Using a graph to find velocity and position at a said time
In summary: I'm pretty sure that I'm wrong, and I'm confused about a couple of things:1. Is the initial velocity always going to be -3 m/s, or is it going to be the velocity that was the end point of the other equation? Because above, I got 11 m/s for the first equation - does that mean that 11 m/s will be my initial velocity for the second equation (when I'm doing the second part of the graph) as well? Or will it be -3 m/s? 2. I know this is a stupid question, but is the time variable a change in time, in other words, the final time minus the time you're starting at? Like looking
themadcow45
Consider the plot below describing the acceleration of a particle along a straight line with an initial position of −15 m and an initial velocity of −3 m/s.
A) What is the velocity at 5 s? Answer in units of m/s.
B) What is the position at 5 s? Answer in units of m.
v = v0 + (a)(t)
A) Because the acceleration is obviously not constant, I added the periods of constant acceleration, from 0 to 2 seconds and 2 to 5 seconds as so:
v= -3 + (7)(2) = 11
v= 11 + (1)(5) = 16
27 (answer)
2. I know this is a stupid question, but is the time variable a change in time, in other words, the final time minus the time you're starting at? Like looking at the graph, from the interval from 2 to 5 seconds when the acceleration is constant, is "t" 3 seconds, the change in time, or is it 5 seconds, the final time the acceleration is constant? I'm confused as to what to use.
Once I get that squared away, I'll be able to focus on part "B" of the problem.
Thanks for the help!
Yes, 11 m/s will be the initial velocity for the second stage.
For the motion equation v(t) = vo + a*t you always assume that time begins at zero. So for your calculations you want to use the Δt. That is, you "reset the clock" to zero at the beginning of each stage and then the variable t becomes the elapsed time during that stage.
So I'd change my second equation accordingly, and this would be the result, right?
v= -3 + (7)(2) = 11
v= 11 + (1)(3) = 14
Total velocity = 25 m/s
v = v0 + (a)(t)
v= -3 + (7)(2) = 11
yes
v= 11 + (1)(5) = 16
no
27 (answer)
why are you adding the velocities?
no
yes
which one do you think?
t is the change in time, good question.
I'm adding the velocities because it isn't constant over the entire time, but it is constant at different intervals, so to find the velocity at a given time, I would add all the constant velocities up to that given point, right? If not, what would I do?
v= -3 + (7)(2) = 11
v= 11 + (1)(3) = 14
No, don't add the final velocities from each stage. The final velocity at the end of the second stage *is* the final overall velocity.
Thanks for the help...now for finding the position at 5s, the second part of the problem I listed above, I used this equation:
x-x0 = v0t + .5(a)(t)^2
For 0 to 2 seconds my equation was: x-(-15) = -3(2) + .5(7)(2)^2 = -7
Then for 2 to 5 seconds, this was my equation: x-(-7) = 14(3) + .5(1)(3)^2 = 39.5
However, 39.5 is coming out as the wrong answer...can anyone help me with what I'm doing wrong?
For the second stage the "initial" velocity should be the velocity at the start of the stage, not the end of the stage. You've used 14 m/s as that velocity, which is the end-of-stage velocity.
1. How do I calculate velocity using a graph?
To calculate velocity using a graph, you need to find the slope of the line on the graph at the desired time. The slope represents the rate of change of position, which is equivalent to velocity. Simply divide the change in position by the change in time to get the velocity.
2. Can I find the position of an object at a specific time using a graph?
Yes, you can find the position of an object at a specific time using a graph. To do this, you need to locate the point on the graph that corresponds to the desired time. Then, determine the position of the object at that point on the graph.
3. What unit of measurement is used for velocity and position on a graph?
The unit of measurement for velocity on a graph is usually distance over time, such as meters per second. Position is usually measured in distance units, such as meters or kilometers.
4. How accurate is using a graph to find velocity and position?
The accuracy of using a graph to find velocity and position depends on the accuracy of the data points used to create the graph. The more precise the data, the more accurate the calculations will be. Additionally, using more data points and a larger time frame can also increase accuracy.
5. Can I use a graph to find velocity and position for non-linear motion?
Yes, you can use a graph to find velocity and position for non-linear motion. In this case, the slope of the graph at a specific point will not give you the exact velocity, but you can find the average velocity over a small time interval. Additionally, you can use the curve of the graph to estimate the position at a specific time.
