| New Reply |
Is there any other place I could get this RAM? |
Share Thread |
| Feb8-13, 03:12 AM | #1 |
Newegg is currently out of stock and they don't have it anywhere on tigerdirect. It could be months before they have them back in stock.
I'm building a new PC and I have the MSI big bang mpower Z77 motherboard. I read that this memory kit was designed specifically for my mobo. Is there any other place where I can order this particular memory kit online? It must be from a trusted and reputable website. http://www.newegg.com/Product/Produc...9SIA0ST0DV4427 |
| Feb8-13, 10:02 AM | #2 |
Recognitions:
http://www.crucial.com/store/drammemory.aspx Either click "scan my system" (and give it permission for messages about downliading software), or select from the lst if you know EXACTLY what make of mobo you have - when you get to the bottom of several layers of submenus, there is a long list of "MSI Z77" boards. |
| Feb8-13, 11:37 AM | #3 |
If you don't want to wait for the RAM to be back in stock again, here's what I would do. Get different branded RAM. Here's the specs on your preferred ram Size: 4x4GB Speed: DDR3 2133 (PC3 17000) Timings: 9-11-10-27 Voltage: 1.65 Here's the ram I would get if i was in your shoes. http://www.newegg.com/Product/Produc...82E16820231563 or http://www.newegg.com/Product/Produc...82E16820231503 Size: 4x4GB Speed: DDR3 2133 (PC3 17000) Timings: 9-11-10-28 Voltage: 1.65 They are essentially identical, the only difference is 1 clock cycle in tRAS and a bit of difference in packaging. Performance wise, if you're modeling a complex system that will take weeks or months to run, yeah, you might notice some time saving but if you're building a gaming system, you won't be able to tell a difference. And this is all only relevant if you're overclocking your system and running at those specified speeds and timing. Your memory won't run at 2133MHz by default. If you don't overclock your system, it will run at the standard DDR3 speed (1333MHz) in which case you're really just wasting money buying expensive ram and not using it for what its meant. So if you're not overclocking: for 16GB of ram http://www.newegg.com/Product/Produc...82E16820233190 I have 8GB which is plenty for what i do (gaming mostly) http://www.newegg.com/Product/Produc...82E16820145261 Hope you find this helpful |
| Feb8-13, 06:21 PM | #4 |
| Feb9-13, 06:21 AM | #5 |
This ram looks better than the one you were originally looking for from AVEXIR.
It has the same timings but is rated for 1.5v so it should run cooler. Just keep in mind that if you are not overclocking, then your $130 ram will have the same performance as $50 ram. but yeah, corsair makes great ram and this should work just fine on your mobo |
| Feb10-13, 12:00 AM | #6 |
16GB is overkill for gaming, am I correct? http://www.newegg.com/Product/Produc...82E16820233285 |
| Feb10-13, 03:40 AM | #7 |
I would get 8GB now and see how the system performs and then if needed get another 8GB down the line. The larger the RAM, greater the amount of data windows will load into its prefetch making the system run faster. But if you already have a solid state drive in your build, then you will have a hard time seeing the difference between 8GB and 16GB of ram because the drive will load stuff so much faster anyway. |
| Feb10-13, 09:58 PM | #8 |
| Feb10-13, 10:42 PM | #9 |
Ebay is always an option, they usually have a wide selection of ram. But take care to ensure the specs are compatible with your MB
| Feb11-13, 12:07 AM | #10 |
| Feb11-13, 01:01 PM | #11 |
yes they are compatable
msi website says DDR3 Memory 1066/1333/1600/1866*/2000*/2133*(OC), 2200*/2400*/2600*/2667*/2800*/3000*(OC, 22nm CPU required) Newegg for the ram says Type 240-Pin DDR3 SDRAM Speed DDR3 2133 they will work just fine |
| Feb13-13, 02:16 AM | #12 |
Yes, that ram will work, but, why not 2400 instead of 2133?
| New Reply |
Similar discussions for: Is there any other place I could get this RAM?
| Thread | Forum | Replies | ||
| Complaint bad place for an ad | Forum Feedback & Announcements | 10 | ||
| Does Fine Structure Constant Vary From Place to Place? | Astrophysics | 13 | ||
| how big is your place? | General Discussion | 27 | ||
| am i in the right place??? | Introductory Physics Homework | 2 | ||
