Register to reply
? about Soldering Iron Tip Care
by meBigGuy
Tags: care, iron, soldering
Share this thread:
meBigGuy
#1
Jul18-14, 12:37 AM
P: 1,084
I have a Weller WTCP station (antique) that I just bought new tips for. I read in some tip reviews that the new "lead-free" technology has ruined the lifespan of tips. Does anyone have any tricks or hints to lengthen the lifespan of these new tips? Any process that can improve the tip? Any tricks you do to keep them functional longer (beyond turning the iron off).
Phys.Org News Partner Engineering news on Phys.org
A spray-on light show on four wheels: Darkside Scientific
Research project on accident-avoiding vehicle concluded
Smaller artificial magnetic conductors allow for more compact antenna hardware
Baluncore
#2
Jul18-14, 02:49 AM
Sci Advisor
Thanks
P: 1,951
Use the lowest temperature tip that will fully melt the solder.
Wipe the tip on a soft sponge to remove excess solder. I wet the sponge with 50% glycol coolant which is hygroscopic, so it is always available and does not dry out. Low water content in the sponge preserves the temperature of the tip while wiping.
A soft sponge will not damage the tip. Stainless steel wool works OK with bare copper tips, but it will remove the protective plating and destroy a WTCP tip.
You can often use the old 60:40, Pb-Sn eutectic solder, preferably with a tad of Cu to preserve the tip.
ROHS Pb free solder is not required for prototyping, critical process control or data communication equipment.
WTCP tips are available at reasonable prices, don't pay the RRP, you can often do better. Keep a few in stock. They work well, so what if they wear out, they easily pay their way.
Register to reply
Related Discussions
Burning a soldering iron Electrical Engineering 14
Soldering iron not working Electrical Engineering 9
Soldering iron advice Electrical Engineering 3
Changing resistance on soldering iron Electrical Engineering 6
How to Separate Rust Iron (Fe2O3) into Ferum/Iron and Oxygen? Chemistry 5
