Lienard-Wiechert potentials. To solve an equation.
  • Thread starter lailola
  • Tags
    Potentials
In summary, the problem with classical electrodynamics is that it is difficult to solve the equation for the position of a particle exactly. Sometimes it is sufficient to find an approximate solution, and one way to do this is to guess first approximation t_r(1) = r/c and then evaluate the right-hand side. Often the first approximation t_r = r/c is sufficient, but if r ~ x, it will not be. Then you have to either iterate the above procedure many times or find another approach.
lailola
46
Hi, I have a doubt about a problem of classical electrodynamics (specifically for calculating the Lienard-Wiechert potentials).
(t_r is the retarded time, and t the time).
The position that has a particle is given by: x (t_r) = e cos (w t_r).
The squared modulus of the relative position vector is: R ^ 2 = r ^ 2 + x ^ 2 - 2rx
On the other hand, we know that: R ^ 2 = c ^ 2 (t-t_r) ^ 2
Equating the two expressions:
r ^ 2 + x ^ 2 - 2rx = c ^ 2 (t-t_r) ^ 2
Then, I have to replace x (t_r) and solve the equation for t_r, but I don't know how to solve it...maybe there's any trick for doing it.
Any idea?
Thank you.
Hello lailola,
such equation is difficult to solve exactly. Often it is sufficient to find approximate solution. One way is as follows.
- reexpress the equation as a formula for t_r:
t_r = f(t_r)
- guess first approximation t_r(1) = r/c and insert to the right-hand side
- evaluate the right-hand side. This is the second approximation; should be better than the first one.
- repeat how many times is necessary
Often the first approximation t_r = r/c is sufficient; but if r ~ x, it will not be. Then you have to either iterate the above procedure many times or find another approach.
Jano L. said:
Hello lailola,
t_r = f(t_r)
Hi Jano, thanks for your help. But why can I set t_r(1)=r/c?
I made a mistake.
The retarded time is exactly t_r = t - R/c.
R can be (if r>>x) approximated by r, so
t_r ~ t - r/c.
Jano L. said:
I made a mistake.
t_r ~ t - r/c.
Ok! But, in that case, I don't use x for anything. That's strange, isn't it?
Well, it is an approximation, good as long as x is much smaller than r. The second approximation will contain x.
How would it be the second aproximation? I was thinking about Taylor series but I don't know how to apply that here.
And, another question, would it be reasonable (supossing w is small) to aproximate cos(wt) by 1-(wt)^2/2?
Thank you!
The Taylor series will be accurate only for times much less than period. But in such problems we are usually interested in long periodic motion, so Taylor probably won't be a good idea.
It would be much better if you can post the full assignment.
I have to find the Lienard-Wiechert potentials
[itex]\vec{A}=\frac{q\vec{v}}{cR-\vec{R}\vec{v}}[/itex]
[itex]\phi=\frac{qc}{cR-\vec{R}\vec{v}}[/itex]
(both evaluated in t_r)
with [itex]\vec{R}=\vec{r}-\vec{x}(t_r)[/itex]. [itex]\vec{x}(t)=Acos(wt) \hat{z}[/itex] is the trajectory of the particle.
Then I have to find E, B and S.
OK, what we wrote applies, you have equations
t_r = t - R/c
R^2(t_r) = c^2(t-t_r)^2
The last equation can be written as
t_r = t - R(t_r)/c~~(*)
The zeroth approximation (in x) is as if the particle was at x = 0:
t_{r0} \approx t - r/c ~(0th~ approx.)
The first approximation in x is obtained from * by substituting the first approximation to the right-hand side:
t_{r1} \approx t - R(t_{r0})/c~(1st ~approx.)
just plug-in the expression for R(t_{r0}).
Higher approximations are derived in the same spirit.
t_r = t - R/c
Ok, I'm going to work the problem that way. If I have any problem, I'll come back!
Thank you a lot, Jano.
Glad to help.
Jano
Another thing! If I want to know the results from an inertial frame which is moving with velocity v on the z axis, how can I do it? Just with Lorentz transformation? Or do I have to solve the problem from the start?
You can find the fields and motion of the particles in any inertial frame, the results are connected via Lorentz transformation. In your assignment you have prescribed motion of the particle x =... in lab frame, so it makes sense to solve everything in this frame and then transform into another if you need to.
1. What are Lienard-Wiechert potentials?
The Lienard-Wiechert potentials are mathematical functions used in electromagnetism to describe the electric and magnetic fields produced by a moving electric charge. They take into account the effects of both the charge's motion and its acceleration.
2. How are Lienard-Wiechert potentials derived?
The Lienard-Wiechert potentials are derived from Maxwell's equations, which describe the fundamental laws of electricity and magnetism. They are a solution to the wave equation and are based on the principle of causality, meaning that the fields at a given point are determined by the charge's past and present positions and velocities.
3. What is the significance of Lienard-Wiechert potentials?
Lienard-Wiechert potentials are important in understanding and predicting the behavior of electromagnetic fields, particularly in situations involving moving charges. They have been used to explain phenomena such as radiation from accelerated charges and the Doppler effect in electromagnetic waves.
4. How are Lienard-Wiechert potentials used in practical applications?
Lienard-Wiechert potentials are used in many practical applications, such as in the design of antennas and radar systems, as well as in particle accelerators. They are also used in theoretical physics to study the behavior of charged particles in electromagnetic fields.
5. How can one solve an equation involving Lienard-Wiechert potentials?
To solve an equation involving Lienard-Wiechert potentials, one can use mathematical methods such as integration and differentiation. It is also important to understand the physical principles and assumptions behind the equation being solved. Advanced techniques such as numerical methods may also be used to solve more complex equations.
  • Mechanics
