Pull Back Manifolds: Checking Exercise on p67/p68 & p69
In summary, the conversation discusses an exercise on p67 of a thread and a mistake made on p69, where the correct answer is (\phi^* g)_{\mu \nu} = diag ( \sin^2{\theta}).
latentcorpse
1,444
In the notes attached in this thread:
https://www.physicsforums.com/showthread.php?t=457123
How do we go about the exercise at the bottom of p67/top of p68?
And secondly, at the top of p69, he giveas the example and invites us to check that [itex](\phi^* g)_{\mu \nu} = diag ( \sin^2{\theta})[/itex]
However I find that
[itex](\phi^* g)_{\mu \nu}= \left( \frac{ \partial y^\alpha }{ \partial \theta} \right) \left( \frac{\partial y^\beta}{ \partial \phi} \right) \delta_{\alpha \beta} = \left( \frac{ \partial y^\alpha }{ \partial \theta} \right) \left( \frac{\partial y^\alpha}{ \partial \phi} \right) = \begin{pmatrix} \cos{\theta} \cos{\phi} & \cos{\theta} \sin{\phi} & -\sin{\theta} \end{pmatrix} \begin{pmatrix} -\sin{\theta} \sin{\phi} \\ \sin{\theta}\cos{\phi} \\ 0 \end{pmatrix}[/itex]
[itex]=-\cos{\theta} \cos{\phi} \sin{\theta} \sin{\phi}+\cos{\theta} \cos{\phi} \sin{\theta} \sin{\phi}=0[/itex]
Where have I gone wrong?
Thanks
The mistake you made is in the last step. You assumed that $\partial y^\alpha/\partial \phi = (0, 0, 0)$, when in fact it is $(-\sin{\theta}\sin{\phi}, \sin{\theta}\cos{\phi}, 0)$. Thus, when you take the product of the two vectors, you get $\sin^2{\theta}$.
1. What is a pull back manifold?
A pull back manifold is a mathematical concept used in the study of differential geometry. It is a type of manifold that allows for the transfer of data or structures from one manifold to another. This is done through a pull back, which is a mathematical operation that maps points from one manifold to another.
2. How is a pull back manifold used in checking exercises?
In checking exercises, a pull back manifold is used to compare the geometric structures of two different manifolds. By pulling back the structures from one manifold to another, it allows for a direct comparison and identification of any differences or similarities between the two manifolds.
3. What is the purpose of the checking exercise on p67/p68 & p69?
The purpose of the checking exercise is to test the understanding of pull back manifolds and their use in comparing geometric structures. It also serves as a way to practice and reinforce the concepts and techniques learned in the study of differential geometry.
4. What are some examples of geometric structures that can be compared using pull back manifolds?
Some examples of geometric structures that can be compared using pull back manifolds include metric tensors, differential forms, and vector fields. These structures can be pulled back from one manifold to another and then compared to analyze any differences or similarities between the two manifolds.
5. How does the pull back operation work in a pull back manifold?
The pull back operation in a pull back manifold is a mathematical mapping that takes points from one manifold and maps them to points on another manifold. This is achieved through the use of a smooth mapping function between the two manifolds. The pull back operation preserves the geometric structures of the original manifold, allowing for a direct comparison with the structures on the target manifold.
