Calculating Tension in Cord in 2-Pulley System
In summary: I redid the Ffriction calculation and it came out to be -2.6219 m/s^2. I then plugged that back into the equation with the tension, T1, and got the correct answer of 39.5 N. In summary, the problem involves three masses connected by cords and moving at the same speed with the same acceleration. The tension in the cord connected to the 9kg block can be found by setting up equations of forces for each mass and solving for the tension. The coefficient of friction between the block on the ramp and the ramp itself must also be taken into account.
maximoanimo
I attached a picture of the given figure to this thread. The suspended 2.5kg mass is moving up, the 2.9kg mass on the ramp is sliding down, and the 9kg mass is moving down. It is given that there is friction between the block on the ramp and the ramp itself with a coefficient of friction = 0.11. The pulleys are massless and frictionless.
What is the tension in the cord connected to the 9kg block?
F = ma
So, I drew three free-body diagrams for the three separate masses. I'll call the furthermost left mass m1, the middle block on the ramp m2, and the rightmost mass m3.
The forces acting on m1 are the force of gravity and the tension in the far left cord (I'll call this tension T1, and m1's overall acceleration a1). Therefore, since m1 is falling:
Sum(forces) = m1g - T1 = m1a1
For m2, in the x direction the forces are the force of friction in opposite direction to the motion, the tension in cord T1, the tension in the other cord T2, and the x-component of gravity, m1gsin(33). In the y direction, the forces are the normal force and the y-component of gravity. Therefore:
Sum(x forces) = T2 + Ffriction - T1 - m2gsin(33) = m2(a2 - a1)
Sum(y forces) = n - mgcos(33) = 0
The free-body diagram for m3 is the same as m1, but the object is moving in opposite direction so:
Sum(forces) = T2 - m3g = m3a2
I've reached this point and I believe my equations are right (except possibly the sum of x forces for m2), but I can't seem to figure how to combine these equations to determine T1.
Any help is greatly appreciated. Thanks!
(1) Since m2 is moving down the incline, why not choose that as your positive direction?
(2) Since the masses are connected by cords, how must their accelerations relate?
(3) How can you express Ffriction in terms of other quantities?
Your analysis of m1 and m3 is good.
(1) Yeah, that makes a lot more sense.
(2) I figured there was no related between the acceleration of the two cords since they were not on the same pulley. Are they equal but opposite (a1 = -a2)?
(3) I actually meant to fill that in. Following from friction force = u x n,
Ffriction = (0.11)m2gcos(33) = 2.6219
Therefore, using the equation for the x forces on m2:
T1 + m2gsin(33) - T2 - 2.6219 = 2(m2)(a)
T1 - T2 = 5.8a - 12.8567
Solving the equations for m1 and m3, we find:
T1 = 88.2 - 9a
T2 = 24.5 - 2.5a
T1 - T2 = 63.7 + 11.5a
Equating this equation with the previous:
11.5a + 63.7 = 5.8a - 12.8567
5.7a = 76.5567
a = 13.431
Plugging this into the equation for T1,
T1 = 88.2 - 9(13.431) = 32.679
But that answer is definitely wrong. I feel kinda lost, can someone give me some guidance on where I need to go with this problem? I been trying for a couple of days hahha.
The three masses are connected, so they all have the same speed and the same magnitude of acceleration.
Redo this calculation.
Tip: Generally, it's a good idea to hold off from using the calculator as long as possible. Try to solve the equations symbolically until the last step. This way if you make an arithmetic mistake you won't have to redo everything.
Thanks a ton, Doc Al! I finally got the answer right lol.
What is a 2-pulley system?
A 2-pulley system is a setup in which two pulleys are connected by a cord or rope. The pulleys can either be fixed or movable, and the cord is used to transfer force from one pulley to the other.
How is tension calculated in a 2-pulley system?
Tension in a 2-pulley system is calculated by using the equation T = (W1 + W2)/2, where T is the tension in the cord, W1 is the weight of the object being lifted, and W2 is the weight of the pulley system itself.
What factors affect tension in a 2-pulley system?
The tension in a 2-pulley system can be affected by various factors, including the weight of the object being lifted, the weight of the pulley system, the angle of the cord, and the friction between the cord and the pulleys.
Can the tension in a 2-pulley system ever be greater than the weight of the object being lifted?
No, the tension in a 2-pulley system can never be greater than the weight of the object being lifted. The tension will always be equal to or less than the weight of the object, as the pulley system simply redirects the force required to lift the object.
How does the number of pulleys affect tension in a 2-pulley system?
The number of pulleys in a 2-pulley system does not affect the tension in the cord. The tension will remain the same regardless of the number of pulleys, as long as the pulleys are arranged in a simple, non-complicated system with no additional weights or forces.
