Gravitation Force Between Two Massive Bodies
In summary, the Stardust spacecraft was designed to visit a comet and bring back samples of its material. It successfully took a photograph of the nucleus of comet Wild2 and will return samples to Earth on Jan. 15, 2006. To determine the gravitational force exerted on the spacecraft by the comet, the mass of the comet was calculated using its assumed density of 2.1 g/cm³, and the resulting force was found to be 6.29 x 10^-15.
tater08
29
The Stardust spacecraft was designed to visit a comet and bring samples of its material back to the earth. The craft is 1.7 m across and has a mass of 385 kg. In January 2004, from a distance of 237 km, it took the photograph of the nucleus of comet Wild2, shown in the figure below. The distance across this nucleus is 5 km, and we can model it as an approximate sphere. Since astronomers think that comets have a composition similar to that of Pluto, we can assume a density the same as Pluto's, which is 2.1 g/cm^3. The samples taken will be returned to Earth on Jan. 15, 2006.
What gravitational force did the comet exert on the spacecraft
F=G ((m1 * m2)/R^2) G= 6.674 x 10 ^-11
Well the radius i determined to be 240.35 km. The mass of the satellite is 385 kg. I guess I'm having the problem of determing the mass of the comet. Please Help!
Hi tater08! :smile:
mass = volume times density. :wink:
the volume of a sphere is 4/3 pi (2.5)^3 if the nucleus radius is 5km across the radius is 2.5 km. after converting the 2.1 g/cm^3 to 0.21 kg/m^3. 0.21 kg/m^3 = M/65449.85 m^3 M=13744.47kg F= G (m1 *m2)/R^2 F= (6.674 * 10 ^-11) ((13742.4kg)(385kg))/237000m F=6.29* 10^-15is this right? Thanks for the help!
tater08 said:
… after converting the 2.1 g/cm^3 to 0.21 kg/m^3 …
Nooo …
1. What is the formula for calculating the gravitational force between two massive bodies?
The formula for calculating the gravitational force between two massive bodies is F = G * (m1 * m2) / r^2, where F is the force, G is the gravitational constant (6.67 × 10^-11 N * m^2 / kg^2), m1 and m2 are the masses of the two bodies, and r is the distance between the centers of the two bodies.
2. How does the distance between two massive bodies affect the gravitational force between them?
The gravitational force between two massive bodies is inversely proportional to the square of the distance between them. This means that as the distance between the two bodies increases, the force of gravity decreases.
3. What is the relationship between the mass of the two bodies and the gravitational force between them?
The gravitational force between two massive bodies is directly proportional to the product of their masses. This means that as the masses of the two bodies increase, the force of gravity between them also increases.
4. How does the gravitational force between two massive bodies affect their motion?
The gravitational force between two massive bodies causes them to be attracted to each other and move towards each other. This force is responsible for the motion of planets in orbit around the sun and the moon around the Earth.
5. What is the significance of the gravitational force between two massive bodies in the universe?
The gravitational force between two massive bodies is one of the fundamental forces of nature and is responsible for keeping celestial bodies in orbit and maintaining the structure of the universe. It also plays a crucial role in the formation of galaxies, stars, and planets.
