Particle-photon interaction to create new particle
In summary: In the lab frame, the minimum energy is:\frac{E_{min}}{m_p c^2} = \frac{E_0}{m_p c^2} + \frac{m_p c^2}{4 E_0}
thepopasmurf
76
A particle with known rest mass energy, [itex]m_{p} c^{2}[/itex] pass through a cloud of monoenergetic photons with energy [itex]E_{\gamma}[/itex]. The particle collides with a photon and a particle A, with mass [itex]m_A[/itex] is created. Show that the minimum energy of the particle required for the interaction is:
[itex]\frac{E_{min}}{m_p c^2} = \frac{E_0}{m_p c^2} + \frac{m_p c^2}{4 E_0}[/itex]
where
[itex] E_0 = \frac{(m_{A}^2 - m_{p}^2)c^4}{4 E_{\gamma}}[/itex]
The relevant equations are the relativistic kinematic equations:
[itex]\textbf{p} = (p_0, \vec{p})[/itex]
[itex]E^2 = p^2c^2 + m^2c^4[/itex]
plus conservation of the four momentum (implying conservation of energy and momentum).
So my first step was to consider the collision in the zero momentum frame since that gives the minimum energy to create the particle A. This also implies that the photon and particle are colinear, otherwise it would not be the zero momentum frame.
In this frame:
[itex]E_p + E_{\gamma} = m_Ac^2[/itex]
considering the four momentum:
[itex]p_p + p_{\gamma} = p_A[/itex]
[itex](E_p + E_{\gamma},0) = (m_Ac^2,0)[/itex]
The square of the four momentum of invariant, so square both sides:
[itex]E_p^2 + E_{\gamma}^2 + 2E_pE_{\gamma} = m_A^2 c^4[/itex]
[itex](m_p^2c^4 + p_p^2c^2) + p_{\gamma}^2c^2 + 2E_pE_{\gamma}= m_A^2 c^4[/itex]
[itex]m_p^2c^4 + 2p^2c^2 + 2E_pE_{\gamma} = m_A^2 c^4[/itex]
Third line comes from conservation of momentum.
Rearrange to give:
[itex]E_p = \frac{(m_A^2 - m_p^2)c^4}{2E_{\gamma}} - \frac{2p^2c^2}{2E_{\gamma}}[/itex]
[itex]E_p = 2E_0 - E_{\gamma}[/itex]
I feel that I'm very close with this result but I can't get to the required expression.
Any help would be appreciated. Thanks
Be careful with the notation. ##E_\gamma## in the rest frame of A does not have to be the same as ##E_\gamma## given in the problem statement.
Ok, so here's my reworking of the problem:
In lab frame four-momentum is:
[itex]p_p + p_{\gamma}[/itex]
The square of this is invariant
[itex](p_p + p_{\gamma})\cdot(p_p + p_{\gamma}) = \frac{E_p^2}{c^2} - p_p^2 + \frac{E_{\gamma}^2}{c^2} - p_{\gamma}^2 + \frac{2E_pE_{\gamma}}{c^2} - 2p_p\cdot p_{\gamma} [/itex]
In the zero momentum frame we have:
[itex] (p'_p + p'_{\gamma}) \cdot (p'_p + p'_{\gamma}) =
\frac{(E')_p^2}{c^2} + \frac{(E')_{\gamma}^2}{c^2} + \frac{2E'_pE'_{\gamma}}{c^2}[/itex]
Both of these values also equal [itex]m_A^2c^4[/itex]
Sorry, but I'm not seeing where to go from here. I don't really see how to perform this transformation properly.
The left side has 4-vectors, the right side 3-vectors with the same symbol?
Let c=1.
Eγ=pγ=-pp
Therefore,
##m_a^2 = m_p^2+2E_{min}E_\gamma + 2E_\gamma^2##
Hmm, I don't think that leads to the target. Is that the minimal energy in the lab frame, or maybe some other frame?
I am always excited to see investigations into particle-photon interactions, as they can lead to the creation of new particles and provide insight into the fundamental workings of our universe. Your attempt at solving the problem is commendable and shows a good understanding of the relevant equations and principles involved.
It seems that you have correctly identified the zero momentum frame as the most suitable frame for this particular collision, and your use of conservation of four momentum is also appropriate. However, there are a few minor errors in your calculations that may have led to your difficulty in arriving at the required expression.
Firstly, in the third line of your solution, the term "p" should actually be "p_p" to represent the momentum of the particle before the collision. This will lead to a correction in the following line where you have two "p" terms, which should now be "p_p" and "p_{\gamma}".
Secondly, in the last line of your solution, I believe there may be a sign error. Since we are dealing with a minimum energy scenario, the particle must have the minimum possible energy before the collision, which would be negative in this case. Therefore, the correct expression should be:
E_p = -2E_0 - E_{\gamma}
This leads to the required expression of:
where
I hope this helps in your understanding of this problem and I encourage you to continue exploring the fascinating world of particle-photon interactions. Keep up the good work!
1. What is particle-photon interaction?
Particle-photon interaction is a fundamental process in which a particle and a photon (a particle of light) interact with each other, resulting in the creation of a new particle.
2. How does particle-photon interaction work?
Particle-photon interaction occurs when a photon approaches a particle and is absorbed by it. This interaction causes the particle to gain energy and can result in the creation of a new particle, depending on the amount of energy transferred.
3. What types of particles can be created through particle-photon interaction?
Particle-photon interaction can create a variety of particles, including elementary particles such as electrons, as well as composite particles like protons and neutrons. The type of particle created depends on the energy of the photon and the properties of the interacting particle.
4. What is the importance of particle-photon interaction in particle physics?
Particle-photon interaction plays a crucial role in understanding the fundamental building blocks of our universe and the interactions between them. It also has practical applications, such as in medical imaging and particle accelerators.
5. How is particle-photon interaction studied?
Particle-photon interaction can be studied through experiments using particle accelerators, where high-energy particles and photons are collided to observe the resulting interactions. Theoretical models and calculations also play a significant role in understanding and predicting particle-photon interactions.
