Electron Cloud described by a Gaussian distribution
In summary, we are given a problem involving a cloud of electrons moving from a negative to a positive plate under the influence of a laser pulse. The cloud has a spatial distribution described by a Gaussian distribution with a standard deviation of 1.0mm. We are asked to calculate the change in electric field across the cloud, which consists of 12 x 10^9 electrons. Using Gauss' law and the spherical form of the equation, we can express the portion of charge enclosed within the sphere by using the given charge distribution. However, further understanding of the problem is needed to arrive at a numerical solution.
MrBeano
A cloud of electrons are drifting from a negative plate to a positive plate after being liberated by a laser pulse, (separated by a distance z = 10cm with an original potential difference of 15V) at an instant in time the centre of the cloud has traveled 25mm from the negative plate and the spatial distribution of the charge is described by a Gaussian distribution with a standard deviation of 1.0mm.
Calculate the the change in electric field across the electron cloud if the electron cloud consists of 12 X 109 electrons.
The tutor said that Gauss' law, in one form or another must be used in the solution.
After some further reading I discovered the equation for the cylindrical gaussian surface of;
Flux = [itex]\oint[/itex] E dA
= E [itex]\oint[/itex] da
= E * 2[itex]\pi[/itex]rh
Flux also equals q/[itex]\epsilon[/itex]
Therefore
E = s / 2[itex]\pi[/itex][itex]\epsilon[/itex]r
I have not really found a reasonable numerical solution yet, which has led me to believe that the problem lies with my derivation of E or my understanding of what E means in the context of the question.
To make this approach work you need to do two things. 1) The cylindrical form you quoted is inappropriate to the problem, which has spherical symmetry. Use the spherical form instead (hint: it involves the surface area of a sphere.) 2) Express the portion q(r) of total charge that is enclosed within the sphere of radius r by using the given charge distribution.
1. What is the electron cloud described by a Gaussian distribution?
The electron cloud described by a Gaussian distribution is a mathematical model used to represent the probability of finding an electron at a given point in space around an atom. It is based on the principles of quantum mechanics and takes into account the uncertainty of an electron's position and momentum.
2. How does the Gaussian distribution explain the shape of the electron cloud?
The Gaussian distribution, also known as the bell curve, describes a symmetrical and continuous probability distribution. In the case of the electron cloud, it is used to show the likelihood of finding an electron at different distances from the nucleus. The peak of the curve represents the most probable location of the electron, while the wings of the curve show the decreasing probability of finding the electron at greater distances.
3. What is the relationship between the Gaussian distribution and the Heisenberg uncertainty principle?
The Gaussian distribution is closely related to the Heisenberg uncertainty principle, which states that it is impossible to know both the exact position and momentum of a particle at the same time. The Gaussian distribution takes this uncertainty into account and provides a way to mathematically represent the probability of finding an electron at a given position.
4. Can the Gaussian distribution be used for any atom?
Yes, the Gaussian distribution can be used to describe the electron cloud of any atom, regardless of its atomic number or electron configuration. However, the shape of the electron cloud may vary depending on the number of electrons and their energy levels.
5. How is the Gaussian distribution related to atomic orbitals?
Atomic orbitals are regions of space around an atom where there is a high probability of finding an electron. The shape of these orbitals is determined by the Gaussian distribution, as it represents the probability of finding an electron at different distances from the nucleus. The different types of atomic orbitals (s, p, d, f) have unique shapes and orientations, which can be described using Gaussian functions.
