New Reply
ANSYS-Steel beyond yield point -Engineering strain or true strain for Plastic strain
Share Thread Thread Tools
Dec2-12, 05:50 PM   #1
I am trying to do a problem on Material Non-linearity , to model steel for large deformation , beyond yield point ,
I have tensile testing data for the steel ( in form of Engineering stress vs Engineering strain).
for defining the model , I chose Multilinear Isotropic hardening
now there are 2 options
stress vs total strain & stress vs Plastic strain
Which option should I choose ( I was asked to choose Stress vs Plastic strain )
Also , what values should I use ? Engineering stress , Engineering Plastic strain (engineering strain - engineering stress/youngs modulus ) ;
or True stress and true strain values ( I know how to calculate them )
can any one clarify?
Also , to make it clear , I am trying to simulate a 4 point bending test , I know how to do contact analysis etc , I am only confused about the material modelling part
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Dec26-12, 06:45 AM   #2
Sir, since you are concerned with the field of material science, may I ask a question in that regards??
I wanted to know why are there two yield points in a stress strain curve ?
Dec26-12, 07:16 AM   #3
The difference between engineering strain and true strain only becomes significant when phenomena such as tensile necking occur.
In normal engineering structures plastic analyis is conducted as a transition from linear-elastic to full plastic and the resulting stress block deduced, often as the formation of a plastic hinge. In this type of analysis the strain remains small and limited by elastic engineering considerations.
Dec26-12, 08:26 AM   #4
thnksss.....but i was asking about the upper and lower yield points....the case of true engineeriing stress-strain curve and normal stress-strain curve arises only after the ultimate failure stage...
can you tell something regarding the reason as to why there are two yield points, upper and lower??
New Reply
Tags
ansys, plastic deformation, plastic strain, true strain
Thread Tools
Similar Threads for: ANSYS-Steel beyond yield point -Engineering strain or true strain for Plastic strain
Thread Forum Replies
True Stress-Strain Curve on the Log Scale: Which portion is the plastic region? Mechanical Engineering 3
Getting stress-strain data using the 'strain hardening exponent'. Mechanical Engineering 0
Where to place strain gauges to measure shear strain on a continuous supported beam Mechanical Engineering 0
strain, thermal strain and agle of twist Engineering, Comp Sci, & Technology Homework 0
what's the physical meaning of true shear strain and simple shear strain Atomic, Solid State, Comp. Physics 2
