Network to connect television satallite dishes
In summary, there was talk a few years ago about setting up a network to connect television satellite dishes for use in astronomy. The idea was to use the dishes overnight when most people aren't watching to provide a large view and perspective with a surface area surpassing anything else imagined. However, no further mentions of this idea have been seen. Some questioned how the dishes would be connected and where the data would go, but others believed the idea was feasible and worth pursuing. The details of the plan were not remembered, but it was thought that a wireless transmitter would relay the information to NASA. Overall, the possibilities of this network were fascinating and could potentially start small and grow with the development of wireless technology.
pbj59
Does anyone here remember talk a few years ago about setting up a network to connect television satallite dishes to be used for astronomy? the theory was use the dishes overnight when most people are not watching. It could provide a large view and perspective with a surface area surpassing anything else imagined. After hearing/reading about it, I never saw it mentioned again.
RW
Astronomy news on Phys.org
How would you connect them all though? Our dish is connected to the TV - not a lot you could do with that I'd have thought... Where would the data go??
network
I wish I could remember where I read it, prob in Astonomy mag. or Pop science. The details I don't remember, thought it sounded good at the time. I suppose a wireless transmitter would relay the info to NASA or something.
Roy
I think the idea is, in principle, just fine.
I suspect that, as usual, the devil is in the details.
network
When I read about this, I was fascinated by the possibilities- the total dish surface area could be immense, I wish I could remember where I read it. It had to be in a science or astronomy magazine(basically the only things I read ). I'm sure it would be complicated, but now with wireless being more completely developed, it could become more possible. I believe it would be worth it, and the good part is it could start small.
Roy
1. What is a network to connect television satellite dishes?
A network to connect television satellite dishes is a system that allows multiple satellite dishes to be connected and share a single satellite signal. This enables the distribution of the satellite signal to multiple televisions or devices within a household or building.
2. How does a network to connect television satellite dishes work?
A network to connect television satellite dishes works by using a multi-switch or multi-switch matrix to combine multiple satellite signals into one cable. This cable is then connected to a satellite receiver, which decodes the signal and distributes it to multiple televisions or devices through a network of coaxial cables.
3. What are the benefits of using a network to connect television satellite dishes?
One of the main benefits of using a network to connect television satellite dishes is cost savings. Instead of having to install separate satellite dishes for each television or device, a single dish can be used to distribute the signal. This also reduces clutter and simplifies the setup process.
Additionally, a network to connect television satellite dishes allows for greater flexibility in terms of the placement of televisions and devices. As long as they are connected to the network, they can receive the satellite signal from the shared dish.
4. Are there any limitations to using a network to connect television satellite dishes?
One limitation of using a network to connect television satellite dishes is that all televisions or devices connected to the network will receive the same channels. This means that individual channel selection or recording capabilities may be limited.
Additionally, the strength and quality of the satellite signal may be affected by the number of devices connected to the network and the length of the coaxial cables used.
5. How do I set up a network to connect television satellite dishes?
The setup process for a network to connect television satellite dishes may vary depending on the specific equipment being used. However, in general, it involves connecting the satellite dish to a multi-switch or multi-switch matrix, which is then connected to a satellite receiver. The receiver is then connected to a network of coaxial cables, which are in turn connected to the televisions or devices. It is recommended to consult the manufacturer's instructions or seek professional installation for the best results.
  • Astronomy and Astrophysics
  • General Discussion
