If a partition of an integral diverges, does the whole integral diverge?
In summary, a partition of an integral is a way of dividing the interval of integration into smaller subintervals to approximate the value of the integral. When a partition diverges, the sum of the subintervals approaches infinity, indicating a possible divergence of the overall integral. However, a divergent partition does not always guarantee a divergent integral. The relationship between a divergent partition and a divergent integral is that a divergent partition is likely to result in a divergent integral, but there are exceptions. The most common method for determining if a partition of an integral diverges is by using the limit comparison test.
Bipolarity
776
[tex] \int^{b}_{a}f(x)dx = \int^{c}_{a}f(x)dx + \int^{b}_{c}f(x)dx [/tex]
If one of the integrals on the right-hand-side is known to diverge, must the integral on the left also necessarily diverge?
BiP
Yes, by definition of improper integrals.
Yes if c is between a and b. But not necessarily if c is not between a and b:
[tex] \int_{1}^{2} \frac{1}{x}dx [/tex] converges, but [tex] \int_{1}^{-1}\frac{1}{x}dx + \int_{-1}^{2} \frac{1}{x}dx [/tex] diverges (each term is an integral over a region containing 0, where 1/x is unbounded).
1. What is a partition of an integral?
A partition of an integral is a way of dividing the interval of integration into smaller subintervals in order to approximate the value of the integral. This is often done in calculus and can be useful in evaluating integrals that are difficult to solve using traditional methods.
2. What does it mean for a partition of an integral to diverge?
When a partition of an integral diverges, it means that the sum of the subintervals approaches infinity as the number of subintervals increases. This indicates that the overall value of the integral may also approach infinity.
3. Does a divergent partition always mean that the entire integral will also diverge?
No, a divergent partition does not always mean that the entire integral will also diverge. It is possible for the overall integral to converge even if the partition diverges. This depends on the function being integrated and the specific partition used.
4. What is the relationship between a divergent partition and a divergent integral?
If a partition of an integral diverges, then it is likely that the entire integral will also diverge. However, there are exceptions to this rule and a divergent partition does not always guarantee a divergent integral.
5. How can one determine if a partition of an integral diverges?
The most common method for determining if a partition of an integral diverges is by using the limit comparison test. This involves comparing the integral to a known divergent integral and taking the limit as the number of subintervals approaches infinity. If the limit is equal to infinity, then the partition is divergent.
  • Calculus
