Trajectory of a Test Particle in a Semidetached Binary
In summary, the conversation discusses using Microsoft Excel to calculate the ballistic trajectory of a test particle released from the inner Lagrange point in a semidetached binary. The conditions and equations for the restricted three-body problem are mentioned, as well as the use of the Runge-Kutta method for calculating trajectories. The individual is seeking guidance on how to apply these equations to solve for the trajectory.
M87
Hello,
I am currently trying to figure out how I can use Microsoft Excel to calculate the ballistic trajectory of a test particle released from the inner Lagrange point in a semidetached binary. To keep things simple, I am using a two-dimensional coordinate system, and I am assuming that the initial conditions of the test particle have very little impact on the trajectory.
So far, I have the conditions of the semidetached binary determined: in the xy plane I have the accreting star located at the origin, and I have the center of mass of the binary and Lagrange Point L1 correctly positioned on the x axis. I have also graphed the radius of the accreting star. All other parameters are also available.
I understand the forces at work, although I am not too familiar with how the directions should be specified for the Coriolis and centrifugal forces on the test particle. I am familiar with the Roche potential of the system, yet I do not know how to apply it to this particular case in determining trajectories. I have also read several publications, including one which has several graphs (the ones on the left side) of what I would like to achieve with this spreadsheet: http://www.astro.psu.edu/~mrichards/research/tomog.gif" The problem is that none of them have gone into detail on how such graphs were derived. So this is as far as I have gotten with my spreadsheet. I would be thankful of someone could lead me in the right direction in calculating these trajectories.
Astronomy news on Phys.org
All right. I apologize for being vague in my first post. I have done more reading, and I am now familiar with the required equations, but I am still a little confused on how I should approach the situation.
In the restricted problem of three bodies the potential is given by:
[tex]\Psi=\frac{1-\mu}{r_1}+\frac{\mu}{r_2}-\mu x+\frac{1}{2}(x^2+y^2)[/tex]
(Kruszewski 1966). Here, μ is the mass of the secondary star divided by the total mass of the binary system. x and y are the coordinates of the test particle, while r1 and r2 are the distances of the primary and secondary star from the origin, respectively.
The equations of motion are given by:
[tex]\ddot{x}=(2A+1)x+2\dot{y}[/tex]
[tex]\ddot{y}=-(A-1)y-2\dot{x}[/tex]
[tex]A=\frac{\mu}{|X_{L1}-1+\mu|^3}+\frac{1-\mu}{|X_{L1}+\mu|^3}[/tex]
(Lubow and Shu 1975). Here, x and y refer to the coordinate system with the Lagrange point L1 centered at the origin. So the positive x-axis points to the accreting star (the mass-accepting star). XL1 is the distance from L1 to the center of mass of the binary system.
Finally, the constant of motion for the restricted three-body problem is given by the Jacobi constant:
[tex]C=\frac{1-\mu}{r_1}+\frac{\mu}{r_2}-\mu x+\frac{1}{2}\mu^2[/tex]
[tex]-\frac{1}{2}\left [\left(\frac{dx}{dt}\right)^2+\left(\frac{dy}{dt}\right)^2\right]+\frac{1}{2}(x^2+y^2)[/tex]
What I wanted to know is how do I use these equations to solve for the trajectory of a test particle originating at L1 as it "free falls" onto the accreting star? The publications where I have obtained these equations mention that the Runge-Kutta method of 7th order was used to calculate the trajectories of the test particle. I have heard of this method before, but I am unfamiliar with how and where I should start. Any help is appreciated.
1. What is a semidetached binary system?
A semidetached binary system is a type of binary star system in which one star is significantly larger and more massive than the other. The larger star, known as the primary star, is close enough to its companion star that it has transferred some of its mass to the smaller star, known as the secondary star.
2. How does a semidetached binary system affect the trajectory of a test particle?
In a semidetached binary system, the gravitational force exerted by the primary star on the test particle is stronger than the force exerted by the secondary star. This results in the test particle being pulled towards the primary star, causing its trajectory to be curved.
3. What factors can influence the trajectory of a test particle in a semidetached binary system?
The trajectory of a test particle in a semidetached binary system can be influenced by the mass ratio between the primary and secondary stars, the distance between the two stars, and the eccentricity of their orbit. Other factors such as the presence of other bodies in the system and the rotation of the stars can also play a role.
4. Is the trajectory of a test particle in a semidetached binary system predictable?
While the trajectory of a test particle in a semidetached binary system can be influenced by various factors, it is still subject to the laws of physics and can be predicted using mathematical models and simulations. However, small changes in the initial conditions of the system or the presence of external influences can make the trajectory less predictable.
5. How is the trajectory of a test particle in a semidetached binary system studied?
The trajectory of a test particle in a semidetached binary system is typically studied using computer simulations and mathematical models. Observational data from telescopes and other instruments can also be used to analyze the motion of the test particle and make predictions about its future trajectory.
  • Astronomy and Astrophysics
  • Quantum Physics
