Register to reply
Stream function along solid boundary
by TomBolton10
Tags: boundary, function, solid, stream
Share this thread:
TomBolton10
#1
Jun5-14, 08:14 AM
P: 1
Hi, I am studying fluid mechanics and I am trying to get to grips with slip and no-slip boundaries.
I know that:
Slip ---> Occurs when fluid is inviscid so no viscous stress at boundary.
No-slip ---> Viscous effects mean the the tangential velocity must be zero, relative to the boundary.
Also, for both slip and no-slip boundary conditions you have no normal flow if the boundary is solid and impermeable.
However, the problem I have is that some say that if you have the no normal flow condition, then the stream function is constant regardless of whether it is a slip/no-slip boundary (http://scicomp.stackexchange.com/que...ream-functions). My lecturer however said that the stream function is constant only when it is a slip boundary. Any thoughts? Who is correct?
Phys.Org News Partner Engineering news on Phys.org
DIY glove-based tutor indicates muscle-memory potential
Tricorder XPRIZE: 10 teams advance in global competition to develop consumer-focused diagnostic device
Study shows local seismic isolation and damping methods provide optimal protection for essential computing equipment
Chestermiller
#2
Jun5-14, 10:14 PM
Sci Advisor
HW Helper
Thanks
PF Gold
Chestermiller's Avatar
P: 5,251
Quote Quote by TomBolton10 View Post
I know that:
Your lecturer is wrong, and what "some say" is correct. Just look at the relationship between stream function and velocity to see this. unormal=-∂ψ/∂x, where x is the coordinate along the wall.
Look up in the literature the solutions for inviscid- and viscous flow past a sphere. In both cases, the stream function is constant on the sphere.
Chet
Register to reply
Related Discussions
How to calculate the stream function from the potential function? Classical Physics 0
Stream function Classical Physics 1
Why must stream function be 2d? Classical Physics 1
Stream Function in 3D Classical Physics 0
Stream Function Calculus & Beyond Homework 1
