knowlewj01
- 110
For Cyclohexane
Boiling point [itex]T_b[/itex] = 80.1°C
P = 1atm
[itex]\Delta H_{vap}[/itex] = 30.1 kJ/mol
Determine at phase change liquid to vapour, Changes in:
a)Entropy per mole
b)Gibbs free energy per mole
c)Internal energy per mole
assume ideal gas behaviour for the vapour.
[itex]dS = \frac{dQ}{T}[/itex] [1]
[itex]dG = -S dT + V dP[/itex] [2]
[itex]dE = T dS - P dV[/itex] [3]
(a) entropy per mole
using eq'n [1]
[itex]\Delta S = \frac{\Delta H}{T} = \frac{30100}{353.1} = 85.2 J K^{-1} mol^{-1}[/itex]
(b) change in gibbs free energy at a phase transition at constant pressure is always 0 because, in eq'n [2] [itex]dT=dP=0[/itex]
(c) this is the part I'm struggling with. so using eq'n [3] we already know the Temperature, which is constant and we have calculated the change in entropy. the second term is the problem. it requires that we know what the change in volume is. can this be expressed in another way. -PdV is the work done by the expanding gas at constant pressure. can this be done without knowing the difference between molar densities of cyclohexane between liquid and vapor?
