Calculating Tension in a Wire with a Perched Bird: A Physics Problem
In summary: F = ma-mg + Sin(0.008)T = 0-14.7 N + Sin(0.008)T = 0T= 14.7 N/Sin(0.008)...is that right so far? Or does the force of gravity on the bird not fit in there?Yes, that's correct. The tension in the wire is 14.7 N due to the weight of the bird and the downward force of gravity.
hm8
The distance between two telephone poles is 46.0 m. When a 1.50 kg bird lands on the telephone wire midway between the poles, the wire sags 0.190 m.
How much tension does the bird produce in the wire? Ignore the weight of the wire.
F=ma
I really just don't know where to start with this one...its confusing to me since the force of the bird (1.5 kg*9.8m/s2 = 14.7 N) is vertical, but the tension is sideways...so for F=ma, would I be looking at the sum of the forces in the x or y direction? Or is there some way to simplify it to one dimension?
What's the question?
So the question is find the tension in the cable?
The tension is not entirely horizontal, because the rope sags. You'll have to resolve the forces into components. In reality, the rope would probably curve, but for simplicity, why don't you assume that the rope has two straight, sloping sections that meet at the midpoint (where the bird is sitting), to form a sort of "V" shape. The vertical position of the midpoint (bottom of the "V") is 0.190 m below where it was when the bird was absent and the rope was horizontal.
Does that help?
Gah, somehow forgot to put the question in. Sorry.
Hello hm8.If by sideways you mean horizontal that's not exactly true.The wire sags so the wire on each side of the bird is inclined upwards at an angle to the horizontal.Start by sketching a diagram and marking in the forces at the point where the bird is.You will have the weight of the bird acting down and the tension in each side of the wire acting along the line of the wire.
Does that help?
Okay...so the downward component of the tension force is 14.7 N?
Still not sure where to go from there...how do I use the length of the wire and the amount it sags? I guess I can figure out that the length of one half of this 'V' is 23.0007 m (square root of .192 + (46/2)2), but does that help me?
No, because tension always acts in the "along the length of the rope" direction. Dadface has given you good advice when it comes to actually implementing what I suggested.
Edit: okay maybe it's not so clear from his post as I thought. Use what you know of the geometry of the situation to figure out by what angle each half of the rope is inclined (relative to the horizontal). Then use that angle, and basic trigonometry, to resolve the tension force into horizontal and vertical components. Then use Newton's second law to figure out what conditions on those components must be true in order for the situation to be static (i.e. sums of forces in x and y directions are *each* equal to zero) .
Okay, so the rope is inclined at and angle of 0.00826 degrees above the horizontal.
So the components of the tension vector would just be Cos(0.008)T and Sin(0.008)T
So, in the Y direction...
F = ma
EDIT:
Sorry, make that .4733 degrees for the angle, my calculator was in radians mode.
The method looks right with a few minor issues. Draw a free body diagram for the bird. What forces act on it? In particular, how many forces act on it due to the rope? What I'm hinting at is, are you sure that there should be only one Tsin(theta) term?
1. What is the "Tension bird on wire problem"?
The "Tension bird on wire problem" is a physics problem that involves determining the tension in a wire supporting a bird. It is a classic example of a static equilibrium problem, where the forces acting on the bird and the wire are balanced.
2. How do you solve the "Tension bird on wire problem"?
To solve the "Tension bird on wire problem", you first need to draw a free body diagram of the bird and the wire, including all the forces acting on them. Then, you can use Newton's laws of motion and the equations for static equilibrium to set up and solve a system of equations to find the tension in the wire.
3. What factors affect the tension in the wire in the "Tension bird on wire problem"?
The tension in the wire is affected by the weight of the bird, the angle of the wire, and any additional forces acting on the bird or the wire, such as wind or an external force. The length and thickness of the wire also play a role in determining the tension.
4. How does the angle of the wire affect the tension in the "Tension bird on wire problem"?
The tension in the wire increases as the angle of the wire decreases. This is because a smaller angle means a greater vertical component of the tension force, which is needed to balance the weight of the bird.
5. Can the "Tension bird on wire problem" be applied to real-life situations?
Yes, the principles involved in solving the "Tension bird on wire problem" can be applied to many real-life situations, such as determining the tension in cables supporting structures or in suspension bridges. It is also commonly used in engineering and construction to ensure the stability and safety of structures.
