Register to reply
Lowest energy neutrino transmutations
by snorkack
Tags: energy, lowest, neutrino, transmutations
Share this thread:
snorkack
#1
Apr19-14, 02:59 AM
P: 381
What are the lowest energy transmutation caused by a neutrino and an antineutrino respectively?
Phys.Org News Partner Physics news on Phys.org
New approach to form non-equilibrium structures
Nike krypton laser achieves spot in Guinness World Records
Unleashing the power of quantum dot triplets
Simon Bridge
#2
Apr19-14, 03:13 AM
Homework
Sci Advisor
HW Helper
Thanks ∞
Simon Bridge's Avatar
P: 12,434
probably the transmutation of the neutrino into itself.
you should be able to answer this for yourself - what are the possible transmutations?
what would be the "energy of the transmutation"?
snorkack
#3
Apr19-14, 03:24 AM
P: 381
With neutrino, the reaction should be
n+nue->p+e, right?
Therefore the lowest energy transmutation due to a neutrino should be the reverse of the lowest energy electron capture.
Which nucleus, of all nuclei, has lowest energy of electron capture?
Detecting antineutrinos should be much harder:
p+antinue->n+e+ should have a huge energy threshold
while p+antinue+e->n should be improbable because 1) it takes 3 particles at the start and 2) because there is only 1 particle at the end, it should be hard to dispose of excess energy.
mfb
#4
Apr19-14, 04:47 AM
Mentor
P: 11,580
Not huge compared to typical neutrino energies. But you can do this in a nucleus like tritium, where it can be threshold-free.
Right.
snorkack
#5
Apr19-14, 05:01 AM
P: 381
Where can data of electron capture energies be found systematically presented?
It seems that lowest energy electron capture should be the 163-Ho/163-Dy system... about 2,6 keV needed. What are the other low energy electron captures?
Not huge compared to typical neutrino energies? Typical neutrino energies should be couple hundred keV. The reaction p+p->d+e++nue has just about 400 keV energy, and that has to be divided between the neutrino and positron. So much of the time the neutrino should not have the 232 keV to transmute gallium 71.
So - are there any isotopes besides dysprosium 163 whose transmutation energy is lower than the 232 keV of gallium 71?
mfb
#6
Apr19-14, 05:21 AM
Mentor
P: 11,580
163 Ho/Dy and Tritium are well-known for their low transition energies, the neutrino mass experiments use them for this reason.
There are multiple websites with nuclear data, they all have different advantages and disadvantages.
snorkack
#7
Apr19-14, 05:54 AM
P: 381
Im puzzled why Ga-71 is used in radiochemical detection. There should be many ways to lose Ge-71 and its radiation, and even if caught the timing, energy and direction information is lost.
Ga-71 is commonly used to produce blue photons. So why not detect neutrinos with a gallium 71 nitride crystal? Any neutrino interacting with it should produce holes and electrons in the semiconductor and emit a number of photons easily detected.
Would a gallium nitride blue flash incorporate clear information of the direction of the incoming neutrino?
Vanadium 50
#8
Apr19-14, 09:00 AM
Mentor
Vanadium 50's Avatar
P: 16,123
Gallium is used because the germanium can be chemically extracted easily - for example, by making germane gas - and the atoms of germanium counted. These experiments are not done in real time: they take a ~month-long exposure, remove and count the germanium, and repeat.
Register to reply
Related Discussions
Entropy at lowest energy Classical Physics 16
Is civil engin. the lowest of the lowest when it comes to engineer? General Discussion 11
Lowest energy conformation Biology, Chemistry & Other Homework 2
Does neutrino oscillation from electron neutrino to muon neutrino conserve energy? High Energy, Nuclear, Particle Physics 4
Delat energy required to excite hole from lowest energy orbit to valence band? Atomic, Solid State, Comp. Physics 1
