Determining ethanol and methanol content in homemade booze
In summary: I don't think so - different reagents might produce different results. In summary, the author suggests using a photometric assay to determine ethanol and methanol content in a solution, and then doing a freezing point depression to get total concentration. There is some uncertainty involved, but it's a simple and easy method that should be accurate enough for home brewing.
Superposed_Cat
388
Hi, I've recently made some very budget homemade 'beer', butt I'm wondering is there an easy (doesn't have to be accurate) way to determining ethanol and methanol content. any help appreciated.
Chemistry news on Phys.org
Nothing easy and obvious. Ethanol can be estimated by measuring the density, assuming no methanol present (or present in negligible quantities). Methanol is a problem in general, as far as I remember nothing below mass spectrometry is reliable.
Likes 1 person
:/ Ja, I was thinking specific gravity for ethanol content but the methanol is the issue as you say. Just don't want to go blind and die from methanol poisoning. Thanks though.
In fermentation, methanol is produced from pectin. If you ferment materials that have a high pectin content (e.g. fruit, rather than grain) the methanol content will be higher, but it's unlikely to be a health hazard. You can reduce this by adding "pectic enzyme" (trade names pectolase, pectinase, etc) to break down the pectin before it ferments. It is more of an issue in wine making that brewing.
If you are distilling fermentation products, methanol is a much more serious issue - but that is probably an illegal activity, so not a topic for discussion on PF.
In many countries it is illegal, but as far as I understand in some it is not.
I'm not distilling don't worry
Freezing point depression.
Just like density measurement, it requires assumption nothing but ethanol is present. Any other solute and the result is off.
Beer contains also lots of sugar. So you have to separate the alcohol off before you can quantify it, e.g. by distillation.
im only using water yeast (added vitamin c)and sugar.
How do you know how much of the sugar is consumed by the yeast and how much is left?
OP wants an "easy" method: evaporate the filtered product to determine dissolved solids; do a freezing point depression to determine total concentration of dissolved materials; difference is concentration of volatiles.
Pretty certainly the method is going to be enzymatic. Finding an enzyme and reagents that will convert the alcohols into something easily detectable and measurable - something coloured. The problem is do they have one that works on methanol and not ethanol? - lots of enzymes will work on both. Just google 'methanol assay' and you find a lot. And they even sell kits for it apparently, see last ref. below.
I would advise not to use a kit or method without validating it yourself with samples of known methanol and ethanol contents, - test on each alcohol separetely and mixed.
I haven't gone beyond that but quickly turned up this:
http://www.biovision.com/alcohol-dehydrogenase-activity-colorimetric-assay-kit-4164.html http://www.biovision.com/ethanol-colorimetric-fluorometric-assay-kit-2915.html
Applied Biochemistry and Microbiology
November 2002, Volume 38, Issue 6, pp 607-609
Photometric Assay for Methanol in the Presence of Ethanol
Comparison of Three Colorimetric Reagents in the
Determination of Methanol with Alcohol Oxidase.1. Photometric Assay for Methanol in the Presence of Ethanol - Springer
link.springer.com/content/.../A:1020747215826.pd... -
di YV Rodionov - ‎2002 -
ethanol and methanol, involving electrochemical detec- tion of changes in O2 or ... assay of methanol and ethanol in solutions containing both these alcohols.
2. An enzymic assay for the specific determination of methanol in serum.
http://www.ncbi.nlm.nih.gov/pubmed/3319289‎
Really? Imagine you have 100 mL of water solution containing 1.00 g of mixture of sucrose, glucose and NaCl. Please calculate its freezing point depression - that will convince me your method will work.
To make things simple, feel free to ignore creation of ionic pairs.
... easy (doesn't have to be accurate) ... determining ethanol and methanol content
Step 1), f.p. depression; step 2), evaporate water and alcohols from a weighed sample, and weigh the residue (a mixture of who knows, or cares, what); step 3) subtract the 0.3 to 0.5 K contribution to total depression from the 2 to 2.5 (maybe 3 K) depression measured in step 1). 10% uncertainty plus another 10% for working on the kitchen counter --- close enough for home brewing.
For the obsessive-compulsive, redissolve the weighed residue from step 2) in water to equal the original sample weight and determine the depression due to non-volatile dissolved solids (given that biologic activity doesn't modify things too much).
Classical detection is supposed to be oxidation to aldehydes with air and hot copper wire - methanol should go to formaldehyde and ethanol to acetaldehyde, and the smell of formaldehyde should be different. But is this reliable/quantitative?
1. How do you determine the ethanol and methanol content in homemade alcohol?
To determine the ethanol and methanol content in homemade alcohol, a process called gas chromatography is typically used. This involves vaporizing a sample of the alcohol and separating its components based on their different boiling points. The separated compounds are then measured and their concentrations are calculated.
2. Is it safe to drink homemade alcohol with unknown ethanol and methanol levels?
No, it is not safe to drink homemade alcohol with unknown ethanol and methanol levels. Both ethanol and methanol are toxic when consumed in large amounts, and without knowing their concentrations, it is difficult to determine if the alcohol is safe to consume. It is important to properly test and measure the levels of these compounds before consuming homemade alcohol.
3. What are the potential risks of consuming homemade alcohol with high levels of methanol?
High levels of methanol in alcohol can be extremely dangerous and potentially fatal. Methanol is metabolized by the body into formaldehyde and formic acid, which can cause blindness, organ failure, and even death. Therefore, it is crucial to accurately determine the methanol content in homemade alcohol before consuming it.
4. What factors can affect the accuracy of determining ethanol and methanol content in homemade alcohol?
Several factors can affect the accuracy of determining ethanol and methanol content in homemade alcohol. These include the type of still used to produce the alcohol, the quality of the ingredients used, and the accuracy and precision of the testing equipment. It is important to use proper distilling techniques and high-quality ingredients to ensure accurate results.
5. Are there any alternative methods for determining ethanol and methanol content in homemade alcohol?
Yes, there are other methods for determining ethanol and methanol content in homemade alcohol, such as using a hydrometer or an alcohol testing kit. However, these methods may not be as accurate as gas chromatography and may not be able to detect low levels of methanol. It is best to consult with a professional chemist or use gas chromatography for reliable results.
  • Chemistry
13K
24K
