| New Reply |
Em wave incident on a surface current |
Share Thread |
| Nov17-12, 10:29 AM | #1 |
Consider an infinite sheet of surface current described by the surface current density , K=dI/dl, where dl is a length element perpendicular to the current.
For this sheet, the magnetic field B=μK/2, above and below the sheet, independent of the distance from the sheet, where μ is for free free space. The dirction of B is parallel to the sheet and perpendicular to the current flow. Now if a plane em wave approaches such a surface, does the B vector of the em wave always satisfy the above equation, independent of seperation from the sheet? I doubt so, since the magnitude of the B vector of the em wave depends on the source of the wave. But if B vector of em wave doesnt satisfy the eq. B=μK/2, then B has values different from this value, above and below the sheet, which would be inconsistent with the amperes law, using which B=μK/2 has been derived for the sheet in the first place. Where am i going wrong ?? |
| New Reply |
Similar Threads for: Em wave incident on a surface current
| Thread | Forum | Replies | ||
| Incident Solar radiation on an inclined surface | Engineering, Comp Sci, & Technology Homework | 2 | ||
| Is Snell's Law valid even when incident ray is Normal to the surface? | Classical Physics | 3 | ||
| Radiation perpendicularly incident to a surface | Advanced Physics Homework | 1 | ||
| Laser Incident to Surface Perpendicularly | Classical Physics | 5 | ||
| Questions on electrons incident on a metal surface | Advanced Physics Homework | 0 | ||
