Derivation of Time Dilation and Length Contraction from Lorentz Transformation
In summary, the Time Dilation and Length Contraction Formulas can be derived from the Lorentz Transformation Equations by understanding the concepts of PROPER TIME INTERVAL and PROPER LENGTH.
mahapan
Hello there, a simple special relativity question, how can the Time Dilation and Length Contraction Formulas be derived from the Lorentz Transformation Equations?
Derive them for yourself. Here are a few hints:
(1) For time dilation, consider a moving clock. Pick two events recorded by that clock: Δx' = 0.
(2) For length contraction, consider a moving stick. Measure the distance between the ends of that stick at the same time: Δt = 0.
I'm not sure doc al's suggestion is realistic for most. yet not impossible either...
The people who derive such original insights have usually been immersed in the work full time and spent a lot of time thinking about the issues...and made many,many errors before successfully creating new insights.
As an example, I have read a little about Einstein's initial work on relativity...studying frames of reference and Newton's views as he decided on a framework to develop his own work...He also used Lorentz and Fitzgerald and Riemann's curved geometric insights...In developing relativity, today's physicsts have been able to review Einsteins original notes and in light of what we know today, his many errors are apparently very obvious...but were not to Einstein! He just refused to give up, retraced his steps repeatedly until he discovered where he had gone off course, corrected himself and proceeded again to make more erros...eventually he got there!
The Lorentz transformation in units such that c=1 is
[tex]\gamma\begin{pmatrix}1 & -v\\ -v & 1\end{pmatrix}[/tex]
where [itex]\gamma=1/\sqrt{1-v^2}[/itex]. Try applying this to the points with coordinates
[tex]\begin{pmatrix}T\\0\end{pmatrix}[/tex]
and
[tex]\begin{pmatrix}0\\L\end{pmatrix}[/tex]
Actually, given the hints and the fact that we know the answer that we're looking for, it should be relatively easy. After all, you're starting with the Lorentz transformations already known. (And in case you can't find them, here they are: https://www.physicsforums.com/showpost.php?p=905669&postcount=3")
I think that it is worth to know that the Lorentz transformations could be derived from length contraction and time dilation.
I would certainly agree, and that's exactly what's done in many elementary treatments of SR. (After first deriving length contraction, time dilation, and clock desynchronization from the more basic assumptions of SR via simple thought experiments.)
But that's not what was asked for here.
Make shure that you have a good understanding of the concepts of PROPER TIME INTERVAL
and PROPER LENGTH.
Present the Lorentz transformations as
dx=g[dx'+Vdt'] (1)
dt=g[dt'+Vdx'/cc] (2)
If dx'=0, the wrist watch of the observer at rest in I' measures a proper time interval dt(0), observers from I measure a coordinate time interval dt related by the time dilation formula
dt=gdt(0) as results from (1). Knowing the conditions under which proper length is measured you obtain from (1) the formula that acconts for length contraction.
1. What is the Lorentz Transformation and how does it relate to time dilation and length contraction?
The Lorentz Transformation is a mathematical formula used in special relativity to describe how measurements of time and space are affected by the movement of objects at high speeds. It is derived from Einstein's theory of special relativity and is used to explain the concept of time dilation and length contraction.
2. What is time dilation and how does it occur?
Time dilation is the phenomenon in which time appears to pass slower for an object in motion relative to an observer. This occurs because the speed of light is constant and absolute, so time must adjust in order for the laws of physics to remain consistent. Essentially, the faster an object moves, the slower time moves for that object.
3. How is length contraction related to time dilation?
Length contraction is the counterpart to time dilation, meaning that as time appears to slow down for an object in motion, its length appears to decrease in the direction of motion. This is due to the fact that an object's velocity through space and time are interconnected, and as one changes, so does the other.
4. What is the formula for calculating time dilation and length contraction?
The formula for time dilation is t = t0/√(1 - v2/c2), where t is the time measured by an observer, t0 is the time measured by an object in motion, v is the velocity of the object, and c is the speed of light. The formula for length contraction is l = l0√(1 - v2/c2), where l is the length measured by an observer, l0 is the length measured by an object in motion, v is the velocity of the object, and c is the speed of light.
5. What are some real-life examples of time dilation and length contraction?
One famous example of time dilation is the "twin paradox," in which one twin travels into space at high speeds and returns home to find that they have aged much slower than their twin who stayed on Earth. This is due to the difference in their velocities and the resulting time dilation. Another example is the use of atomic clocks on GPS satellites, which must account for time dilation in order to accurately measure distances on Earth. As for length contraction, a common example is the apparent shortening of a train when viewed from a stationary platform as it passes by at high speeds. This is due to the train's velocity causing length contraction in the direction of motion.
