Example of Completely positive map from M_n to M_m
In summary, a completely positive map is a linear transformation that preserves positive semidefinite matrices. An example of such a map is the transpose map, which switches the rows and columns of a matrix. A completely positive map differs from a positive map in that it also preserves positivity under tensor products. It can also be extended to a larger matrix space. In quantum mechanics, completely positive maps are used to describe the evolution of density matrices and the process of quantum measurement.
Genericcoder
131
Can you guys give me a concrete example of a completely positive map from M_m → M_n?
I'm sorry you are not generating any responses at the moment. Is there any additional information you can share with us? Any new findings?
Could you please define it for us? I'm used to positive-definite maps, but not completely-positive ones.
1. What is a completely positive map?
A completely positive map is a linear transformation between two matrix spaces which preserves positive semidefinite matrices. This means that if the input matrix is positive semidefinite, then the output matrix will also be positive semidefinite.
2. What is an example of a completely positive map from Mn to Mm?
An example of a completely positive map from Mn to Mm is the transpose map, which takes an n x n matrix and produces an n x n matrix with its rows and columns switched. This map preserves positive semidefinite matrices because the transpose of a positive semidefinite matrix is also positive semidefinite.
3. How is a completely positive map different from a positive map?
A completely positive map is a stronger condition than a positive map. While a positive map only requires that the output matrix is positive semidefinite, a completely positive map also requires that the map preserves positivity under tensor products. In other words, if we apply the map to a tensor product of matrices, the resulting matrix should still be positive semidefinite.
4. Can a completely positive map be extended to a larger matrix space?
Yes, a completely positive map can be extended to a larger matrix space. This is because the map preserves positive semidefinite matrices, so any new matrices added to the larger space will still be mapped to positive semidefinite matrices.
5. How are completely positive maps used in quantum mechanics?
In quantum mechanics, completely positive maps are used to describe the evolution of density matrices, which represent the state of a quantum system. These maps are also used to describe the process of quantum measurement, as they preserve the positivity of the measured quantity.
  • Linear and Abstract Algebra
  • Computing and Technology
