AP Physics C Mechanics: Conservation of Energy Problem
In summary, the conversation discusses a problem involving a block of mass m attached to a string and connected to a block of mass M on a table through a pulley. The goal is to use energy considerations to find the speed of m as a function of the distance fallen and to repeat the process with the inclusion of friction on the block on the table. The conversation also mentions using calculus to solve some of the later parts of the problem. It is suggested to use forces and F=ma equations to solve for the acceleration of the masses.
SHawking
A block of mass m hangs on the end of a cord and is connected to a block of mass M by a pulley arrangement. (m hangs freely, M is attached to the string, and is on a table top. (So m is attached to a string which goes therough a pulley changing the strings direction 90 degrees where it goes through a pulley attached to M and back to a block on the table. So, for every unit m moves M moves two, sorry this is hard to explain without a diagram.) Using energy considerations,
a.) find an expression for the speed m as a function of the distance fallen,
b.) repeat the previous assuming that a friction of µ acts on the block on the table. Assume everything is at rest.
I don't think it is pertinant, but, it has a few latter parts which are calculus based that I was able to get using what I know to be the answer to a and b.
U=mgh
K=.5mv^2
F=µN (N=mg)
MAybe some kinematics equations for part B?)
I think I got part a, just a math error.
Using the formula K(m)+K(M)+U2(m)=U(m) U2 being the new potential energy after a change in distance, and then
1/2mv^2+1/2m(v/2)^2(It will be half the speed of m)+mgh2=mgh
and solving for M, I think I am getting the correct answer
For B, that is including coefficient of friction I think I am having a lot more trouble. My first attempt was to attempt to factor in the friction into the velocity, but that got an incorrect answer. I then tried tog et force, and integrate (integral of NetForce dx=∆K)
Can anyone point me in the right direction?
I don't see how you can find the acceleration using the energy approach.
I think you will have to work with forces. The force of gravity on m is what makes the masses accelerate. Can you write an F = ma equation for each of the masses? Would the force pulling M be half the force with which m pulls on the rope?
As a scientist, my response to this problem would be to approach it using the principles of conservation of energy. This means that the total energy of the system (including both blocks and the pulley) remains constant throughout the motion.
In part a), we can use the equation for conservation of energy to find the speed of block m as a function of the distance fallen. This can be done by equating the initial potential energy of block m (mgh) to the final kinetic energy of block m (1/2mv^2) plus the final potential energy of block M (mgh2). This results in the equation 1/2mv^2 + mgh2 = mgh, which can be solved for v to get the speed of block m.
In part b), we need to take into account the friction acting on block M as it slides on the table. This frictional force will do work on block M, reducing its kinetic energy and increasing its potential energy. This means that the final potential energy of block M will be less than the initial potential energy of block m (due to the work done by friction), and this needs to be accounted for in the equation for conservation of energy. We can use the equation W = ∆K, where W is the work done by friction and ∆K is the change in kinetic energy of block M. This can be integrated over the distance fallen to find the final speed of block m as a function of the distance fallen, taking into account the work done by friction.
It is also important to note that in both parts a) and b), the system will reach a point where the blocks will stop moving and all the energy will be converted to potential energy. This is when the final kinetic energy of block m (or block M in part b) is zero. At this point, the final potential energy will be equal to the initial potential energy, and we can solve for the maximum distance fallen before the blocks come to a stop.
Overall, this problem can be solved by applying the principles of conservation of energy and taking into account the work done by friction in part b). It may also be helpful to draw a free body diagram and use Newton's laws of motion to determine the forces acting on the blocks.
1. What is conservation of energy in AP Physics C Mechanics?
Conservation of energy is a fundamental principle in physics that states that energy cannot be created or destroyed, only transformed from one form to another. In AP Physics C Mechanics, it specifically refers to the conservation of mechanical energy, which includes the sum of kinetic and potential energy in a system.
2. How is conservation of energy applied to problems in AP Physics C Mechanics?
In problems involving conservation of energy, the initial and final energies of a system are compared to determine if there is a change in energy. The principle of conservation of energy states that the total energy of a system must remain constant, so any changes in energy must be accounted for through the conversion of potential energy to kinetic energy, or vice versa.
3. What are some common types of conservation of energy problems in AP Physics C Mechanics?
Some common types of conservation of energy problems in AP Physics C Mechanics include analyzing the motion of a pendulum, a block sliding down an inclined plane, or a mass-spring system. These problems often involve calculating the initial and final energies of the system and determining the relationship between kinetic and potential energy.
4. What are some strategies for solving conservation of energy problems in AP Physics C Mechanics?
One strategy for solving conservation of energy problems is to carefully identify and label all the relevant energies in the system, such as gravitational potential energy, elastic potential energy, and kinetic energy. Then, use the principle of conservation of energy to set up an equation that equates the initial and final energies and solve for the unknown variable.
5. How does understanding conservation of energy benefit students in AP Physics C Mechanics and beyond?
Understanding conservation of energy is a crucial concept in physics and has many practical applications in real-world scenarios. It also helps students develop critical thinking and problem-solving skills that can be applied to other areas of science and engineering. Additionally, conservation of energy is a fundamental principle that is built upon in more advanced physics courses, making it an essential foundation for future learning.
17K
