Is there a reaction called nucleus reaction?
In summary, the conversation discusses the role of electrons in nuclear reactions and how they can affect the behavior of nuclei. The question is raised about whether it is possible to have reactions with only the nucleus, without the presence of electrons. It is also mentioned that in advanced nuclear physics, the focus is on studying elementary particles. The conversation also touches on the effects of electron interference in nuclear experiments and how heavy ion facilities can mitigate these issues. Finally, the topic of naked nuclei and their stability is brought up, with examples of nuclei that may be stable when naked due to the absence of electrons.
abdullahbameh
is there a reaction called nucleus reaction?
my question is can we have reaction that has only the nucleus by separating the electron cloud and why we have in nuclear reaction most of the time reactions have the elecron in it and if we take the nucleus alone there will be no reactions having any electron under the theory there no electron in the nucleus and thank you...
please writer shorter and clearer sentences. I have not understand any of your postings in this forum.
Just so that I know how I should answer, how much Nuclear Physics have you studied?
Do you know of any experiment where electron interference causes so much disturbance that we can't get good resolution enough concerning properties of the nuclei?
my question is why we are not having only nucleus reactions ((( P and N )) without electron,
because nuclear physics is concerned with the nucleus only is that correct.
why are we putting the electron in middle is that because nuclear physics deal with the elementary particles.
and i can say about my slef that i am in advanced nuclear physics
"why are we putting the electron in middle is that because nuclear physics deal with the elementary particles"
That sentence makes me doubt that you are in the field of advance nuclear physics..
the meaning is can not we deal only with N AND P AND what is inside the nucleus!
How can I know what you mean? You wrote that nuclear physics deal with elementary particles. Neither the proton nor the proton is an elementary particle, however - the electron is an elementary particle.
What kind of interference could the electron could give rise to? We can also derive those interferences and substract them, not so difficult, electrons are relative simple objects.
And what kind of nuclear experiments do you know of that electron interference causes problems? And also, heavy ion facilities exists, so don't worry so much :-)
/malawi
Primary cosmic rays are 'naked' nuclei I believe (they are mostly protons, but heavy nuclei are found too.)
Naked nuclei should indeed sometimes behave differently from those accompanied by electrons. In an atom with a heavy, highly-charged nucleus the total binding energy of the electrons is very considerable, of the order of 1 Mev. These electrons include some that spend time near or even partly within the nucleus. They therefore counteract the mutual repulsion of the protons and stabilise the positive charge of the nucleus.
Consequently, there must be nuclei which while stable as part of atoms, would not be as naked nuclei because there are no electrons to stabilise the positive charge.
Some light nuclei that normally decay by electron-capture may be stable when naked. Electron-capture involves the production of an almost massless neutrino, and as the electron is captured its mass contributes to the decay energy. In beta+ decay you must have the energy available to make the positron (0.5Mev).
Therefore some nuclei that normally decay by electron-capture are stable to beta+ decay and therefore stable when naked. I believe Be-7 may be an example.
1. What is a nucleus reaction?
A nucleus reaction is a type of reaction that involves the splitting or combining of atomic nuclei, leading to the release or absorption of large amounts of energy. This reaction is also known as a nuclear reaction.
2. How is a nucleus reaction different from a chemical reaction?
A nucleus reaction involves changes to the nucleus of an atom, while a chemical reaction involves changes to the electron configuration of an atom. Nucleus reactions also release much more energy than chemical reactions.
3. What are some examples of nucleus reactions?
Some examples of nucleus reactions include nuclear fission, where a heavy nucleus is split into smaller fragments, and nuclear fusion, where two or more light nuclei combine to form a heavier nucleus.
4. Are nucleus reactions safe?
Nucleus reactions can be both safe and dangerous, depending on the circumstances. In controlled environments, such as nuclear power plants, they can provide a reliable source of energy. However, in uncontrolled environments, such as nuclear accidents, they can release harmful levels of radiation.
5. Can humans control nucleus reactions?
Yes, humans have developed ways to control nucleus reactions through various methods, such as using control rods to regulate the rate of fission in a nuclear reactor. However, it is important to follow strict safety protocols to prevent accidents and potential harm to humans and the environment.
