Calculating Theoretical Yield for Copper Reactions: Help with Homework
In summary: I have to calculate number of moles of each substance each time. Do you have any examples of what the calculations would be for each reaction?In summary, A student is struggling to work out how to do a lab assignment. They are looking for help from an expert. The student has no idea which measurements to use for each reaction. They are asked to calculate the theorecital mass of copper (II) nitrate formed in reaction 1, the theoretical mass of copper (II) hydroxide formed in reaction 2, the theoretical mass of copper (II) oxide formed in reaction 3, the theoretical mass of copper formed, and the % yield of the overall reaction. They are also asked to check which
blicker
Here's the measurements from my expirement.
(reaction 1)
0.548 g Cu (s)
4.0 mL HNO3
100 mL DI water
(reaction 2)
30 mL 3.0 M NAOH
(reaction 3)
nothing was added.
(reaction 4)
200 mL of DI water
15 mL of 6.0 M HCl
(reaction 5)
2.095 g Zn
10 mL 6M HCl
5 mL methanol
5 mL DI water
40.767 g mass of evaporating dish
41.238 g mass of evaporating dish with solid
Here are the reactions:
reaction 1: theoretical mass of copper (II) nitrate formed
Cu+4HNO3-->Cu(NO3)2+2NO2+2H2O
reactoin 2: theoretical mass of copper (II) hydroxide formed
Cu(NO3)2+2NaOH-->Cu(OH)2+2NaNO3
reaction 3: theoretical mass of copper (II) oxide formed
Cu(OH)2-->CuO+H2O
reaction 4: theoretical mass of copper (II) sulfate formed
CuO+H2SO4-->CuSO4+H2O
reaction 5: theoretical mass of copper formed
Zn+CuSO4-->ZnSO4+Cu
I have no clue where to even start. my teacher said some of the measurements from the lab were needed in the calculations, but i don't know which measurements to use for each reaction.
First of all - what are you expected to calculate?
what I need to calculate (some of the measurements from the lab are used in the calculations):
im not asking you to do all those problems for me. but, i have no idea where to start. i need somebody to help show me how to do the first one, then i could do the rest on my own.
These can be calculated, no problem - but are you really asked to do it, or do you just guess you should do it?
Do you know what limiting reagent is?
Think about mass conservation. You started with some amount of copper, did some tricks with it - but you have not added nor removed copper. You end with copper again. Assuming everything went perfectly well - is there any reason for the amount of copper to change?
all of the reaction questions are apart of my assignment, so i have to do them all.
i think the limiting reactant is the reactant that limits the amount of product.
Good. Do you know how to check which reagent is limiting? If not, check out
http://www.chembuddy.com/?left=balancing-stoichiometry&right=limiting-reagents
Start with the first reaction - what is a limiting reagent, copper, or nitric acid?
Hm, I see you don't have concentration of nitric acid. If so, assume there was an excess of nitric acid.
i tried working it out. is this right?
0.548g Cu*(1 mol Cu/63.55g Cu)=0.009g mol Cu
0.009 mol Cu*(1 mol Cu(NO3)2/1 mol Cu)=0.009 mol Cu(NO3)2
0.009 mol Cu(NO3)2*(125.56g Cu(NO3)2/1 mol Cu(NO3)2=1.08g Cu(NO3)2
Yes and no. In general you are on the right track.
What is "g mol"?
0.009 seems to be rounded down way too far. You should use at least the same number of significant figures as you have in the copper mass.
sorry i didnt mean to stick that g in there. what should i have done differently besides rounding?
Other than things I listed what you did looks OK. Try the next step.
is there more i need to do for the first reaction? and would i do the second reaction the same way?
First reaction is OK. In general you may assume all other reactions can be done the same way, although - to be on the safe side - you should check each time if added reagents are in excess.
would i use the answer from the first reaction to calculate the second reaction?
i don't know if its right, but i used the answer from the first reaction to calculate the second reaction since all these reactions are connected.
1.08g Cu(NO3)2*(1 mol Cu(NO3)2/187.57g Cu(NO3)2)=0.00576 mol Cu(NO3)2
0.00576 mol Cu(NO3)2*(1 mol Cu(OH)2/1 mol Cu(NO3)2)=0.00576 mol Cu(OH)2
0.00576 mol Cu(OH)2*(97.566g Cu(OH)2/1 mol Cu(OH)2=0.562g Cu(OH)2
[/quote]
It can't be OK - what you wrote means 0.009 = 0.00576. I have not checked your math earlier, just the logic, obviously that wasn't enough.
What is molar mass of copper nitrate?
Other than that you are on the right track. Question: do you have to calculate number of moles of each substance each time? Or are they somehow dependent?
yeah i realized my math was wrong on the first reaction. i fixed it. and my teacher said we are suppose to work in that 4.0 mL of HNO3. its suppose to be turned into mols. how would i do that?
You can't without concentration. Perhaps it was just a stock concentrated solution, that would mean around 68% w/w. You have to check the solution density.
What is theoretical yield?
Theoretical yield is the maximum amount of product that can be produced in a chemical reaction if all reactants are completely converted to products.
Why is theoretical yield important?
Theoretical yield is important because it allows scientists to calculate the efficiency of a reaction and compare it to the actual yield obtained in the lab. It also helps in determining the amount of reactants needed for a desired amount of product.
How is theoretical yield calculated?
Theoretical yield is calculated by using the balanced chemical equation for the reaction and stoichiometry, which is the study of the quantitative relationships between reactants and products in a chemical reaction.
What factors can affect theoretical yield?
Theoretical yield can be affected by factors such as impurities in the reactants, side reactions, incomplete conversions, and experimental errors. It is important to control these factors in order to obtain a high theoretical yield.
What is the difference between theoretical yield and actual yield?
Theoretical yield is the maximum amount of product that can be produced, while actual yield is the amount of product that is actually obtained in a reaction. Actual yield is often lower than theoretical yield due to various factors such as impurities and experimental errors.
  • Biology and Chemistry Homework Help
