Thermal physics exam questions - would you check my answers please?
In summary, the conversation is about a student requesting help with past exam papers and problems related to thermodynamics. The conversation includes questions and answers related to calculating change in length of a copper bar, melting ice, atmospheric pressure, energy from the sun, and the first law of thermodynamics. The student also asks for clarification on specific heat capacity and the difference between heat capacity at constant pressure and constant volume. They also discuss the use of Latex for showing formulas correctly.
Brewer
212
I've been revising for my exams with past exam papers supplied by my uni, but they don't supply the answer schemes for them. Would some of you guys look at them for me if I put the question and the answers I get?
Thanks
1) i) calculate the change in length of a 1.5m long copper bar when its temp is raised from 303K to 353K
ANS: 1.275*10^-3 m
ii) calculate the amount of energy to completely melt a 10g ice cube at a temp of 273K
ANS: 3300J
iii)calculate change in entropy in part (ii)
ANS: 12.09 J/K
iv) state 4 assumptions of kinetic theory of gases
ANS: molecules evenly spaced, move in random directions, random velocities, all have the same mass
v) assuming temp constant at 303K and independant of height calculate atmospheric pressure at top of Everest
ANS: 37241 Pa
vi) estimate rate energy escapes from sun (surface temp ~ 6000K) in form of thermal radiation. state assumptions
ANS: 4.52*10^26 W assuming sun is spherical and is a black body emitter
vii) state the entropy form of the second law of thermodynamics
ANS: no process can occur that would result in an increase in the entropy of the universe. Universally the entropy must stay the same or increase.
2) i) State the first law of thermodynamics explain any symbols
ANS: U = Q + W, U=change in internal energy, Q=change in heat, W=change in work
ii) 10kJ of heat are supplied to a gas which then expands at a constant pressure of 5kPa, from an initial volume of 10 litres to a final volume of 40 litres. Calculate the change in internal energy
ANS: -140000J
iii) Explain what is meant by specific heat capacity of a substance
ANS: The specific heat capacity of a substance is the smount of heat required to raise the temperature of 1kg of substance by 1 degree
iv) Explain why the heat capacity of a substance at constant pressure (Cp) is larger than the heat capacity at constant volume (Cv)
ANS: Because Cv is not temperature dependant, but Cp is (complete guess this one)
v) Show that for n moles of ideal gas, Cp-Cv = nR
ANS: I have no idea for this one. I can it relates to PV=nRT somehow but I can't think how.
Please help me!
Thanks
Brewer
Brewer, no one wants to sit down and work out all these problems so that they can tell you if you got the right answer. If you want help then show your work. That way we can easily tell you if you've made an error by examining your solution.
Ok, but how would I go about showing formulas correctly? Otherwise they just get confusing to read.
1. What is Thermal Physics?
Thermal physics is the branch of physics that studies the behavior of matter at a microscopic level in relation to temperature and heat. It involves understanding how heat energy is transferred, how temperature affects the properties of matter, and how thermal equilibrium is achieved.
2. What topics are typically covered in a Thermal Physics exam?
Topics covered in a Thermal Physics exam may include thermodynamics, heat transfer, kinetic theory of gases, thermal properties of matter, and laws of thermodynamics. Other topics may also be included depending on the level of the exam.
3. How can I prepare for a Thermal Physics exam?
To prepare for a Thermal Physics exam, it is important to review class notes, textbooks, and practice problems. It may also be helpful to work on past exam papers and seek help from a teacher or tutor if needed.
4. What is the difference between heat and temperature?
Heat is a form of energy that is transferred from one body to another due to a temperature difference. It is measured in joules (J). Temperature, on the other hand, is a measure of the average kinetic energy of the particles in a substance and is measured in degrees Celsius (°C) or Kelvin (K).
5. What are some common mistakes to avoid when answering Thermal Physics exam questions?
Some common mistakes to avoid when answering Thermal Physics exam questions include not fully understanding the concepts, not showing all the necessary steps in calculations, and not carefully interpreting the given information in the question. It is also important to pay attention to units and significant figures in calculations.
