How are Stereographic Projections Derived in Differential Geometry?
In summary, the derivation for the equations for stereographic projection is straightforward, but the other direction is more difficult.
niall14
In cartesian coordinates (x.y,z) on the and (X,Y) on the plane, the projection and its inverse are given by the following formulae:
(X,Y)=(x/1-z,y/1-z)
(x,y,z)=(2X/1+X^2+Y^2, 2Y/1+X^2+Y^2, -1+X^2+Y^2/1+X^2 +Y^2)
This relates to the field of differntial geo.Anybody have a proof to where thes equations are derived?
Thanks very much
The derivation is straightforward if not somewhat cumbersome. Do you know how stereographic projection is defined? You take the straightline through a pole and a point on the sphere and project it onto the plane. Consider a fixed point on the sphere (x,y,z) and find the line through the North pole and (x,y,z). Then find where it intersects the plane z=0.
thanks for your reply.not really to sure what u mean by 'project'.if you could give me the first few lines of the proof I am sure i could figure it out.
I'll give you one direction, the other follows similarly but is definitely the harder direction. Consider the north pole [itex] (0,0,1) [/itex] and let [itex] (x_0,y_0,z_0) [/itex] be a point on the sphere. Then the line between the north pole and this point is given by
[tex] x = x_0 t, \qquad y = y_0 t, \qquad z = 1 + (z_0 - 1)t [/tex]
which is easily calculated via basic geometric results. Notice that when [itex] t=0 [/itex] we get the North pole, and when [itex] t = 1 [/itex] we get the point on the sphere. Now we want to calculate where this line hits the z=0 plane, so in particular
[tex] z= 0 = 1+(z_0 - 1)t \quad \Rightarrow t = \frac1{1-z_0} [/tex]
Substituting this value into the equation of the line we get the intersection of the line with the plane
[tex] \left( \frac{x_0}{1-z_0}, \frac{y_0}{1-z_0}, 0 \right) [/tex]
and we drop the third coordinate since we want to identify the sphere with the plane.
Again, the other direction is a bit harder and more technical, but follows precisely the same idea. Give it a try yourself and see if you can get the right answer.
thanks ill give it a go
What is a stereographic projection?
A stereographic projection is a method of mapping points on a sphere onto a flat surface, typically a plane. It preserves angles and shapes, but distorts areas and distances.
What is the purpose of a stereographic projection?
Stereographic projections are commonly used in cartography to create maps of the Earth's surface. They also have applications in mathematics, crystallography, and astronomy.
How is a stereographic projection created?
A stereographic projection is created by projecting points on a sphere onto a tangent plane that touches the sphere at a single point, known as the "point of projection". This is typically done using mathematical equations or geometric constructions.
What are the advantages of using a stereographic projection?
One advantage of a stereographic projection is that it preserves angles, making it useful for navigational purposes. It also shows the entire sphere on a single flat surface, making it more visually appealing and easier to interpret.
What are the limitations of a stereographic projection?
One limitation of a stereographic projection is that it distorts distances and areas, particularly near the edges of the map. It also cannot accurately represent the entire surface of a sphere, as points near the "point of projection" are disproportionately enlarged.
