Electric circuit with negative reference voltages and diodes
In summary, you should assume D2 is not conducting when trying to figure out the voltages for nodes Va and Vb. If D2 is on, then Va > Vb.
  • #36
va would equal 5-VR1 the voltage drop across R1 would be the current * R1. OH! VR1 would be the current induced by both the -10 draw and the +5 push. therefore the total current in the left side would be 5+10-.7 =14.3V/R1+R2 = 1.43mA
VR1 = 1.43mA*R1 = 7.15 V
and Va = 5-7.15V = -2.15V is this right?
  • #37
It is. So in conclusion...?
  • #38
In conclusion D2 is in fact off. Thank you very much. I got very confused with the negative potentials. But I realize now that they cannot make the potential at any point higher than the original potential.
  • #39
The important thing is that you got there in the end :smile:
  • #40
good work ... sounds like you learned something worth learning
  • #41
Thank you both very much for your help. I didn't think I would ever see the light at the end of the tunnel. Thanks again
