Intuition why area of a period of sinx =4 = area of square unit circle
In summary: The area under the sine from 1 to pi/2 can be cut up to fill the gap between the sin and y=1 from 0 to 1.
CoolFool
This isn't really homework, but I've been reviewing calc & trig and realized that the area of one period of sin(x) = 4. Since sin(θ) can be understood as the y-value of points along a unit circle, I noticed that the area of a unit square that bounds the unit circle is also 4. Is this a relationship about squaring a circle, or just a coincidence?
A unit circle is a circle with a radius of one.
Area of one period of sin x is [itex] 2 \int^{\pi}_{0} sin(x) dx = 4[/itex]
For a unit circle, r=1. So the area of a square bounding the unit circle is also [itex](2r)^{2} = 4[/itex].
I tried drawing out what the area under the curve of sin(x) means, focusing on the first quarter of the unit circle (so, from 0 to pi/2, which is 1/4 the period of sinx and has an area of 1. The square bounding the quarter of a circle also has an area of [itex]r^{2}=1[/itex].)
I understand that the area under sin(x) is the infinite sum of all measurements of the y-coordinate of a point on a rotating unit circle. But why does that become a square?
In other words, what does the area under sin(x) mean and what is its relationship to the square bounding the unit circle (or the 1x1 square bounding the quarter of the circle)? Why?
I hope I have conveyed this question clearly. Thank you for your help!
Niggle: The area between the x-axis and sin(x) for any integer number of periods is 0.
What you did was the area of |sin(x)| ...
The relationship is to do with the way "sine" is defined on the unit circle.
You can think of it like the way Pythagoras sometimes gets demonstrated by putting squares on each side of a right-angle triangle and showing that the two smaller squares can be cut up so they fit exactly inside the biggest one.
Note: does it make a difference if the circle has unit circumference instead of unit area?
I don't get what you mean about the cut up triangles for this application. My confusion is that it doesn't fit. The area under a period of |sin x| = 4, a unit circle's area is only [itex]\pi[/itex].
A unit circle is a circle with a radius of one, not an area of one. I've now made this explicit in the question.
Its a simile - an analogy ...
That was already clear. The sine is a specific length defined on the unit-radius circle... since the one was derived from the other, it is not surprising to find they have special relationships.
1. What is intuition?
Intuition is the ability to understand something instinctively, without the need for conscious reasoning or logical analysis.
2. Why is the area of a period of sinx equal to 4?
The period of sinx is defined as the smallest positive value of x for which sinx repeats itself. In this case, the period of sinx is 2π. The area under one period of sinx is equal to 2, and since the period is 2π, the total area of one full period is equal to 4.
3. How is the area of a square related to the unit circle?
The unit circle is a circle with a radius of 1 centered at the origin. The area of this circle is equal to π, and since the diameter of a circle is equal to twice the radius, the area of a square inscribed within the unit circle is also equal to 4.
4. Why is the area of a period of sinx equal to the area of a unit circle?
This is because the graph of sinx and the unit circle have the same shape and occupy the same amount of space within their boundaries. Therefore, their areas are equal.
5. How does understanding the relationship between sinx and the unit circle help with problem-solving?
Understanding the relationship between sinx and the unit circle can help with problem-solving by providing a visual representation of the trigonometric function. This can make it easier to understand and apply concepts such as amplitude, period, and phase shift in real-world scenarios.
  • Calculus
