Writing unit vectors in terms of sin/cos?
In summary, to write a unit vector in terms of sine and cosine, use the formula u = cos(θ)i + sin(θ)j, where θ is the angle between the unit vector and the positive x-axis. This can also be written in terms of tangent and cotangent, as well as in terms of its components. The angle θ can be determined using inverse trigonometric functions, and using the Pythagorean theorem, the magnitude of the unit vector can be found.
cdotter
305
Where could I find a webpage or guide on how to write unit vectors in terms of sin and cos? I looked through my textbook and tried searching google, but I can't find anything...I must be using the wrong terminology.
edit: Delete me! I had one of those epiphany moments and figured it out. :blushing:
1. How do I write a unit vector in terms of sin and cos?
The general formula for writing a unit vector in terms of sin and cos is u = cos(θ)i + sin(θ)j, where θ is the angle between the unit vector and the positive x-axis. This formula is derived from the Pythagorean theorem and the definition of sine and cosine as ratios of sides in a right triangle.
2. Can I write a unit vector in terms of only one of sin or cos?
Yes, you can write a unit vector in terms of only sin or cos, but it may not be a unique representation. For example, if you write u = cos(θ)i, there are infinitely many unit vectors that satisfy this equation, as long as θ is a multiple of 360 degrees.
3. How do I determine the angle θ for a given unit vector in terms of sin and cos?
To determine the angle θ, you can use the inverse trigonometric functions. For example, if the unit vector is u = ½i + ½j, then θ = 45 degrees, since cos(45) = sin(45) = ½.
4. Can I use other trigonometric functions to write a unit vector?
Yes, you can also use tangent and cotangent to write a unit vector. The formula is u = cos(θ)i + sin(θ)j = cot(θ)i + tan(θ)j, where θ is the angle between the unit vector and the positive x-axis.
5. Are there any other ways to write a unit vector besides using trigonometric functions?
Yes, you can also write a unit vector in terms of its components. For example, if the unit vector is u = a i + b j, then its magnitude is |u| = √(a^2 + b^2) = 1, which can be used to find the values of a and b. This method is useful when the unit vector is not given in terms of trigonometric functions.
