Question about deflection of light test
In summary, Einstein's theory that the speed of light is always the same was flawed because he assumed that any observer moving at a constant speed would have the same laws of physics. He solved this by making space, mass and time malleable. The bending light experiment was used to prove his theory by proving that light is constant. If you are trying to see what answer you would get with Newtonian formulas you should not be using his constant value for the speed of light.
RoccoV
I've always been fascinated by Einstein’s theories about the speed of light and have always wondered about something that I've never been able to find the answer to. Any books I read were either too simple and did not address my question or too complex that I didn't understand it.
It's time I put this question forward in the hopes that someone will be able to answer it in terms I understand.
It’s in regards to Einstein’s deflection of light by the Sun test. From what I understand, using his equations, he calculated how much the sun would bend light before it could be tested. When it could be tested it was found to be correct and when normal geometry (not sure of the correct term) was used that answer was wrong.
My question is: What did they use for the speed of light when they tried normal geometry equations?
This has been bothering me for awhile. I’ll explain why after I receive an answer.
Thanks,
Rocco.
Normal geometry?? Prior to General Relativity Theory, anyone would predict *zero* deflection. Why would gravity affect a mass-less particle?
It doesn't. GR predicted spacetime curvature. It still does. Photons are massless particles traveling through spacetime. Spacetime bends, photons do not. Not liking it is optional. This is an exercise in futility.
Hey ...wouldnt Newtonian gravity also predict bending of light?as acceleration due to gravity has nothing to do with mass of the object that is being attracted(in this case the photon)
You can have a pseudo-Newtonian theory in which photons are treated as having a 'mass' equal to their energy/c2. However this only produces half the GR value, which is that observed.
This is because that calculation does not take into account the curvature of space.
The full GR expression for a light ray just grazing the surface of the Sun is given by:
[tex]\theta = \frac{4GM_{\odot}}{R_{\odot}c^2}\frac{1 + \gamma}{2} = 1.75\frac{1 + \gamma}{2}[/tex] arcsecs.
where [itex]\gamma[/itex] describes the amount of space curvature per unit mass, (actually GM).
The 'Newtonian' component is:
[tex]\theta_N = \frac{4GM_{\odot}}{R_{\odot}c^2}\frac{1}{2} = 0.83[/tex] arcsecs.
This 'Newtonian' component in the GR calculation, mentioned above, is the remaining part of the curvature of space-time i.e. that due to time dilation, equal to the Newtonian 'acceleration' on the photon at each part of its trajectory. It is this component that is described by the Einstein Equivalence Principle, "photons fall towards the Sun at the same rate as all particles".
Garth
I don't understand all of your post but I see that C is used in the Newtonian equation so now we come to why I asked the question in the first place.
First a little history. From what I understand of Einstein’s formulas, he started with 2 assumptions;
1. Any observer moving at a constant speed would have the same laws of physics.
2. The speed of light c is always constant, no matter how fast or in what direction the light source was moving.
Or as I like to say; everything is relative except light.
First of all I have a problem with that. Why should light be different than everything else in the universe? But let’s move on.
Einstein then did some calculations and found that light can’t be a constant because it causes contradictions in his calculations and of course we know it is counterintuitive.
But, being the great mathematician that he is, he took on the challenge to find a way to make it work and in the end he did it by making space, mass and time malleable. In other words to make one counterintuitive fact true (that light is constant) he had to introduce another 3 counterintuitive elements (namely that space, mass and time are malleable).
Now we come back to the bending light experiment and its apparent result supporting Einstein’s theories. If you are trying to prove Einstein’s formulas you are actually trying to prove his original assumption (that the speed of light is a constant). After all the formulas directly came about because of that assumption.
Would it then not make sense that if you are trying to see what answer you would get with Newtonian formulas you should not be using his constant value for the speed of light? Only Einstein’s formula was created to cater for that constant value. There is no place for it in Newtonian logic.
I think early on scientists took it so much for granted that when doing calculations they used C with and without Einstein’s formulas without thinking and so of course it seemed that only Einstein’s formulas came up with the correct answer.
I suspect and put forward for anyone who can do the calculations, that if you used a variable speed of light with the Newtonian formulas you may well also get the correct answer with the bending light test and possibly with others.
So if I’m correct, on one hand we would have a counterintuitive assumption and 3 counterintuitive changes to our understanding of space, mass and time and on the other hand we would have light acting just like everything else in the universe and everything else behaving the way we feel it should.
Now, all that remains is to apply one swift swipe with Occam’s Razor to see what remains.
Or maybe I'm just showing my ignorance. Please feel free to correct any errors in my understanding and keep any explanations at this layman level or I problably won't understand it. Thanks.
Rocco.
RoccoV said:
I think early on scientists took it so much for granted [...] without thinking [...]
So if I’m correct [...] all that remains [sic] is to apply one swift swipe with Occam’s Razor [...] Or maybe I'm just showing my ignorance.
Look, yes, you're just showing your ignorance. It's a bit rude to accuse so many scientists of not thinking, you should first try to understand what it really means to be a scientist and second study the history of relativity theory.
Relativity is a simple theory (in the sense that it can be defined with just a few short axioms), its predictions have been surprising and nonetheless verified to high precision. You're suggesting that a completely different theory might make a couple of the same predictions. Who cares, unless it can make all of the same predictions plus get something new correct (something that relativity gets wrong)? Your theory certainly isn't simpler yet, since you still need to arbitrarily specify how the speed changes. And worse, you haven't even bothered to complete your theory (nor state a specific prediction), and already you're criticising the mainstream theory!
I suggest you sit in on some university level courses, and learn the mainstream theory. It is "crackpot" behaviour to propose your own new theories before you even know how to scientifically compare the theories' merit.
Special relativity says that the speed of light at the observer's own location is fixed, and this has been confirmed to very high precision by experiment, to the point that it is now fixed by definition, and so units of length and time now have a fixed relationship. (The original question as to whether the speed of light is fixed is therefore now replaced by a question as to whether the size of the metre is constant).
However, the speed of light at a remote location is a matter of choosing your definitions. If you try to map gravitational effects on to a flat Euclidean coordinate system, you will find that the local speed of light relative to that coordinate system depends on the potential, and may even depend on the direction. If you choose an "isotropic" coordinate system (where the ratio of the local ruler size to the corresponding spatial coordinate is the same in all directions, which is for example known to be possible in a spherically symmetrical potential) then you can calculate the effects of gravity on light and orbits by treating the speed of light as a scalar variable which is a function of the potential. When the appropriate function is used for the potential to match General Relativity, the usual GR expressions are obtained for the deflection of light and (more sensitively) the precession of orbits.
The first-order approximation is that the coordinate c varies as (1 - 2GM/rc^2), so the fractional change is twice the Newtonian potential. For calculating the precession of orbits accurately, it is necessary to use the correct second-order term in (GM/rc^2)^2 as well.
This method of calculating using a variable scalar c is limited to the special case of isotropic coordinate systems. In more general cases, the speed of light relative to the coordinate system varies with direction, and calculations are usually performed using tensors instead.
RoccoV said:
I don't understand ...
No don't “move on”
because in the context you say "every thing is relative" you are incorrect to say 'except light'.
All observers follow the same rules of physics; include how they observe light. No Except about it.
All observers use the same physics to find the new speed in there own reference frame of anything (including light) send at v1 from a reference frame moving at v2 .
That correct physics is:
vtotal = (v1 + v2) / (1 + v1 v2/cc)
When you say 'except light' what rules do you think light is not following?
Not this one; if v1 is “c” how is vtotal going to be anything but “c” as well? Use and refrance frame speed you want 0.1c. 0.5c even 1.0c or the impossible referance frame speed of 1.1c (which in fact Hubble did find)! Light speed will still total 1.0c as SR demands.
Before you “move on” to GR, do what you can to be sure you understand SR.
I thought Einstein’s second assumption was that light would always appear to be moving at speed C regardless of the frame of reference and this caused contradictions unless time, space and mass were made malleable.
Did I understand that wrong?
"malleable" isn't quite it (the usual term is "relative") but sure, that much is ok. Obviously there is now ample evidence to verify this "assumption".
So would they have used a constant value for the speed of light, namely C, with the bending light test when doing the calculations using Einstein’s formulas and a variable speed of light with the Newtonian formulas because the particles of light would be speeding up as they approached the sun and slowing down as they moved away? Or doesn’t the speed of light come into it? Or have I misunderstood it completely?
Again, please keep explanations in layman’s terms. No formulas. I can’t follow them.
The Newtonian argument simply follows from the "Principle of equivalence" which says that gravity is locally the same as acceleration, so one would expect light beams in a box subjected to a gravitational field to behave in the same way as light beams in a box which is being accelerated upwards in the absence of a field. From this, one would expect light traveling past the sun to be accelerated in exactly the same way as a material object would be.
That basic argument assumes that space itself is unaffected by gravity, but from Einstein's equations we find that relative to some "flat" rectangular coordinate system, space as measured by local rulers "shrinks" in a deeper gravitational potential, so it is in a sense slightly more "dense" closer to the sun, and light therefore travels more slowly, as if traveling through a medium with an increased refractive index. This means that light passing the sun (or a material object traveling at near the speed of light) is deflected by exactly twice as much as would be predicted from the simple Newtonian acceleration. This has of course been confirmed by experiment.
This might suggest that a horizontal light beam within a box would be accelerated downwards twice as much as a material object. It is indeed accelerated downwards by twice the Newtonian acceleration relative to the flat coordinate system. However, the local horizontal spatial coordinates in a gravitational field appear to be slightly curved downwards relative to the background flat coordinate system, by an amount which is equivalent to the usual Newtonian acceleration when traveling horizontally at c, and the vertical coordinates (the sides of the box) converge slightly in a downwards direction. Relative to those local curved coordinates, a fast-moving object accelerates downwards only by the usual Newtonian acceleration, so in the local view the acceleration does not depend on the speed and observations are consistent with the Principle of Equivalence.
RoccoV
I thought we'd agreed that light can't slow down or speed up ? That's what it means when it is said that the speed of light is constant. Are you grasping this point ?
You know, from a quite natural point of view, light slows down near the sun (as it would in a converging refractive lense).
How far do you intend to progress, depending on other people to interpret every step of the way? I suggest you get a first year undergraduate physics textbook (like Tipler), some high school maths textbooks, and work towards being able to understand some of this material properly for yourself. (After that you would do the exercises in Rindler's SR book, then start on a GR textbook. Finally, you need to thoroughly research important experimental results, not just one or two.)
One subtle point to be aware of:
Using local clocks and rulers, light does not speed up or slow down as it approaches or leaves a large mass, though it does gain (in the former case) or lose (in the later case) energy and momentum.
However, the clocks and rulers themselves can be said to change, i.e. due to gravitational time dilation. The speed of light is only constant when measured using local clocks and rulers.
You really won't get anywhere without math, Rocco!
I think you are being badly confused because none of the participants in the discussion are being sufficiently precise in describing what theory and what simplifying assumptions they have in mind when they say this or that. Even worse, you insist upon the following terribly misguided principle:
I like to define mathematics as the art of reasoning about simple phenomena without getting confused. Without its assistance, even simple phenomena confuse humans. This is why mathematics is essential for understanding physics. You really can't expect to understand much in physics without being able to follow the math.
(Advanced students may recognize that one issue I have in mind here is that we are discussing various approximations and idealizations which are introduced in order to simply the mathematical discussion of various physical effects. And with experience one recognizes that making useful approximations and idealizations are just where the greatest skill is required in physics. One might even say that this is the "physical" part of physics; once appropriate approximations have been made, purely mathematical reasoning comes into play.)
Case in point: at a guess, Cesium is thinking of the "Shapiro light delay effect" in gtr, one of the four classical solar system tests of gtr (one of the others is the "light bending effect").
The trouble is that neither you nor he were careful to note that there are multiple operationally significant notions of "distance in the large" in curved spacetimes, nor that these are in turn distinct from "coordinate speeds". In simple terms, this means that in curved spacetime models, coordinate speeds have no geometric or physical meaning; to obtain a notion of distance in the large and thus speed in the large which has operational significance in the sense that it can be experimentally tested, you need to specify a method of measurement and a method for computing a "distance" from those measurements.
The Shapiro effect is based upon one of the simplest notions of distance in the large, called radar distance, and then one can show that gtr predicts a "time delay" for signals passing near a massive object. This has been tested many times, and so far the gtr prediction has been confirmed by each test.
This does not contradict that fact that the speed of light is constant; you just have to understand what "the speed of light means".
Ditto. You either need to take our word for it (in particular, to take our word for it that we are not contradicting ourselves when we write down a formula for the Shapiro light delay in which the symbol "c" appears), or else master enough math to follow along with a good textbook. I think D'Inverno is a very readable textbook, by the way.
D'Inverno is a bit advanced for where Rocco appears to be at.
The other subtle point to remember is that from a fixed reference point some distance away from the sun does see the light passing very near the sun Slow Down not speed up.
Because relative to that point the local clocks near the sun are running slower.
Radar tests that have proven this experimentally as one of the several proofs for GR you will find.
Let me expand on this a bit:
While it may not answer all of his questions, and glosses over quite a few important points, I'd say that http://www.onestick.com/relativity/ is probably around the right level for Rocco as nearly as I can judge from his posts (which isn't particularly easy to do, but lacking any other input from Rocco one has to do a certain amount of guessing). This web-based multimedia presentation won the Pirelli relativity award "for the best multimedia work that explains special relativity theory to the layperson." It's also extremely basic.
If Rocco (or whomever is curious about relativity and is reading this thread) is willing to put in a little more effort, I'd suggest Bondi's "Relativity and common sense" and/or Taylor & Wheeler's "Spacetime physics". The first chapter of the first edition of the later is available for download from http://www.eftaylor.com/download.html#special_relativity. However, note that it is a college level text (though I'd classify it as one of the easier college level texts, quite suitable for freshman). Downloading the first chapter should give the reader some inducation of whether this book is for him or her.
You're tight, this is at a level I can understand and pretty much already understand but it leaves questions unanswered.
1. What are those "physical laws" that are supposed to give "a definite speed for light" and what do they mean?
2. In regards to the example given of Al's trip to the shop 10 light years away. His mother saw Al rocket away at 99.5% the speed of light then return. 20 years passed for her but only 2 years for Al because he was moving so fast. From Al's perspective the Earth moved away at 99.5% the speed of light then returned? So from his perspective, wouldn't 20 years pass for him and only 2 years for the Earth because it was moving so fast? How do you reconcile their final 2 perspectives?
Also, A few people have mentioned that there have been a number of experiments that prove, definitively, that the speed of light is always a constant. Can anyone describe some of these experiments?
Still trying to clarify confusing and potentially misleading statements
Randall, that doesn't make sense. The Sun "sees" light slow down? No wonder he's confused!
Again, the only way to understand this stuff properly is to
1. Distinguish clearly between small scale effects (e.g. "c", "photon"---or better, laser pulse--- world line is null geodesic) and large scale effects (e.g. "light bending", "light delay"),
2. Distinguish clearly between optical effects and other kinds of measurements, in particular to distinguish clearly between various operationally signficant notions of "distance in the large" and thus "speed in the large",
3. Understand "gravitational red shift" (and also the other effects mentioned here) in terms of the divergence of initially parallel null geodesics due to spacetime curvature.
It is essential to express yourself very carefully, particularly if in deference to the OP's wishes you are avoiding mathematical statements.
RandallB said:
Because relative to that point the local clocks near the sun are running slower. Radar tests that have proven this experimentally as one of the several proofs for GR you will find.
Just to be clear, RandallB is referring here to the same Shapiro light delay effect that I mentioned. The first test of this involved radar signals bounced off one of the Mariner probes. "Local clocks running slower" refers to a comparison of ideal clocks carried by static observers at two different radii in the Schwarzschild exterior vacuum, by radially outgoing light signals whose world lines spread apart, which results in a frequency shift being measured by the receiver, and also the so-called "gravitational time dilation" effect.
Randall, I think you probably know this but you should have mentioned it, since as it stands you left the impression that you were discussing something completely different, even contradictory, which is not the case.
The physical laws that give a definite value to the speed of light are Maxwell's equations. I'm not sure what you are asking when you ask "what they mean"?
Reconciling Al's perspective with the other perspective's takes a slightly more advanced approach than is presented in "Al's relativistic adventure". Al is basically not in anyone single inertial frame - he is in two different inertial frames. During the process of switching frames is where his mother appears to age suddenly. Understanding this requires understanding the relativity of simultaneity, this is one of those fine points that the above multimedia presentation glosses over.
There are many different ways of working through the "twin paradox" from different perspectives, see for instance the sci.physics.faq
http://math.ucr.edu/home/baez/physics/Relativity/SR/TwinParadox/twin_paradox.html
Mathematically the simplest approach is to treat the acceleration process as a sudden "jump" in Al's speed, in which case Al's mother's age appears to also "jump".
A more physical approach has Al gradually accelerate. To use this approach, one needs to be able to able to deal with accelerating frames, however, which is mathematically more challenging. The result may be easier to understand however - Al's mother's aging can then be attributed to the "gravitational field" which exists from Al's "viewpoint".
If you really want precision, though, you'll have to work through something more sophisticated, like Taylor & Wheeler "Spacetime physics", or Bondi's "Relativity and common sense".
Probably the most famous experiment that shows that the speed of light is constant is the Michelson morley experiment.
There have been others, for instance the speed of light (actually gamma ray) emitted from a relativistically moving particle has been measured, and it has been found that this is the same speed as the speed of light emitted from a stationary source, illustrating directly that there is no dependence on the speed of light of the motion of the source.
For a list of some of the experimental tests of SR, see for instance http://math.ucr.edu/home/baez/physics/Relativity/SR/experiments.html. The test I referred to above would be the Alveger experiment.
The only wrong impression I see is your comment about the sun seeing anything slow down, I sure didn’t say that.
The Shapiro light delay is seen “from a fixed reference point some distance away from the sun”. In your example that distant reference frame is earth. Experimentally seeing the light (photons of radar) when passing near the sun as they return to Earth come in at a delay. Because from the earth reference frame when light travels near the sun it slows down causing the delayed return. It is the only way correct local measurements of light speed near the sun could remain at “c”.
Just one of the proofs on GR that should be found by anyone studying it.
Different definitions of "speed" appropriate for different scales
I don't think I can keep this up much longer, but I'll make one more effort.
Rocco, you are asking about how speeds "in the large" (e.g. in the Mariner radar ranging experiment used to test the Shapiro light delay effect) compare with speeds "in the small" (e.g. an idealized laboratory in a spaceship).
Speed is distance divided by time. Most gtr newbies do appreciate (from prior knowledge of str) the fact that in gtr, elapsed time is measured on an ideal clock and refers to Minkowski arc length along the (timelike) world line of the clock. This generalizes without change to curved spacetimes. However, one must also appreciate that there are numerous distinct operationally significant notions of "distance in the large", and thus various distinct operationally significant notions of "speed in the large". This is slurred over by almost all textbooks, and IMO doesn't do students any favors since I see failure to recognize this fundamental fact frequently trips up people posting in forums like this (or even, sad to say, sometimes in the arXiv).
When you see "speed of light = c, a fundamental physical constant", this refers to "speed in the small", i.e. on length and time scales so small that curvature effects are not noticeable.
I am not sure what you mean by experiments which "prove" that c is always a constant. As a rule, it would be more correct to say (following the somewhat naive Baconian model of science) that experiments can either disprove theoretical predictions, or fail to disprove them.
I think you mean that theories such as Maxwell's theory of EM predict the existence of a definite speed of propagation of EM waves in a vacuum, and relate this speed c to some other physical constants. These can be measured and the results fail to disprove Maxwell's theory. This theory is inconsistent with Galilei kinematics, although this wasn't noticed at first, but rather implies Einstein's kinematics, aka str. So the same experiments fail to disprove str, which is theoretically more or less inseperable from Maxwell's theory. Then str is incorporated (at the level of tangent spaces) into gtr with no change. Gtr makes more predictions and to date experiments have failed to disprove them.
Rocco, I can see this all going over you head, and I regret this. If I could "water it down" more I would. I did say that it is not possible to understand subtleties (and not much in Nature is truly unsubtle) without recourse to mathematics! Nonetheless I suspect the points I am trying to make can be made in a nontechnical way, at least if illustrations were possible. At the moment I seem to lack inspiration to attempt to do that and I apologize for that.
Your choice of words in your post # 20 was ambiguous, and I have been urging everyone to make the greatest possible effort to avoid ambiguities.
I concede however that I too have probably played a role in confusing Rocco, although that was not my intent (or yours).
You just said "seen" again when you should have said "measured". It is not so easy to explain relativistic kinematics to newbies, but if said newbies have encountered descriptions of optical effects (e.g. optical appearance of the night sky to an observer riding a relativistically accelerating rocket), using "sees" can be ambiguous. Or maybe I'm just trying too hard... :rolleyes:
Rocco, since Randall insists upon such a different description of the intuition for Shapiro light delay than the description I prefer, I guess you'll have to take my word for it that he and I really are talking about exactly the same thing, described using exactly the same mathematical reasoning, giving exactly the same quantitative predictions in a given experimental setup, and confirmed by exactly the same experiments (in the sense that these experiments fail to disprove the predicted effect)! :wink: If you remember nothing else about the posts by myself and Randall I hope you'll remember that.
Expanding Pervect's answer above - Maxwells' equations. Maxwell's unification of the electric and magnetic fields predicts waves, whose speed is given by
[tex]c = \frac{1}{\sqrt{\mu_0 \epsilon_0}}[/tex]
Now, [tex]\mu_0[/tex] and [tex]\epsilon_0[/tex] are two numbers which are thought to be unchanging universal values. They refer to properties of the 'vacuum' and there is simply no reason to expect them to change for a given observer, from place to place.
Again, it has been stated above, special relativity is overwhelmingly supported by experiment and observation. The central tenet of SRT is that all inertial observers will measure the same speed of light in their labs.
Scales, scales, scales!
Rocco, I stress again that in their labs refers to the small scales of length and time mentioned above. How small? Or IOW, how large can a "lab" be? It can't be so large that curvature effects become measureable.
I hope it is clear that Mentz, Randall and I are actually in agreement about the physics (but maybe not entirely about how to try to convey the physics without using math)...
Thanks for all your help guys. You have gone a long way to convincing me.
One thing that is obvious is that I need to hit the books if I truly want to be convinced. A few books have been mentined. I'll have to look into them and see if I'm able to raise my understanding enough to convince myself. :)
Again thanks. Rocco.
1. What is the purpose of a deflection of light test?
The purpose of a deflection of light test is to measure the bending of light as it passes through a medium, such as a lens or prism. This can help scientists understand the properties of the medium and how it affects the path of light.
2. How is a deflection of light test performed?
A deflection of light test is typically performed by shining a beam of light through a medium and observing the angle at which the light is bent. This can be done using specialized equipment, such as a spectrometer, or by using everyday objects like a glass of water.
3. What factors can affect the results of a deflection of light test?
Several factors can affect the results of a deflection of light test, including the properties of the medium, the angle at which the light enters the medium, and the wavelength of the light. Other factors, such as temperature and pressure, can also play a role in the deflection of light.
4. Why is the deflection of light important in scientific research?
The deflection of light is important in scientific research because it can provide valuable information about the properties of a medium. It is also a fundamental aspect of optics and is used in various fields such as astronomy, physics, and engineering.
5. How does the deflection of light relate to the theory of relativity?
The deflection of light is a key concept in the theory of relativity, specifically in the general theory of relativity. According to this theory, the path of light can be affected by the presence of massive objects, such as planets or stars, causing it to bend. This phenomenon has been observed and confirmed through experiments, providing evidence for the validity of the theory.
