Non Commuting Observables not Representing a Complete Set?
In summary: The text says that if two operators do not commute, then it is impossible to find a set of states that both operators are eigenstates of. So if A and B do not commute, then there is no complete set of eigenstates that they share.
kq6up
368
I am going through James Binney's course on Quantum Mechanics. I love all of the little misconceptions he points out along the way. One thing he mentions in his text and the lectures is found on page 20 and 21 starting with the heading "Commutators" eq. 2.21. He states that non commuting observables do not form a complete set. Could someone unpack this idea for me, or point me to some text that expands on this idea a little more clearly?
Here is a link to his textbook. It is FREE:
http://www-thphys.physics.ox.ac.uk/people/JamesBinney/qb.pdf
Thanks,
Chris Maness
It says that there is no complete system of mutual eigenkets of ##A## and ##B##.
So since ##A## and ##B## are self-adjoint, they have both a complete system of eigenkets. In LA language, it is said that we can diagonalize ##A## and ##B##. But we cannot do it simulatenously. So if we have a complete system of eigenkets of ##A##, then some of them won't be eigenkets to ##B##.
Likes 1 person
It means that if the operators ##A## and ##B## do not commute, it is impossible to find a set of states ##\left|\phi_i\right>## such that:
1. All states ##\left|\phi_i\right>## are eigenstates of both ##A## and ##B##.
2. Any imaginable state ##\left|\psi\right>## can be written as a linear combination of the states ##\left|\phi_i\right>##. This is what it means if a set of vectors forms a complete set in the vector space being considered.
EDIT: Micromass was faster than me...
Likes 1 person
He says that if A and B don't commute it is impossible to find a complete set of mutual eigenkets of A and B. This means that it is impossible to have an eigenket of A and an eigenket of B. As a consequence this means that you cannot have a state that has a definite value of A and a definite value of B.
Edit. Everyone is faster than me!
Likes 1 person
^ Actually, that is not true. As pointed out in the text linked by the OP, it is possible that some ket is "accidentally" an eigenket of two mutually non-commuting observables. It's just that one can never find enough such kets to span the whole vector space.
Likes 1 person
Ahhh, I like that. Self adjoint meaning -- hermitian. That is, when the eigenvectors are orthogonal -- which in QM they always are (I think).
Chris
Chris
Self-adjoint and Hermitian are very similar, but not exactly the same. Self-adjoint is a slightly stronger condition that requires the domain of the two operators (the operator itself and its adjoint) to be identical.
Eigenvectors of distinct eigenvalues of self-adjoint operators are orthogonal. Degenerate eigenvectors need not be orthogonal, but one can use the Graham-Schmidt procedure to make them so.
Likes 1 person
Think about the harmonic oscillator in 1D. The Hamiltonian doesn't commute with neither momentum, nor coordinate. The eigenvectors of the Hamiltonian don't even live in the same space as the eigenvectors of either momentum or coordinate. Now go to the occupation number formalism. The number operator's eigenvectors are eigenvectors for the Hamiltonian (since H = N + 1/2). H and N will then commute.
Likes 1 person
Ok, I have had a little time to scratch my head on this one. In general operators (matrices) do not share eigenkets (eigenvectors). So is there some positive relationship between having common eigenket and commutation? In other words -- if two operators share eigenkets, they commute, and if not they don't?
This seems like a stretch, since I am at a loss as to how to see if this is true with some sort of proof.
Thanks,
Chris Maness
Ok, I think I can actually show what I just said. Let-a-rip:
$${ C }^{ -1 }QC=D\quad and\quad let\quad Q=AB$$ Where A & B are hermitian. That is:
$$A={ A }^{ \dagger }\quad and\quad B={ B }^{ \dagger }$$
Let C be the unitary matrix that diagonalizes Q.
$${ C }^{ \dagger }ABC=D\quad implies\quad { \left( { C }^{ \dagger }ABC \right) }^{ \dagger }={ D }^{ \dagger }=D\quad \therefore \quad D={ C }^{ \dagger }BAC$$
This seems to imply AB=BA under the conditions above. I know it doesn't show that C the unitary matrix that diagonalizes (spectrally decomposes) A and B separately. I think I would have to show that to be sure.
Is this any good?
Thanks,
Chris Maness
For one direction (for matrices at least), see http://www.math.drexel.edu/~foucart/TeachingFiles/F12/M504Lect2.pdf Section ##3##. So this shows that any family of commuting normal operators are simultaneously diagonalizable.
As for the other direction. Let ##A## and ##B## be simulatenously diagonalizable. Then there is (by definition) a unitary matrix ##C## and diagonal matrices ##D## and ##D^\prime## such that ##CAC^{-1} = D## and ##CBC^{-1} = D^\prime##. But then ##CABC^{-1} = DD^\prime = D^\prime D = CBAC^{-1}##. It follows that ##AB = BA##.
As for what you did, you assumed that there is a real diagonal matrix ##D## such that ##CABC^{-1} = D##. You cannot just assume this. This assumption is actually equivalent to asking that ##AB## is self-adjoint and that is only the case if ##AB=BA## (it is even equivalent to this).
Likes 1 person
Thanks, micromass. It is now clear to me why what you shared with me is true. I think you meant to put the ^(-1) on the right "C". I would still like to get better physical insight into what he stated. I get that an abstract space can be covered (I take that to mean that you can add the basis together in such a way to reach every point in Hilbert/Abstract space can be reached by this set of basis). However, why this would be the case for eigenkets of operators that don't commute might still be eluding me. Is it because there are not enough kets/vectors to span all space since a non commuting pair would not necessarily produce a full basis set of kets to span this space?
Thanks,
Chris Maness
Anyone still around to verify my last statement?
Thanks,
Chris Maness
A given Hermitian operator will have a complete basis of eigen-vectors. Two Hermitian operators will have a complete basis of mutual eigen-vectors, this is because if ##A\left|a_n\right>=a_n\left|a_n\right>## then the ##\left|a_n\right>## are complete, and given ##AB=BA## then:
$$A(B\left|a_n\right>)=B(A\left|a_n\right>)=a_n(B\left|a_n\right>)$$
This means that although B transformed the state ##\left|a_n\right>## into another state ##B\left|a_n\right> ## this transformed state is still the eigen-vector of ##A## with eigenvalue ##a_n##. Given the case of non-degenerate eigen-vectors where each eigenvalue corresponds to only one eigen-vector (for a more complete proof, where degeneracies are considered, one can look at e.g. Ballentine) then this means that ##B\left|a_n\right>=b_n\left|a_n\right>## for some constant ##b_n##. So the eigen-vectors of ##A## are also eigen-vectors of ##B##.
The fact of completeness is much harder to prove, and is given basically by the spectral theorem. If A and B do not commute, then a given eigen-vector of A will not necessarily be an eigen-vector of B. The eigen-vectors of A and B both still form a complete set, but they no longer coincide with each other.
1. What are non commuting observables?
Non commuting observables are physical quantities that cannot be simultaneously measured with complete precision. In other words, the order in which these observables are measured affects the outcome of the measurement. This is in contrast to commuting observables, where the order of measurement does not impact the results.
2. Why do non commuting observables not represent a complete set?
Due to the fact that the order of measurement affects the results, non commuting observables cannot be used to fully describe a physical system. This means that they do not form a complete set, as there are other observables that are needed to fully characterize a system.
3. How do non commuting observables impact the uncertainty principle?
The uncertainty principle states that there is a fundamental limit to the precision with which certain pairs of physical quantities, such as position and momentum, can be measured. Non commuting observables play a crucial role in this principle, as their inability to be measured simultaneously with complete precision contributes to the uncertainty in these measurements.
4. Can non commuting observables ever be measured simultaneously?
No, it is not possible to measure non commuting observables simultaneously with complete precision. This is a fundamental principle of quantum mechanics and is a result of the inherent uncertainty in the behavior of subatomic particles.
5. How do non commuting observables affect our understanding of the physical world?
Non commuting observables challenge our classical understanding of the physical world, where it was believed that all physical quantities could be measured with complete precision. They highlight the probabilistic nature of quantum mechanics and the limitations of our ability to fully describe and measure physical systems.
  • Quantum Physics
  • Quantum Interpretations and Foundations
  • Quantum Physics
  • Quantum Physics
32K
  • Quantum Physics
  • Art, Music, History, and Linguistics
10K
