An Infinite Lapse of Time is Impossible and Unscientific
In summary, the conversation discusses the concept of an infinite lapse of time and concludes that it is impossible based on modern day observations and scientific theories. The idea of a cyclic universe or a multiverse with infinite time is deemed unscientific. Some scholars propose the concept of eternalism to explain the infinite time paradox, but this is not compatible with scientific theories. The argument also touches on Zeno's paradoxes of infinity and the difference between actual and potential infinity. Overall, the conversation emphasizes the importance of scientific observation in the study of cosmology and the rejection of impossible concepts like infinitely lapsed time.
  • #36
karahka said:
I believe that time has gone on forever and it will do that forever in the future. You say it is impossible, i think different.
We have quite a bit of evidence that time "started" about 13.6*109 years ago, and we have quite a bit of evidence that the Universe will have some sort of death, be it the Big Rip, Big Crunch, or Big Chill, and we can't forget the heat death. Doubting the validity of the Big Bang Theory without the intervention of something creating the Universe so that it's younger than the Big Bang Theory predicts (such as a God creating the Universe a few thousand years ago) would be doubting the validity of General Relativity.
To the OP: The eternalism is just a matter of philosophy, deciding whether or not we want to consider time time in the sense most people think of it or as just another dimension, as the spatial ones are. This has nothing to do with whether or not an infinite lapse of time is possible.
As far as I can tell, your argument goes something along the lines of "a clock can never show infinity as its time interval, therefore, we can't have an infinite interval of time." It depends on how we define infinite time. If we define it as two points along a timeline being infinitely far apart, that's obviously impossible, as it would be impossible to get any sort of information to travel between them to compare anything, such as times. However, the usual definition is that either (assuming one can invent a time machine that takes them an arbitrary amount of time into the past, which is obviously impossible, but just as a thought experiment) one can go an arbitrary amount of time into the past (possible/impossible depending on your model for the Big Bang, whether or not we have a cyclic Universe) or an arbitrary amount of time into the Future (which is perfectly possible with gravitational fields or a bit of special relativity.) That is, there are no bounds on how far you can go into the past or the future (assuming you've invented something that can take you into the past or the future.) And this is perfectly possible. So all you're doing is getting the definition wrong, and misinterpreting what infinity means in this context. (The infinity we're talking about is similar to the definition used in calculus, and quite different from the one used in set theory.)
Space news on Phys.org
  • #37
Time measures changes. That's all it does. Its not a dimension, or an entity. It's a measurement, like distance. It measures the relative duration between events. So, if there is no "change" happening - no events - then there is nothing to measure. Hence then time doesn't "exist". (Not that an abstract measuring system has a real existence anyway).
So "time" will go on forever ONLY IF change (or events) go on forever. [Whats causes change? Energy differential? So time is a function of energy differential]. Once all change has ceased, time therefore ends.
see here for better explanation:-
www.thisistime.co.uk
  • #38
True, but spatial dimensions are also "just" measurements. This doesn't exclude time from being a dimension. And special relativity (or, rather, a very common interpretation of it) suggests that time is a full-on bloomin' dimension.
  • #39
Sorry, flippin' kindle won't let me edit the previous post.
It seems the post I was replying to was talking philosophy as opposed to science, and most of this thread is the same. Should this be in the philosophy section?
  • #40
  • #41
Two VERY important things to say here. Firstly you are wrong. Distance and time are both measurements. Distance measures the dimension "space". Distance is not itself a dimension. Space is the dimension to which distance refers.
Similarly time can be likened to distance. It just measures. And the dimension that time measures is "change".
So "change" is the dimension to which time refers. If you understand this subtle but fantastic thing, you will now be having a double-helix moment. I'll repeat it - change is the dimension to which time refers.
Secondly - The world of you physicists have broken a cardinal rule of academic study. You have failed to explain your terms. You have never bottomed out a core definition of "Time" and have consequently bandied the word around with astonishing rashness, and as a result poured out tons of bovine excrement. Ask Prof Hawkins why he wrote a book on the subject but admitted in the first page of that book he doesn't know what Time is.
So, yes this is not a physics blog, I am no physicist. It is a semantics blog I am posting. But unless you physicist get your collective heads around the core definition of Time you will carry on trying to explain the unexplainable - e.g. you will talk about infinite time when you mean infinite change.
If you understand this about change, then you will easily get to the realisation that everything exist in its own unique change dimension (I've coined the term- change stream). Yes, every quantum particle has its own change dimension ("time dimension" using your poor terminology). You could say, rashly, that there are zillions of time dimensions.
Again, have a look at this www.thisistime.co.uk. Remember, you read it here first..enjoy!
  • #42
You're not making any sense. Dimensions are a very well-defined concept in physics, and your description doesn't bear any resemblance to that definition. Dimensions are a counting of the number of independent parameters required to define an object's shape or position. A rectangle, having length and width, is a two-dimensional object. More complicated two-dimensional shapes can be defined using a series of pairs of parameters defining the vertices. Three-dimensional objects requires sets of three parameters to define their shapes.
  • #43
What I am saying is that the 4th dimension is not universal. It is specific to every individual quantum particle (in fact every composite object too). Its usually called time, so I am saying that Time is not a general, universal dimension. Everything exits in its own unique time (I really mean change rate) dimension.
So, if you have two atomic clocks calibrated identically, and you send one of them into space, and then bring it back, and lo they have diverged. This isn't because time has bent or curverd or warped. It is because they both have unique, non synchronised change dimensions. What has caused these to diverge? I don't know, that's for clever physicist to work out. What I do know is that saying sillly things like time has curved is to misunderstand what time is. Time isn't universal. And it most certainly isn't the casue of this divergence, it merely identifies it.
  • #44
No physics content for quite some time here.
  • Cosmology
  • Cosmology
  • Cosmology
  • Cosmology
