Thread Closed
Clocks On The Space Shuttle
Share Thread Thread Tools
Feb1-04, 05:34 AM   #1
I just read that the clocks on board the space shuttle go more slowly than the clocks on earth.
does that mean time has speeded up for those on the shutte or slowed down ?
i reckon it means time has slowed down. if they stayed up for a year by their clocks then by our clocks more than a year will have passed.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Feb1-04, 06:19 AM   #2
Is this a question, or statment?
Feb1-04, 10:50 AM   #3
it was a question as I am really not sure.
Feb1-04, 07:35 PM   #4
So maybe you would want to type in the words "time dilation" into the search feature, (in these forums) look in titles, or threads, and you will find some 'stuff' to help you start building knowledge towards understanding the how and why of that...stuff.... O.K.?
Feb1-04, 08:18 PM   #5
Mentor
The speed of the space shuttle causes the clocks to slow down relative to a clock on earh. The altitude (reduced gravitational force) causes the clocks to speed up. The net effec is that the clocks (time) go faster in space than on earth.
Feb1-04, 08:37 PM   #6
And hence the relativisation of light's speed(?)
Feb2-04, 12:02 PM   #7
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Mr. Robin Parsons - Your second post was uncalled for. There was nothing wrong with the question. Yes, sam1967 could have used the search feature to find some similar topic...but give a new member a break. I'd rather see repeated discussions than rude responses.
Feb2-04, 06:50 PM   #8
no, the relativisation of time
Feb2-04, 07:10 PM   #9
O.K. but I was trying something trying to see if I could help, the rude part, is, perhaps, not as much there, as you might think...But I would apologise to sam1967 if they were, what? "off-ended" by my, well, thought....Sorry sam1967, didn't intend, or mean to be 'rude' just wondered if newbies even looked in the search features, they are rich... My Opinion... [a)]
Feb3-04, 01:07 PM   #10
Recognitions:
thanks [:))]
Feb4-04, 06:21 AM   #11
[a)] No Problemo [a)]
Aug3-11, 08:11 AM   #12
You might be incorrect, the clocks on the shuttle are not your wind up clocks next to your bed.
They are digital and atomically. gravity does not effect the mechanics of the clock because there are no gears, weights,springs in it.
Aug3-11, 08:30 AM   #13
Recognitions:
You noticed, didn't you, that this thread was 7 years old?
Jun27-12, 08:27 AM   #14
Lol. Space time even exists in forums.
Jun27-12, 01:55 PM   #15
Recognitions:
Quote by just board View Post
To observers on the shuttle, the clocks are running at their usual rate, irrespective of whether they are mechanical or digital. However, according to russ waters, to observers on the earth's surface, the clocks on the shuttle are running faster than their own, and it is earth surface clocks that are running at the usual rate.
Jun27-12, 02:17 PM   #16
Recognitions:
Quote by Chestermiller View Post
I don't think russ's statement was correct for the Space Shuttle. It is correct for satellites in high orbits, such as the GPS satellites, where the effect of altitude (speeding up clocks relative to those on the Earth's surface) outweighs the effect of orbital velocity (slowing down clocks relative to those on the Earth's surface). For satellites in low Earth orbit, such as the Shuttle, the velocity effect outweighs the altitude effect.
An approximate equation for the rate of time flow for an object in Earth's gravity field is
[tex]\frac{d\tau}{dt} = \sqrt{1 - \frac{2 G M}{c^{2} r} - \frac{v^{2}}{c^{2}}}[/tex]
For an object on Earth's surface, we can eliminate the v^2 term by using the poles as a reference; since the Earth's surface is (approximately) an equipotential surface, clocks on the surface all go at the same rate, and the rate at the poles is the easiest to calculate. The polar radius of the Earth is 6.36 x 10^6 meters according to Wikipedia. G is 6.67 x 10^-11, and M for the Earth is 5.97 x 10^24 kg. This gives a result of [itex]d\tau / dt = 1 - 6.97 * 10^{-10}[/itex].
For objects in orbit, since v^2 = GM/r for an object in a free-fall circular orbit (which we'll assume is a good enough approximation for this problem), we can rewrite the above more simply as
[tex]\frac{d\tau}{dt} = \sqrt{1 - \frac{3G M}{c^{2} r}}[/tex]
For the Space Shuttle, r is about 200 miles, or 3.2 x 10^5 m, above the Earth's surface. For the GPS satellites, r is about 4.2 Earth radii. The corresponding numbers are:
Shuttle: [itex]d\tau / dt = 1 - 9.95* 10^{-10}[/itex], which is slower than ground clocks by about 3 parts in 10^-10.
GPS satellite: [itex]d\tau / dt = 1 - 2.49 * 10^{-10}[/itex], which is faster than ground clocks by about 4.5 parts in 10^-10.
Jun27-12, 02:34 PM   #17
D H
Mentor
Quote by HallsofIvy View Post
And now it is over 8 years old.
Thread locked.
Thread Closed
Thread Tools
Similar Threads for: Clocks On The Space Shuttle
Thread Forum Replies
Space Shuttle going up again General Discussion 78
Space shuttle Mechanical Engineering 7
Space Shuttle Problem Introductory Physics Homework 12
End of the Space Shuttle? Mechanical Engineering 1
Space Shuttle Question Introductory Physics Homework 1
