Comparing coefficients of polynomial congruences.
In summary, the AKS - Primality test was discussed, which states that for gcd(a, n) = 1, we have (X - a)^n\equiv X^n - a\ (mod\ n) if and only if n is prime. The proof involves using the fact that \binom{p}{k}\equiv 0\ (mod\ p) for 1\leq k < p and comparing coefficients to reach a contradiction. However, this raises the question of when comparison of coefficients can be done for congruent polynomials, which boils down to when a^m is a unit in the ring \mathbb{Z}_n. This is true if (a,n)=1, which is
Yuqing
218
Today I read about the AKS - Primality test in which the simple theorem
For gcd(a, n) = 1, we have
[tex](X - a)^n\equiv X^n - a\ (mod\ n)[/tex]if and only if n is prime.
was proven. The if direction is quite trivial from the fact that [itex]\binom{p}{k}\equiv 0\ (mod\ p)[/itex] for [itex]1\leq k < p[/itex]. The other direction comes as follows (sketch):
Suppose [itex](X - a)^n\equiv X^n - a\ (mod\ n)[/itex] and that n was composite. Let p be a prime divisor of n and [itex]p^k[/itex] the largest power of p which divides n. Then [itex]p^k[/itex] does not divide [itex]\binom{n}{p^k}[/itex] so we have on the left a coefficient of [itex]x^{p^k}[/itex] which is non-zero and on the right a coefficient which is 0. By comparison of coefficients, we reach a contradiction.
The problem I have with the proof is the last step, the comparison of coefficients. I thought that this cannot be done in general with congruences. This brings me to a more general question which is: When can comparison of coefficients be done for congruent polynomials.
Mathematics news on Phys.org
Your question is: When are we allowed to conclude ##\mu a^m \equiv \nu a^m \,\operatorname{mod} n \Longrightarrow \mu \equiv \nu \,\operatorname{mod}n\,?##
The equation lives in the ring ##\mathbb{Z}_n##, so the question is: When is ##a^m \in \mathbb{Z}_n## a unit, in which case we can cancel it and are left with ##\mu \equiv \nu\,\operatorname{mod}n\,.## And ##a^m## is a unit, if it is coprime to ##n##. Since ##(a,n)=1## are coprime, so are ##(a^{(p^k)},n)=1\,.## Here we use, that ##\binom{n}{p^k}## is the coefficient at ##a^{(p^k)}\,.##
What is the purpose of comparing coefficients of polynomial congruences?
The purpose of comparing coefficients of polynomial congruences is to determine if two polynomials are congruent modulo a given number. This can help in solving mathematical equations and proving number theory theorems.
How do you compare coefficients of polynomial congruences?
To compare coefficients of polynomial congruences, you first need to identify the coefficients of the two polynomials. Then, you can use the modulo operator to check if the coefficients are congruent or not. If they are congruent, then the polynomials are congruent modulo the given number.
What are the properties of congruent coefficients in polynomial congruences?
The properties of congruent coefficients in polynomial congruences are that they have the same remainder when divided by the given number, and they follow the same algebraic rules as regular numbers. This means that if two coefficients are congruent, their sum, difference, and product will also be congruent.
Can comparing coefficients of polynomial congruences be used to solve equations?
Yes, comparing coefficients of polynomial congruences can be used to solve equations. By comparing the coefficients, you can determine if two polynomials are congruent, which can help in solving equations with unknown variables. This method is often used in number theory and algebraic equations.
Are there any limitations to comparing coefficients of polynomial congruences?
Yes, there are some limitations to comparing coefficients of polynomial congruences. This method can only be used with polynomials and not with other types of equations. Also, it may not always provide a unique solution and may require additional steps to fully solve the equation.
  • General Math
10K
  • General Math
