Electron shells in atoms: WHY do they exist as they do?
In summary: One of the most important is the pauli exclusion principle, which states that no two electrons can occupy the same shell. This principle comes from more fundamental rules, such as the wavefunction. Without understanding these rules, it would be impossible to comprehend how atoms work.
PurposeNation
I have seen similar posts, but I haven't seen what seems to be a clear and direct answer.
Why do only a certain number of electrons occupy each shell? Why are the shells arranged in certain distances from the nucleus? Why don't electrons just collapse into the nucleus or fly away?
It seems there are lots of equations and theories that describe HOW electrons behave, predictions about WHERE they may be located, etc. But hard to find the WHY and causality behind these descriptive properties.
Thank you! Please be patient with me, new to this forum and just an amateur fan of physics.
The answer boils down to the fact that there are a few simple rules that govern how subatomic particles interact. One of the most important in regards to electron orbitals is the pauli exclusion principle. When it comes right down to it, we don't know why the fundamental rules of nature exist. We only know that they do, and asking "why" a fundamental rule exists is typically a pointless question, as there is no answer until another theory is developed (which then has its own fundamental rules that you could ask "why" about).
Hi Drakkith. Thank you. Yes, have read about the Pauli Exclusion Principle. Understand it holds up well, but still very unsatisfying as to WHY electrons behave this way.
Hopefully I can continue to keep asking "pointless" questions on this forum if folks will be patient with me. =)
Thanks again.
Some things, like the pauli exclusion principle, arise from more fundamental rules. The PEP is due to the way the wavefunctions have to work for certain classes of particles called fermions. Other things, such as why a particle can be described by a wavefunction, just comes down to, "that's just the way it is". Unsatisfying maybe, but the truth.
Does atom has any shells?
How this theorie appeared?
Shells refer to specific energy levels that electrons in atoms and molecules occupy. They are not physical shells.
http://en.wikipedia.org/wiki/Electron_shell
The idea of shells came with the develop of quantum physics in the early 1900's.
Also I wrote this somewhere else too...
The shells don't give you a certain radius around the nucleus. They give you definite energies.
The QM treatment of the atom, gives you the probability of finding an electron within some radius range. The definite radii appear only as the classically behaving mean values of the radius.
The probability of an electron collapsing in a nucleus is rather small (it can happen and is called electron capture) but it generally happens to heavier atoms (proton-rich nuclides). The electron can as well fly away (ionization) if it gets enough energy to leave its bound state.
What do you mean "why" and "casuality"? Everything works fine with casuality in QFT... The Schrodinger equation doesn't have to be casual, because it's not a relativistic equation (is not Lorentz covariant). The why itself is unanswered because it makes no sense (at least to me as you ask it)- it's how nature works and how the eigenvalue-eigenstate equations work.
Certainly, but each time such exact seems strange.
By the way, bit chemie:
how to obtain 2g Fe2+?
I'm sorry, I can't understand your post very well.
PurposeNation said:
\but still very unsatisfying as to WHY electrons behave this way.
Its related to a deep theorem of Quantum Field Theory called the spin statistics theorem:
http://en.wikipedia.org/wiki/Spin-statistics_theorem
'Spin statistics theorem implies that half-integer spin particles are subject to the Pauli exclusion principle, while integer-spin particles are not. Only one fermion can occupy a given quantum state at any time, while the number of bosons that can occupy a quantum state is not restricted. The basic building blocks of matter such as protons, neutrons, and electrons are fermions. Particles such as the photon, which mediate forces between matter particles, are bosons.'
Thanks
Bill
1. Why do electron shells in atoms exist?
Electron shells exist because they allow electrons to exist in specific energy levels around the nucleus of an atom. These energy levels are necessary for the stability of the atom, as electrons in lower energy levels are held more tightly to the nucleus and are less likely to be lost or gained.
2. How are the number of electron shells determined in an atom?
The number of electron shells in an atom is determined by the number of electrons present. Each shell can hold a certain maximum number of electrons, with the first shell holding a maximum of 2, the second holding a maximum of 8, and so on. Once the maximum number of electrons in a shell is reached, any additional electrons will fill the next shell.
3. What is the significance of the different energy levels in electron shells?
The different energy levels in electron shells correspond to different distances from the nucleus and therefore different levels of energy. Electrons in higher energy levels have more potential energy and are therefore more easily excited, while electrons in lower energy levels are more stable and less likely to participate in chemical reactions.
4. Why do electrons fill lower energy levels before filling higher energy levels?
This is due to the principle known as the aufbau principle, which states that electrons will fill the lowest energy levels first before moving to higher energy levels. This is because lower energy levels are closer to the nucleus and are therefore more stable, while higher energy levels are further away and are less stable.
5. Can electron shells overlap or touch each other?
No, electron shells cannot overlap or touch each other. This is because each shell represents a specific energy level and only a certain number of electrons can occupy each shell. If shells were to overlap, it would result in a loss of stability for the atom.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
