Rifleman's Rule: Best angle for a projectile up a hill [ ]
In summary, the conversation discusses finding the best angle for a projectile fired at an elevation angle up a hill of slope beta to achieve maximum range. The equation for distance up the slope is given and it is mentioned that if b=0, the equation can be maximized by setting a=45. The question is how to find the relationship between L, b, and a to maximize L. It is suggested to take the derivative of the L equation with respect to alpha and use trigonometry to solve. The conversation also touches on the potential error in elevation when shooting on a steep up-slope or down-slope, with the explanation that it could be due to equivalent errors.
FissionMan1
Rifleman's Rule: Best angle for a projectile up a hill [urgent]
A projectile is fired at speed Vo at an elevation angle alpha up a hill of slope beta (alpha>beta). At what angle will the range (L) be maximum?
L=(2Vo^2)/g*(cos(a)/cos(b))*(sin(a)-cos(a)tan(b)) is the distance up the slope that
From the above equation we can see that if b=zero, we can maximize the equation by making a=45. If a=b, L=0. The question is, how do we make an equation that maximizes L. I tried integrating and setting the LHS to zero, but that didn't work. I need a relationship between L, b, and a that maximizes.
I'd like no full answers here since it is a homework question, just help as to how to find the relationship.
Nevermind! The problem is solved. For future reference, you merely take the derivative of the L equation with respect to alpha. Do a few trig identities in order to get one alpha in the equation and solve.
Can anyone generalize and explain why shooting on a steep up-slope or down-slope might result in an error in elevation? Why might the error be equivalent?
1. What is the Rifleman's Rule?
The Rifleman's Rule is a mathematical formula used to determine the best angle for a projectile to be fired up a hill in order to hit a specific target.
2. How does the Rifleman's Rule work?
The Rifleman's Rule takes into account the slope of the hill, the distance to the target, and the trajectory of the projectile. It uses trigonometry to calculate the correct angle for the projectile to be fired at in order to hit the target.
3. Why is the Rifleman's Rule important?
The Rifleman's Rule is important because it allows for more accurate shooting on hilly terrain. Without taking into account the angle of the hill, the projectile may fall short or overshoot the target, resulting in missed shots.
4. Is the Rifleman's Rule applicable to all types of projectiles?
Yes, the Rifleman's Rule can be applied to any projectile, such as bullets, arrows, or even thrown objects. As long as the trajectory of the projectile can be calculated, the rule can be used.
5. Are there any limitations to the Rifleman's Rule?
The Rifleman's Rule assumes a perfectly flat and level target, so it may not be as accurate for targets on uneven terrain. It also does not take into account external factors such as wind or air resistance, which can affect the trajectory of the projectile. However, it is still a useful tool for improving accuracy when shooting on hilly terrain.
