Calculating a Kis value for a competitive inhibitor
  • Thread starter gravenewworld
  • Tags
    Value
In summary, the Kis value can be found by plotting the slope of the reciprocal plots of the MM equation and determining the x intercept, which is equal to -1/Kis.
gravenewworld
1,132
Say you are given the velocity of a reaction catalyzed by an enzyme and associated concentrations of substrate, but there is also a competitive inhibitor present. To find Vmax and Km for the reaction you would plot the reciprocal plot of the Mekelis(sp?)-Menton Equation and estimate the Y and X intercepts. My question is, I know that if you plot the slope of the reciprocal plots of the MM equation vs. different concentrations of inhibitor you can find the Kis value for the enzyme inhibitor complex from the x intercept of this plot. Is the Kis value = -(the x intercept) or is -(1/Kis)=x intercept?
Chemistry news on Phys.org
The x intercept of the plot of the reciprocal plot of the MM equation vs. different concentrations of inhibitor is equal to -1/Kis, where Kis is the inhibition constant for the enzyme-inhibitor complex.
The Kis value is equal to the negative x-intercept of the slope plot of the reciprocal plots of the MM equation. This is because the x-intercept represents the concentration of inhibitor that results in half maximal velocity, and the Kis value is defined as the concentration of inhibitor that binds to the enzyme with half the affinity of the substrate. So, the Kis value is equal to the negative x-intercept, not the negative of the reciprocal of the x-intercept.
1. What is a Ki value for a competitive inhibitor?
A Ki value, also known as the inhibition constant, is a measure of how tightly a competitive inhibitor binds to its target enzyme. It represents the concentration of the inhibitor at which half of the enzyme's active sites are occupied by the inhibitor.
2. How is a Ki value calculated?
A Ki value is calculated by performing a series of experiments in which the concentration of the inhibitor is varied while keeping the concentration of the enzyme and substrate constant. The data is then plotted on a graph and the Ki value is determined by finding the concentration of inhibitor that results in half-maximal inhibition.
3. What is the significance of a high or low Ki value?
A high Ki value indicates that the inhibitor binds weakly to the enzyme, meaning it can be easily displaced by competing molecules. A low Ki value indicates a tight binding between the inhibitor and enzyme, making it difficult for other molecules to bind and inhibit the enzyme's activity.
4. How does a competitive inhibitor affect the Michaelis-Menten equation?
A competitive inhibitor binds to the active site of the enzyme, preventing the substrate from binding and slowing down the rate of the reaction. This changes the apparent affinity of the enzyme for the substrate and therefore affects the Km value in the Michaelis-Menten equation.
5. Can a Ki value be used to compare different inhibitors?
Yes, the Ki value can be used to compare the potency of different inhibitors. A lower Ki value indicates a more potent inhibitor, as it binds more tightly to the enzyme. This can help in drug development and determining the most effective inhibitor for a specific enzyme.
  • STEM Educators and Teaching
  • Biology and Medical
14K
