- #36
petterg
- 162
- 7
Baluncore said:Maybe there is a misunderstanding here of the orientation of coils.
I guess it is. When I say vertical coil I think of the coil produced when holding my finger vertical and spin a wire around it. The wire then will be somewhere near the horizontal plane, while the axis and magnetic field in the coil will be vertical. I guess you call this coil horizontal because it's wire is close to horizontal, while I say it's vertical because of the direction of it's axis.
Still, the method you suggest requires a vertical and a horizontal coil to change phase simultaneously, which they won't.
Baluncore said:The phase of the signal is determined by the direction the flux passes through the coil, use your “Right Hand Rule”. The horizontal plane coil, flat with the floor, will always be above the wire so it will have a phase and magnitude determined by the left/right horizontal position error. The vertical plane coil will have a phase determined by the direction faced along the wire. That phase reverses if you turn the vehicle 180°, but so does the left/right phase picked up by the horizontal plane coil, so the phase detection still steers correctly along the line.
With that misunderstanding cleared out, let's check if there is another misunderstanding too. As far as I understand the second statement in bold from the quote above says the exact opposite of the first statement in bold. They both can't be correct. To my knowledge the first statement is correct, the second is not. If they both were correct the problem would be solved. (I hope you see a second misunderstanding here.)
