Why the K.E. Increases in a 10-Stage Linac Accelerator with 200 kV Supply
  • Thread starter jsmith613
  • Tags
    Drift Tube
In summary, the conversation discusses the kinetic energy of an electron in a 10-stage linac accelerator with a 200 kV supply and how it changes as it passes through different stages. The question is asked if the KE will double if the electron is accelerated through another 300V. The calculations are easier to do using eV units and it is explained that an ac voltage and drift tube are used to shield the electron from the applied voltage. A calculation is provided to determine the drift tube lengths based on the ac frequency. The conversation concludes with a summary of the relationship between tube length and KE in the accelerator.
jsmith613
614
Lets say we had a 10-stage linac accelerator and we were using a 200 kV supply.
Apparently the K.E at stage 2 (in the second tube) is twice that of the first tube (stage 1).
why is this?
In fact a better question is:
If an electron, starting at 0 m/s is accelerated across a p.d of 300V its new KE is
4.8 * 10-17J (E = QV).
My question is, if I accelerate this electron (with this KE) through another p.d of 300V then, disregarding relativistic effects, will the new KE be
4.8 * 10-17J *2 = 9.6*10-17J ?If not then what will it be?
It is easier to do the calculations using eV (electron-volt) units. The electron mass in eV units is mc2 = 511,000 eV. The kinetic energy is
[tex] KE=\frac{1}{2}mv^2=\frac{1}{2}\beta^2mc^2 [/tex]
where v=βc and c = 3 x 108 meters per second. So
[tex] \beta=\sqrt{\frac{2\cdot KE}{mc^2}} [/tex]
So β = 0.03427, 0.04846, 0.05935, etc. for n=1, 2, 3, etc. and KE =n·300 eV.
When the electron is inside a drift tube, it is completely shielded from the applied voltage. You have to use an ac voltage and a drift tube so that when the applied voltage is the wrong polarity, the drift tube shields the electron, and the electron only "sees" the correct polarity voltage.
[added] If you use an ac frequency of f = 100 MHz, the drift tube lengths are [itex] L=\frac{\beta c}{2f}= [/itex] 0.05141, 0.07269, .08903 meters etc.
OK so a good way to see it is as follows:
tube 1 --> tube 2 - KE doubles
tube 2 --> tube 3 - KE * 1.5
so
Tube 1 = L
tube 2 = L*sqrt(2) = L-new
tube 3 = L-new * sqrt(1.5)
but this has answered by question so thanks a lot :)
The increase in kinetic energy (K.E.) in a 10-stage linac accelerator with a 200 kV supply can be attributed to the principle of energy conservation. In a linac accelerator, charged particles are accelerated by a series of electric fields created by alternating voltage sources. Each stage of the accelerator provides an additional electric field, allowing the particles to gain more kinetic energy as they pass through each stage.
In this scenario, the first stage of the accelerator is receiving a 200 kV supply. This means that each particle passing through this stage will gain 200 kV of potential energy. As the particles move through the first stage, this potential energy is converted into kinetic energy, resulting in a certain amount of K.E. at the end of the first stage.
When the particles move on to the second stage, they already have a certain amount of kinetic energy from the first stage. This K.E. is then added to by the second stage, which also receives a 200 kV supply. This results in a doubling of the K.E. compared to the first stage.
This process continues for each subsequent stage, with the particles gaining more and more kinetic energy as they pass through each stage. Therefore, at stage 2, the K.E. is twice that of stage 1, and this trend continues for each subsequent stage.
In summary, the increase in K.E. in a 10-stage linac accelerator with a 200 kV supply is due to the accumulation of energy from each stage as the particles progress through the accelerator. This demonstrates the efficient and effective nature of linac accelerators in providing high levels of kinetic energy to charged particles.
1. What is a 10-stage Linac accelerator with 200 kV supply?
A 10-stage Linac accelerator with 200 kV supply is a type of linear particle accelerator that uses a series of 10 electrically charged stages to accelerate charged particles, such as electrons or protons, to high energies. The 200 kV supply refers to the voltage of the power source used to generate the electric fields in each stage.
2. Why does the K.E. increase in a 10-stage Linac accelerator with 200 kV supply?
The K.E. (kinetic energy) increases in a 10-stage Linac accelerator with 200 kV supply because each stage of the accelerator applies an electric field to the particles, causing them to gain energy and accelerate. As the particles pass through each stage, the electric fields become stronger, resulting in a continuous increase in kinetic energy.
3. How does a 10-stage Linac accelerator with 200 kV supply differ from other types of accelerators?
A 10-stage Linac accelerator with 200 kV supply differs from other types of accelerators, such as circular accelerators, in its design and method of acceleration. While circular accelerators use magnetic fields to bend and accelerate particles in a circular path, a Linac accelerator uses electric fields in a linear path. Additionally, the number of stages and voltage of the power supply can vary in different types of Linac accelerators.
4. What factors affect the efficiency of a 10-stage Linac accelerator with 200 kV supply?
The efficiency of a 10-stage Linac accelerator with 200 kV supply can be affected by several factors, including the quality of the power supply, the design and condition of the accelerator's components, and the stability of the electric fields generated by each stage. Any fluctuations or malfunctions in these factors can impact the overall efficiency of the accelerator.
5. What applications is a 10-stage Linac accelerator with 200 kV supply used for?
A 10-stage Linac accelerator with 200 kV supply has many applications in scientific research, medicine, and industry. It can be used to produce high-energy x-rays for medical imaging and cancer treatment, to generate intense beams of particles for particle physics experiments, and to produce high-energy electron beams for industrial processes such as sterilization and materials testing.
  • Other Physics Topics
  • Mechanics
  • Mechanics
  • High Energy, Nuclear, Particle Physics
10K
