What is the best way to troubleshoot slow internet speeds at night?
In summary, there are several factors that can affect internet speed, such as sharing bandwidth with others in your area, the time of day, and the activity you are doing online. It is possible that your ISP's name server may be overloaded, causing slow loading times for websites. Additionally, the distance and number of nodes involved in online gaming can also contribute to lag. As for antivirus software, it is a matter of personal preference and it is recommended to research and compare different options before making a decision.
888eddy
35
what affects internet speed?
my internet slows down significantly at night. i have done a speed test which indicates its actually faster but everything i do on the internet after around 8pm takes over twice as long. I'm assuming its a program slowing the connection and using up the bandwidth but what program?
Computer science news on Phys.org
What type of connection do you have? If you have cable you are sharing a pool of bandwith along with everyone else in your block( not a street block, but a block of customers to the isp). The after 8pm drop might indicate more people are on during this time.
Also what activity are you doing at 8pm that might be different then what you do earlier in the day. "everything i do on the internet" is vague.
By "slowness" do you mean having to wait for a page to come up when you click on a link, or do large files take longer to download, or both?
If it's the first but not the second, then the problem might be that your ISP's name server is overloaded in the evening. When you access a new page, your computer has to look up the numeric IP address that corresponds to a domain name like physicsforums.com, using your ISP's name server.
Where I work, the raw connection speed is much faster than at home, so I can download large files faster at work. However, at work it takes longer for pages to load, especially when it's a complicated page with images and other pieces from more than one server. I think my school's name server doesn't have as much "horsepower" as it really should have. The ISP that I use at home has more resources.
Another possibility is that the time zone difference between you and the sites you're accessing is great enough that it's daytime wherever they are.
cheers jtbell and CaptainQuasar. your probably both right. shame there's not much i can do about it except mabye change my isp.
It could be bandwidth issues at your end or an issue at the web sites you typically visit.
Try downloading something from Microsoft. I'm currently using Cox cable (Southern California), but there aren't many others nearby using cable modems, and although the stated download rate is 12 megabits per second, I've seen over 2 megabytes / second downloads from Microsoft, although Cox may be caching some of these (my last download was Virtual PC 2007 SP1 which wouldn't seem to be that popular), or there's some compression going on (2 megabytes would be 16 megabits per second), or Cox had yet again bumped up the speed (it's just a paramater in a cable modem set by the ISP via software commands). Note that Cox limits upload speed to about 10% of the download speed (to discourage people hosting servers).
If you're referring to lag in online gaming, it's the distance and number of nodes involved between you, the server, and/or other players. The time it takes for information to propagate isn't affected by bandwidth (if the information packets are relatively small). Satellites, being 22,000 miles up, add about 1/4 second of lag (22,000 miles x 2 / (186,000 miles / second), for each transfer of information.
The current limit for USA (DOCSIS 1.1 or 2.0) cable modems is 38.7 megabits / seconds download, 9 (DOCSIS 1.1) or 27 (DOCSIS 2.0) megabits / second upload. This would consume all of a 6 mhz channel on a cable. My cable modem supports 88mhz to 860mhz, being able to select 1 of up to 128 channels.
i am a newy in computers compare with you guys so i will like to ask you something
is nod antivirus better than spybot search and destroy?
Where I work, the raw connection speed is much faster than at home, so I can download large files faster at work. However, at work it takes longer for pages to load, especially when it's a complicated page with images and other pieces from more than one server. I think my school's name server doesn't have as much "horsepower" as it really should have. The ISP that I use at home has more resources.[/QUOTe
hi jtbell i am a newy in computers compare with you so i will like to ask you something
What affects internet speed?
There are several factors that can impact internet speed, including:
1. What is the type of internet connection being used?
The type of internet connection can greatly affect speed. For example, a fiber optic connection will typically be faster than a DSL or satellite connection.
2. How many devices are connected to the network?
The number of devices connected to a network can also impact internet speed. The more devices using the network, the slower the speed may be, especially if multiple devices are streaming or downloading large files simultaneously.
3. Is the network equipment up to date?
Outdated network equipment, such as routers or modems, can also affect internet speed. It is important to regularly update these devices to ensure optimal performance.
4. Are there any network congestion or bandwidth limitations?
Network congestion, which occurs when many users are trying to access the internet at the same time, can slow down internet speed. Additionally, some internet service providers may have bandwidth limitations, which can impact speed during peak usage times.
5. Is there a problem with the website or server being accessed?
Sometimes, slow internet speed may be due to a problem with the website or server being accessed. This could be caused by a high volume of traffic or technical issues on the website's end.
  • Computing and Technology
  • Aerospace Engineering
