Prove a set is closed and bounded but not compact in metric space
In summary, the set X, consisting of integers with the given metric, is closed and bounded but not compact. This can be shown by checking the metric requirements, finding a ball that encompasses all the numbers to prove boundedness, and finding an open cover with no finite subcover to prove non-compactness. The set is also known as the discrete metric, and to determine if it is closed or not, one must consider if it has limit points.
hhqqvn89
Let X be the integers with metric p(m,n)=1, except that p(n,n)=0. Show X is closed and bounded but not compact.
I already check the metric requirement.
I still haven't got any clue yet. Can anyone help me out?
What is your definition of compact? The typical definition is every open cover has a finite subcover. Thus one way you could prove this is to find just one open cover such that there is no finite subcover.
The set you are describing is known as the discrete metric except with integers instead of arbitrary numbers.
To determine if it is closed, you need to know if it has all its limit points. So the question you need to ask is "does this set have limit points"? If it does, are they in the set, if it does not then it is vacuously closed.
To determine if it is bounded you just need to find a ball that encompasses all the numbers which in this case is easy.
Now for non-compactness I'll give you a hint. An open ball of radius greater than one with a center at any point contains the entire set. Find a ball that does not do this then create a ball around each point.
1. What does it mean for a set to be closed and bounded in a metric space?
For a set to be closed and bounded in a metric space, it must satisfy two conditions. First, the set must contain all of its limit points, meaning that any sequence of points in the set that converges must also converge to a point within the set. Second, the set must have a finite diameter, meaning that the distance between any two points in the set is bounded by a real number.
2. Why is it important to prove that a set is closed and bounded?
Proving that a set is closed and bounded in a metric space is important because it guarantees certain properties about the set. For example, a closed and bounded set will have a well-defined boundary and will not have any gaps or holes. This can be useful in many applications, such as in optimization problems or in proving the existence of certain mathematical objects.
3. How do you prove that a set is closed and bounded in a metric space?
To prove that a set is closed and bounded in a metric space, you must show that it satisfies the two conditions mentioned before: it contains all of its limit points and has a finite diameter. This can be done by using the definitions of closed and bounded sets, as well as the properties of metric spaces, such as the triangle inequality and convergence of sequences.
4. What does it mean for a set to be compact in a metric space?
A set is compact in a metric space if it is both closed and bounded, as well as being "small" in some sense. This means that the set cannot be "spread out" infinitely and must be contained within a finite region of the metric space. Compact sets have many useful properties, such as being sequentially compact and having a finite subcover.
5. How can a set be closed and bounded but not compact in a metric space?
A set can be closed and bounded but not compact in a metric space if it fails to satisfy the "smallness" requirement of compactness. This can happen if the set is too spread out or if it contains "holes" or gaps. An example is the set of all real numbers between 0 and 1, which is closed and bounded but not compact because it does not include the endpoints 0 and 1.
  • Topology and Analysis
