Show that a Group (G, *) definied by a condition is Abelian
In summary, the conversation discusses a group (G, *) where * is a law, and a condition where (x * y)^i = (x^i) * (y^i) for all i belonging to {2, 3, 4} and (x, y) belonging to G2. The question is to show that G is an Abelian (commutative) group. The solution is to show that if the group is not Abelian, there are elements a and b with ab - ba ≠ 0, and then using the given condition, prove that * is commutative. This can be done for all i values, showing that G is indeed an Abelian group.
JPC
206
(G, *) is a group (where * is a law)
And for all 'i' belonging to {2, 3, 4}, for all (x, y) belonging to G2
(x * y) ^ i = (x^i) * (y^i)
(where ^ is the law : to the power of)
Question : Show that G is an Abelian (commutative) group
we have never done any questions of that sort yet, all i can say is that
"(x * y) ^ i = (x^i) * (y^i)" shows that the law '^' (to the power of) is distributive over the law '*' for 'i' belonging to {2, 3, 4}
But then i don't know where to go
Any help or directions would be appreciated, thank you :)
Hi JPC! :smile:
My inclination would be to start by saying …
if it's not Abelian, then there are a and b with ab - ba ≠ 0,
so let ab - ba = c, and … :smile:
oh, i should have precised, here "*" is not necessarily the multiply law, it can be any law that respects the given conditions
i tried with your method, putting to the square after, but then i end up working with 4 laws at the same time :D
Thank you for the indication anyways, i have to find the little trick inside that exercise now
Hello Jpc,
In the case that i = 2,
(x*y)*(x*y) = x*x*y*y
by associativity:
x*(y*x)*y = x*(x*y)*y
and then just left and right multiply by x inverse and y inverse respectively.
This proves that G is Abelian, since we have shown * to be commutative.
If you want to show this for the more complicated cases where i is only allowed to take the value 3 or only allowed to take the value 4, then you would need to rephrase your question.
yes thank you Sisplat, that works very well :)
I was looking for very complicated things, and i did a little confusion, thinking that the "^i" was associated to the multiply law and not the * law
And yes, you were right, there were too many data given, to confuse you probably
Thanks again
1. What is a group defined by a condition?
A group defined by a condition is a mathematical structure that consists of a set of elements and a binary operation that satisfies certain conditions. These conditions include closure, associativity, identity element, and inverse element.
2. How is the binary operation defined in a group?
The binary operation, denoted by *, is a rule that combines any two elements in the group to produce a third element. It is defined such that for any two elements a and b in the group, a * b is also an element of the group.
3. What does it mean for a group to be Abelian?
A group is considered Abelian if its binary operation is commutative, meaning that for any two elements a and b in the group, a * b = b * a. In other words, the order in which the elements are combined does not affect the result.
4. How do you show that a group defined by a condition is Abelian?
To show that a group (G, *) defined by a condition is Abelian, we must prove that for any two elements a and b in the group, a * b = b * a. This can be done by using algebraic manipulations and the properties of the group, such as associativity and identity element.
5. Can a group be both defined by a condition and Abelian?
Yes, a group can be defined by a condition and also be Abelian. In fact, many commonly studied groups, such as the integers under addition or the real numbers under multiplication, are both defined by a condition and Abelian.
