Handheld 10W Laser: Possibilities and Concerns
In summary, building a 10 watt (battery powered) handheld laser is not possible due to battery limitations and the inefficiency of lasers, which would result in excessive heat. Additionally, without proper laser safety training, the high power output of such a device could pose serious hazards to one's eyes and skin. While there are laser pointers available in the 1-2 watt range, they are not considered safe for handheld use and are only suitable for enclosed machines with safety measures in place. The issue of availability and legality of such devices is also a topic of debate. The efficiency of modern laser diodes can reach over 50%, making them the most efficient light emitter currently available.
Mgt3
80
Is it in any way possible to build a 10 watt (battery powered) handheld laser?
a typical 5mw laser will kill batteries pretty quick. You start putting many orders of magnitude more power in the batteries won't work. Also the efficiency of lasers are very bad so there would be tremendous heat.
Sure. What's the application? What laser safety training have you had?
I have not had laser safety training (where can you get instructions), but it's obvious that a 10 watt laser would pose eye and skin hazards. My reason for asking is this: I've seen certain green/blue/infrared laser pointers sold between 500 mW - and 1 watt in a flashlight type unit. It might be useful for people interested in material cutting if you could make a similarly compact, portable unit at a higher output.
A handheld unit wouldn't be safe at all. Too easy to slip. Power levels like that require enclosed machines with safety interlocks and other measures.
I'm surprised that "laser pointers" are available in the 1W range as well. Could you provide some web pointers? Hard to believe they are made -- the liability is huge.
This is a country where you can buy assault rifles at the mall rememebr.
There are a bunch of 1-2W DPSS, a few are really 500-600mW 532nm that can run at 1W for a few seconds before over-heating. The really nice feature is that most of them are frequency doubled so there is an unknown amount of 1um infrared that you can't see!
True enough. But not silencers. (ironic analogy, eh?)
But they're so easy to make, who needs to buy one? (My favourite achievement was designing one for a rifle that can be turned on and off.:cool:)
Please excuse my ignorance on the issue, but what kind of danger does a 1-2 watt laser pose?
The most obvious one is visual. Anything with even a small percentage of that power can destroy the retinae in your eyes. Skin burns and accidental fires are also possible in that power range.
I was unaware that 1 watt was enough to damage skin. At what power does a laser become lethal? More importantly, why are these devices which can inflict, at minimum, irreversible damage to a person's eyes so easily available?
I am totally unfamiliar with the politics involved. You might as well ask why Tasers are illigal here in Canada, yet can be bought at a grocery store in the US. Lethality depends upon both the location and the duration of exposure, so that question is not really answerable.
So a 5 watt laser probably wouldn't be lethal?
Lethality is not the issue at all. And skin burns really aren't either. Eye/retina damage is primarily the issue. Blindness is no joke. Wouldn't you agree?
Again, location and duration. Neither a shot from a .22 nor thirty seconds with an electric drill in your foot will kill you. Either applied to your temple is a different story.
edit: Hi, Berkeman. You sneaked in on me again.
And you wonder why they call him Danger... :eek:
:biggrin:
How efficient is bad to you?
Modern laser diodes (multi watt) are have greater efficiencies than 50%.
http://www.repairfaq.org/sam/laserdio.htm#diotoc
In fact, high power laser diodes - those outputting WATTs of optical power - are without a doubt the most efficient light emitter - not just lasers - in existence. Some have electrical to optical efficiencies (DC W into light W out) of greater than 50 percent! In other words, put 2 watts of DC power in and get out 1 W of light. And, research is in progress to improve this to 80 percent or beyond.
http://www.repairfaq.org/sam/laserdio.htm#dioldlb
Consider: Some commercially available high power laser diodes have an overall conversion efficiency - electrical power into optical power out - of over 50 percent. Current research is attempting to boost this past 80 percent.
My 50 watt laser diode generates 50 watt of light with 2.5v @ 60 amps (150 watts power in.) 150 watts in and 50 watts out in light = 33.3% efficiency. This is with 4-5 year old solid state laser diode tech.
As for the original question, can one build a 10 watt (battery powered) handheld laser, the answer is a simple yes.
I've powered this 50 watt laser with a few pol-li batteries and a proper shunt resistor, I do not recommend this unless you really know what your doing, i.e. know your internal battery resistance, don't go past C rating, etc..
But the rest of the energy would be in the form of heat, so it will get hot fast, i.e. use proper heatsink, and just don't run it more than x seconds at a time.
FYI, I have proper eye wear (808nm), and I actually stopped using them, as I'm not present in the room, i.e. I use a remote camera to observe. >50mw lasers can get very dangerous, even with 1 watt diode reflecting off dull metal can hit your eye to blind you.
Yes you can, see my previous post.
BTW please if you do an laser project, please Google "SAM FAQ laser guide" and read all the safety parts. And at Minimum buy (ebay) laser eye protection wear that matches your laser diode range.
It's not just the OP that needs protection, given the way that he presented the question. It's those in his vicinity who are at risk. I'm not sure what the legal terminology in his location would be, but 'criminal negligence causing bodily harm' would apply where I live. Not a good idea.
This is correct, original poster could be facing "criminal negligence" if used in a improper manner, basically anywhere outside, or in a room with people.
Well said everybody. Hopefully the OP takes our comments to heart. Thread locked.
Received via PM from the OP. Posting here for clarification.
Mgt3 said:
I read that 10 watt lasers were used for cutting metal and assumed that they would be the more dangerous type of laser for sale and worried that a powerful laser like that could come out for sale in a laser pointer in the future if it is not already out. I would ask that you please let the thread reflect that I have no intention of building such a device and posed my original question for educational purposes only.
1. How does a handheld 10W laser work?
A handheld 10W laser works by using a power source to generate a high-intensity beam of light. This beam of light is then focused and amplified using a series of lenses and mirrors, allowing it to reach a power output of 10 watts. The laser beam is emitted through an aperture or opening at the end of the handheld device.
2. Is it safe to use a handheld 10W laser?
While a handheld 10W laser can be safe to use, it is important to always follow proper safety precautions. This includes wearing laser safety glasses to protect your eyes from the intense beam of light, as well as avoiding pointing the laser at anyone or anything that could be harmed by the high-powered beam. It is also important to carefully read and follow the instructions provided by the manufacturer.
3. What materials can a handheld 10W laser cut through?
A handheld 10W laser can cut through a variety of materials, including wood, plastic, and certain types of metals. However, the thickness of the material that can be cut will depend on the power and strength of the laser. It is important to carefully consider the material and its thickness before attempting to use a handheld 10W laser for cutting.
4. How do I maintain a handheld 10W laser?
Proper maintenance of a handheld 10W laser is essential for ensuring its longevity and safe operation. This includes regularly cleaning the lenses and mirrors to prevent dust and debris from affecting the laser's performance. It is also important to use the laser in a well-ventilated area to prevent overheating and to periodically check and replace any worn or damaged parts.
5. Can I build my own handheld 10W laser?
Building a handheld 10W laser can be a complex and potentially dangerous task, as it involves high-powered components and precise assembly. It is recommended to purchase a commercially available handheld 10W laser from a reputable manufacturer rather than attempting to build one on your own. This will ensure proper safety measures and quality components are used for the laser's construction.
  • Electrical Engineering
  • Earth Sciences
  • Atomic and Condensed Matter
