Can Microwaves Fuse Metal Particles on a Plastic Substrate?
In summary: Hi Berkeman.I am looking for a way to create a copper path on a plastic substrate using microwaves. I have read that microwaves bounce off metal, is this a property of all microwave frequencies and wavelengths or can I tune my magnetron to the resonant frequency of copper atoms?In summary, the answer to this question is that you can't tune your magnetron to the resonant frequency of copper atoms, but you can use microwaves to bounce off metal.
taylaron
Greetings!
I'm interested in depositing a Line of fine copper powder on a plastic substrate. Due to Limitations of my situation, I want to explore the possibility of using tuned microwaves to fuse the copper particles to form a continuous conductive path. I'm aware microwaves bounce off metal. Is this a property of all microwave frequencies and Wavelengths or can I tune my magnetron to the resonant frequency of copper atoms like existing microwaves vibrate Hydrogen atoms in Water at their resonant frequency to heat the object?
Thanks,
Science news on Phys.org
taylaron said:
Greetings!
Thanks,
There are other ways to put down a copper line on a plastic substrate. Using microwaves and high power to do it seems a bit dangerous and overkill. Have you considered alternate ways to accomplish your goal? Can you say a bit more about your project?
Hi Berkeman. In short, I'm exploring possible methods of creating traces for 3D printable circuit boards. I tried to focus my question because 3D printed PCB's could consume a whole website, let alone a thread. It's out of the scope of this thread...
Conductive ink or filament for FDM printing is very expensive, so I'm trying to avoid it. I've explored alternatives such as using a roller to apply copper wire or ribbon (at room temp), but the intricacies and points of failure are very numerous in addition to simple limitations.
If I printed a layer of ABS plastic with recesses wherever there are copper traces and then fill those recesses with copper powder. Because the layer doesn't need to be that thick, it should quickly fuse under exposure to microwaves. ABS plastic doesn't fare well under microwaves, so I'm hoping the ABS won't get too hot or burn before the copper fuses.
-Tay
Hope is not a plan.
Does the plastic have to be ABS? Do you absolutely need copper for the conductor? What about using solder? You realize, of course, that solder has a lower M.P. than copper? How about conductive ABS filament?
https://www.amazon.com/dp/B00AF2L0W0/?tag=pfamazon01-20
Problem is that you are dealing with a good conductor and a good insulator, neither of which will absorb EM well. Is there not some approach involving electrolytic deposition I.e. using some Chemistry to help you?
Sounds a really attractive goal, though. The Philosopher's Stone, almost.
-Tay
Have you looked at PCB Milling Machines? I've used them in the past for prototypes in our R&D Lab, and they work pretty well for simple 2-layer PCBs:
http://www.lpkfusa.com/pcb/?gclid=CLGZlpmturkCFYZ_Qgod1DgAdg
:smile:
How about this:
A wire traces are formed out of copper powder on top of an ABS 3D printed part. The entire part (ABS & copper) are then exposed to an inductive heater which will only heat the copper because ABS is not conductive. After a short time when the ABS powder has fused into a continuous trace, the inductive heater is switched to 180 degrees out of phase (still exposed to the ABS and Copper) and the part is then cooled* using induction.
After heating something can I take the heater 180 degrees out of phase and cool it? The vibrating molecules would still be vibrating in the orientation of the propagating EM waves, so taking the EM waves 180 out of phase should return the part to it's original temperature, correct?
-Tay
You cannot cool by antiphase excitation because the heating is due to quadrature (lossy) components. It cannot operate like laser cooling. If this system.worked, they'd have fridges based on it.
1. How does fusing metal with microwaves work?
Fusing metal with microwaves involves using high frequency electromagnetic waves to excite the atoms in the metal, causing them to vibrate and generate heat. This heat melts the metal and allows it to fuse together.
2. What types of metals can be fused with microwaves?
Most conductive metals can be fused with microwaves, including aluminum, copper, gold, silver, and steel. However, some metals may not fuse as easily or consistently due to their composition or shape.
3. Is fusing metal with microwaves safe?
When done correctly and with proper safety precautions, fusing metal with microwaves is generally safe. However, it is important to use appropriate protective gear and follow all safety guidelines to avoid any potential hazards.
4. What are the advantages of fusing metal with microwaves?
Fusing metal with microwaves can be faster, more precise, and more energy-efficient compared to traditional methods. It also allows for the fusion of metals with different melting points and can create stronger bonds between metals.
5. Can microwaves be used for other metalworking processes?
Yes, microwaves can also be used for other metalworking processes such as welding, sintering, and brazing. However, the specific technique and equipment used may vary depending on the desired result.
  • DIY Projects
  • STEM Academic Advising
  • DIY Projects
28K
  • Thermodynamics
