How to compute for the torque developed in the shaft of the motor?
In summary, to compute for the torque developed in the shaft of the motor, we use the equation Torque = Power/Speed, where the power used is the output power (calculated as 7820 watts) and the speed is the given 800 rpm converted to radians per second. The torque is then calculated to be 93.34 Nm. The friction and iron losses are not the same as SPL, and the output of the motor is almost equal to the output power calculated, indicating good efficiency.
detski
How to compute for the torque developed in the shaft of the motor??
A DC series motor takes 40 A at 220 V and runs at 800 rpm. If the armature nd field resistnces are 0.2 ohm and 0.1 ohm respectively and the iron and friction losses are 0.5 KW. find the torque developed in the shaft of the motor. What will be the output of the motor?
What i did was:
EC= 220-40(.2+.1)
EC= 208
Power of the armature= (0.2)(40)^2=320
power of the field= (.1)(40)^2=160
Poutput= 8.8K-320-160-.5K
Poutput= 7820
7820=(2*pi*800*Torque)/60
Tout=93.34 Nm
My problem>> I don't know what's next..
Is the Friction & Iron Losses same as the SPL of it?
First of all, great job on your calculations so far! To compute for the torque developed in the shaft of the motor, we need to use the equation Torque = Power/Speed. In this case, the power we will be using is the output power, which you have correctly calculated as 7820 watts. The speed is given as 800 rpm, but we need to convert it to radians per second by multiplying it by 2π/60. So, the speed is 83.78 radians per second. Plugging these values into the equation, we get a torque of 93.34 Nm, as you have already calculated.
To answer your question about the friction and iron losses, these are not the same as the SPL (sound pressure level) of the motor. Friction losses refer to the energy lost due to friction between moving parts, while iron losses refer to the energy lost due to magnetic hysteresis and eddy currents in the iron components of the motor. Both of these losses contribute to the overall inefficiency of the motor, but they are not the same as SPL.
To find the output of the motor, we can use the equation Power = Torque x Speed. Plugging in the values we have, we get a power of 7799.6 watts, which is very close to the 7820 watts we calculated earlier. This means that the output of the motor is almost equal to the output power we calculated, which is a good indication of its efficiency.
I hope this helps you with your calculations and understanding of torque and power in a motor. Keep up the good work!
The torque developed in the shaft of a motor can be computed using the formula:
Torque = (Power output * 60) / (2 * pi * RPM)
In this case, the power output is 7820 W and the RPM is 800. Therefore, the torque developed in the shaft of the motor is:
Torque = (7820 * 60) / (2 * pi * 800) = 93.34 Nm
To find the output of the motor, you can use the formula:
Output = Power input - Iron losses - Friction losses
In this case, the power input is 220 V * 40 A = 8800 W. Therefore, the output of the motor is:
Output = 8800 - 0.5 KW - (320 + 160) W = 7820 W
The friction and iron losses refer to the losses in the motor due to friction and magnetic hysteresis, respectively. They are not the same as the SPL (sound pressure level) of the motor.
1. What is torque and why is it important to compute it for a motor shaft?
Torque is a measure of the rotational force applied to an object. In the case of a motor, it is the force that causes the motor shaft to rotate. It is important to compute torque for a motor shaft because it can help determine the motor's power and efficiency, and ensure that the shaft can withstand the applied force without breaking.
2. How do you calculate torque in a motor shaft?
To calculate the torque in a motor shaft, you need to know the force (in Newtons) applied to the shaft and the distance (in meters) from the center of the shaft to where the force is applied. The formula for torque is torque = force x distance. You may also need to consider the angle at which the force is applied if it is not perpendicular to the shaft.
3. What units are used to measure torque?
Torque is typically measured in Newton-meters (Nm) or foot-pounds (ft-lb). These units can be converted to other units of force and distance as needed.
4. How does the torque in a motor shaft affect the motor's performance?
The torque in a motor shaft is a key factor in determining the motor's performance. A higher torque allows the motor to exert more force and therefore generate more power. It also affects the motor's speed and ability to overcome resistance.
5. Are there any factors that can affect the torque in a motor shaft?
Yes, there are several factors that can affect the torque in a motor shaft. These include the type and design of the motor, the amount of resistance or load on the shaft, and any external forces acting on the shaft. It is important to consider these factors when calculating and evaluating the torque in a motor shaft.
  • Mechanical Engineering
29K
