Overnight everything has doubled in size.
  • Thread starter Willowz
In summary, the thought experiment cannot be put to test because it is based on assumptions that may not be true.
Willowz
197
Do you know where this 'thought experiment' that cannot be put to test originated from? Was it Bertrand Russell?
I'm reading the only other thread that is similar to this one. You might find this interesting.
This is a quote from another thread.
DaleSpam said:
If all of the universal lengths changed in such a way that none of the dimensionless constants were changed, then the change would not be measurable.
And this is from wiki;
At the present time, the values of the dimensionless physical constants cannot be calculated; they are determined only by physical measurement. This is one of the unsolved problems of physics.
*scratching head*
On what basis can physicists suppose that there are dimensionless constants if they can only be calculated by physical measurement?
Scale is always comparative, it's a definition thing. It's not testable since there is nothing to test.
If matter doubled in size and space did not, then the effect would be similar to gravity in a way given that the space between two small objects would decrease slower than the space between two larger objects. More volume, more "gravity". :)
In this model a balloon and a metal sphere with the same volume, would have similar "gravitational" attraction. Curious isn't it? :)
A dimensionless constant would be a ratio of dimensionfull constants that are measureable. Lengths can't be doubled without any other change occurring concurently and those other changes would be noticable. For instance, gravitational force is given by:
[tex]F_g = G\frac{m_1m_2}{r^2}[/tex]
where r cannot be the only thing in the equation that changes.
Is it actually meaningful to say that all lengths doubled (and everything else to make it all fit in whatever way) if this lead to no observable difference in the world? We are more used to the idea now that everything is relative- in what respect can we say that this is actually a concept which makes sense? What's important is the relations between different things- time and space, for example.
We could, for example, declare tomorrow that all lengths are now doubled. We'd have to half the speed of light and so on, but nothing actually happened except changing our name for things.
Everything doubled in size compared to what? Does your question have meaning?
John Passmore. [http://test.philpapers.org/rec/PASEHJ" ] Or at least, he discussed it being untestable in 1965.
Imagine a cube (2*2*2) of material density M supported on a 1*1 cross section pillar the force on the pillar is 8M/1.
If all dimensions doubled you would now have 64M/4 or 16M/1 you've doubled the loading on the pillar; that is why elephants have thick legs in relation to their body size and deer have thin ones.
Yes, but we are assuming that all the other constants change accordingly. Obviously if this was not the case then things would be noticeably different (just think about the orbits of planets).
My question would be- what is the difference between this and us just renaming all of our lengths? I don't think that it is possible to come up with such a difference.
You can always make a dimensionless constant by taking some dimensionful constants and combining them so that the units cancel. So the existence of dimensionless constants is not in doubt. Dimensionless constants are important because their value does not depend on your choice of units.
Here is a good page on the fundamental dimensionless constants:
http://math.ucr.edu/home/baez/constants.html
And here are a couple of posts explaining the "everything doubled" idea:
https://www.physicsforums.com/showpost.php?p=2011753&postcount=55
https://www.physicsforums.com/showpost.php?p=2015734&postcount=68
The original question just asked if everything doubled in size whether we could observe a difference, I think that the answer to that is yes we could by structures falling down as their mass cubed but supporting framework only squared. Even if you push a bit further and alter the density and strength of materials so that everything stays upright I think that things like the way waves break on a shore and ripples propagate would change (if you look at films with scale models of nautical disasters the sea always looks a bit wrong), all down to Reynolds number. If you want to push things to the limit and modify the laws of physics so that everything acts the way it did before you doubled it's size, I suppose that then you couldn't see a difference but what would be the point of the question?
The point is that that question, as stated, is incompletely specified. There are multiple ways that everything could double in size, some would be observable and some would not. The way to determine if a difference is observable or not is to determine if there is a change in any of the dimensionless fundamental constants.
Jobrag, I assumed that everything else was changed to make sure that no difference could be perceived by the inhabitants of the universe in question. We are in the philosophy thread. There are an infinitude of reasons why we'd notice a difference if simply all lengths were doubled in size...
Not necessarily.
If everything doubled in size and this could not be measured in principle, the undeniable conclusion is that size is not meaningful in an absolute sense in the first place. It falls out of the equations.
This 'thought experiment' shows one. All of the constants on the 3 ratios below can be regarded as time or distance (based on the distance traveled by light in the time). Mass is not part of any ratio used in this 'thought experiment'.
If I started photographing a light around 6 and a bit feet away, and the light was being spun in a circle 2 feet in diameter and I captured the light from the spinning light in one complete circle the ratio (A) of the time between the rotating source and the observer over the diameter of rotation would be roughly equal to Pi.
In this case the ratio (B) of the actual distance between source and observer over the distance traveled by light in a year would be very small and the ratio (C) of the observation period over the time it takes for the light to be rotated once will equal one. All observations should have a width of field that covers the complete diameter of rotation of the source being observed.
If I halve the exposure period I get half a circle and capture half as much light and when I double the exposure period I get 2 circles over each other and twice as much light in my photograph. If the light is rotated twice as fast I would expect something that looked similar to when I doubled the exposure period but I would also expect to capture the same amount of light from only one rotation despite the doubling of the speed of rotation. If I put two lights together I could halve the exposure time and double the speed of rotation to capture a similar amount of light from 1 light doing 1 complete rotation. If the light moved at an angle to me I would observe an oval instead of a circle but the amount of light captured would remain the same as in a complete circle.
In this simplest base context A = Pi, B = tiny, C = 1 and the observer will capture one complete cycle. On any scale where C >= 1 the observer will capture at least one complete cycle despite the size of B.
On any scale where A = Pi * x, B >= 1 and C < 1 the observer will only capture the light from B * C = x of one rotation during any observation regardless of the speed of rotation of the same object.
On a galactic year scale where A = Pi * x, B = 230 million and C = 1/230 million you would expect to capture the light from B * C = x rotations or roughly one rotation regardless of the speed of rotation.
On a galactic year scale where A = Pi * x, B = 4.2 billion and C = 1/4.2 billion you would expect to capture the light from B * C = x rotations or roughly one rotation.
Only changes in brightness can really make a difference on any scale as the speed of rotation does not change the total amount of light captured from the same source during any similar observation period. I have used figures for convenience, put your own figures in and keep ratio A as Pi * x and you will have a base point to compare observations.
This 'thought experiment' illustrates a common ratio that allows for a perceived mass and size variation from double, as per this threads title, to parity and one half. While it would be impossible to calculate the galactic years of every observed rotating source in the universe it would be logical to say that the difference in the sum of the perceived universal mass calculated from optical observations verses the perceived universal mass calculated from x ray observations is equal to the average of the number of galactic year rotations of each discrete source captured in your visible data sets.
What could cause everything to double in size overnight?
There are a few possible explanations for this phenomenon. One possibility is that there was a sudden and significant increase in temperature, causing materials to expand. Another possibility is that there was a sudden influx of air or gas, causing objects to inflate. It is also possible that there was a chemical reaction or growth process that occurred rapidly, leading to an increase in size.
Is it possible for living organisms to double in size overnight?
No, it is not possible for living organisms to double in size overnight. Organisms have a set rate of growth and require specific conditions to grow and develop. While some may experience rapid growth, it is not possible for them to double in size in such a short period of time.
Could this be a result of a natural or man-made disaster?
Yes, it is possible for a natural or man-made disaster to cause objects to double in size overnight. For example, a volcanic eruption or earthquake could cause the ground to shift and materials to expand. Additionally, a chemical spill or explosion could lead to sudden growth or inflation of objects.
How can this sudden increase in size be measured and studied?
Scientists can use various methods, such as measuring tools or imaging techniques, to accurately measure and study the change in size. They may also conduct experiments to replicate the conditions that caused the growth and gather data to analyze and understand the process.
Is there any potential danger or harm associated with objects doubling in size overnight?
It depends on the specific circumstances and objects involved. In some cases, such as with living organisms or structures, rapid growth could lead to instability and potential harm. In other cases, it may simply be a natural occurrence with no negative consequences. It is important for scientists to study and understand the cause of the growth to determine any potential risks or dangers.
  • General Discussion
  • Electrical Engineering
  • Quantum Physics
