Absorption of photons with less energy than the band gap
In summary, the conversation discusses the absorption of photons in semiconductor materials, specifically in silicon. The speaker expected the absorption to drop off at lower than the band gap energy, but this was not the case. Possible explanations for this include dopants in the material, phonon-assisted absorption, and excitonic effects. The conversation also mentions the limitations of experiments and the role of temperature and multiphoton processes in absorption.
Lambduh
69
Hi guys i have a question about how semiconductor materials absorb photons at less than the band gap energy. Particularly in an indirect material like silicon.
Looking at absorption spectra for silicon i expected for it to immediately drop off at lower than the band gap energy ~1100 nm (1.12 eV) but it definitely does not from the graphs that I've seen. Is this something to do with phonon assisted absorption (even then there doesn't seem to be enough energy, or momentum, to get absorbed? It just seems to me that for any photon with energy less than the bandgap the material should be transparent. Is this due to "traps" or some defects in the material? Thanks!
Mark
Likes Lotanna Ezeonu
Dopants have levels in the gap. Another way is the phonon assist mechanism.
There are also excitonic effects, where the created electron and hole are in a bound state, ala a hydrogen atom; that might not be very strong in silicon though. At the end of the day, remember that all experiments are limited in resolution, and reality is always smooth, never any sharp jumps.
Even without the assist, there could be absorption "into" the phonon spectrum.
1. If temperature >0 then there are electrons in the conductunce band, so they may absorb photons in greate number.
2. Laser photons are permitted be absorbed by electrons even at T=0 with multiphoton processes.
3. Of course nobody can neglect phonons.
1. What is the band gap?
The band gap is the energy difference between the highest occupied energy level (valence band) and the lowest unoccupied energy level (conduction band) in a material.
2. Can photons with less energy than the band gap be absorbed by a material?
Yes, photons with less energy than the band gap can still be absorbed by a material. However, the absorption process will be less efficient compared to when the photon energy matches or exceeds the band gap energy.
3. How does the absorption of photons with less energy than the band gap affect the material?
When a material absorbs photons with less energy than the band gap, the energy of the photon is used to excite electrons from the valence band to the conduction band. This can lead to the creation of electron-hole pairs and changes in the material's electrical and optical properties.
4. What happens to the excess energy of the absorbed photons with less energy than the band gap?
The excess energy of the absorbed photons is usually dissipated in the form of heat. This is because the energy of the absorbed photon is not enough to promote an electron to the conduction band, so it is converted to thermal energy instead.
5. How does the band gap affect the colors of a material?
The band gap of a material determines the range of photon energies that can be absorbed, and therefore, the colors that the material can absorb and reflect. Materials with smaller band gaps will absorb lower energy photons, leading to the appearance of longer wavelengths (such as red) in their color, while materials with larger band gaps will absorb higher energy photons and appear to have shorter wavelengths (such as blue).
  • Atomic and Condensed Matter
