[HELP]- Determine the Resultant of the Force System.
In summary: The moment produced by a force depends on the point you are using to calculate the moment. For example, in your problem the moment of the 100 lb force about point A is 100*0 = 0, about the midpoint of the beam it would be 100lbs*8ft, and about the right end of the beam it would be 100lbs*16ft.
  • #36
Dellis said:
I didn't say it was 4 feet from the midpoint of the line load to point A, I wondered if the midpoint you said to mark is half the distance of 8 ft, which is 4ft.
Yes, the midpoint is right in the middle of the 8 ft span, thus 4 ft from each end of that span.
  • #37
Ok I knew I had something right there, so after that would the equation be this?, btw what about the Roller Distance toward POINT A?
[tex]\Sigma[/tex]M= -100( 0 ) -700(8) - 160( 4 )(8) - 160(16) =
Can't believe this is 3 pages deep, can't believe this is confusing me so bad.
  • #38
Got your PM...
Are you still having problems with this?
CS
  • #39
If you take the moment about A, then
ΣM = -100(0) - 700(8) - 160(8 + 4)
R = -(100 + 700 + 160)
X(bar) =ΣM/R.
  • #40
No, still not correct. The line load force is 160 lb. Where does it act? Effectively at the midpoint of the line load. So to calculate its moment about point A, you need the distance between that midpoint and point A. What is that distance?
The distance between the roller and point A is irrelevant.
  • #41
X(bar) =ΣM/R.
Wow so is (8 + 4)?, here I was thinking multiplication(8)(4) for some reason
can you explain how you got R=-(100 + 700+ 160)?
because the mentor told me what I had before was good in terms of the summation of
the forces.The X(/bar) part I know how to do that, the issue I was having was the summations of the moments and noticing the reactions, as you can see I am 3 pages deep with that issue.
  • #42
stewartcs said:
Got your PM...
CS
sadly yes, the Moments part got me going in circles, one things for sure I am learning as I am making all of these mistakes, so it is good experience.
  • #43
12...
ΣM = -100(0) - 700(8) - 160(8 + 4)yeah I figured it was irrelevant when you went off line(or looked like you did) then I erased that out of my process.
  • #44
Dellis said:
Wow so is (8 + 4)?, here I was thinking multiplication for some reason
the forces.
The X(/bar) part I know how to do that, the issue I was having was the summations of the moments and noticing the reactions as you can see I am 3 pages deep.
The magnitude of the resultant is the summation of the two point loads and the distributed load. Hence, -100 + (-700) + (-20 lb/ft x 8 ft) = -(100 + 700 + 160) lb. The negative sign is due to the convention chosen (i.e. downward is negative).
CS
  • #45
Dellis said:
12...
Looks good.
CS
  • #46
CS
ah ok, well he left that out, so was wondering, thanks for clearing that up.So I should use that to get the resultant?, I thought my summation of the forces was called "good" by the mentor.
Doc Al said:
Good, this will tell you the magnitude of the force.
  • #47
That is the magnitude of the resultant...you will use that to find the point of application of the resultant force (i.e. x_bar).
CS
  • #48
Doc Al said:
I know you've already gotten help on this issue, but just for the record:
You are taking moments about point A, which is fine. But you're using the wrong distance for the 160 lb force.
He told you the same thing regarding the resultant...However he told you that your moment calculation was still wrong...which it was at the time.
I'm not sure what you are asking now.
CS
  • #49
stewartcs said:
He told you the same thing...I'm not sure what you are asking now.
CS
He told me the summations of forces was good, meaning I can get the Resultant with this
[tex]\Sigma[/tex] F= -100 lb - 700 lb - 160 lb=...
Then I was presented with this a few seconds ago, explained further by you
^That isn't asking me to multiply right?, it isn't asking me to multiply -1 with(100+700+160)
right?
He just put it that way but it still means this [tex]\Sigma[/tex] F= -100 lb - 700 lb - 160 lb=..., what I originally have in my process.
  • #50
right?
Those two are equivalent. One just factors out the negative sign...
CS
  • #51
CS
Sorry I just got a bit confused, he presented it in a way not shown to me in the book but yeah it is the same...
post after this one has my calculations done
  • #52
[tex]\Sigma[/tex] F= -100 lb - 700 lb - 160 lb= -960
R = -(100 + 700 + 160)=-960
No problem...that's why we are here...
CS
  • #53
CS
I appreciate it, I learned more reading these forums then using this 150 dollar buck, thanks again.
Ok so here the finish line right?...
ΣF= -100 lb - 700 lb - 160 lb= -960 lb
ΣM = -100(0) - 700(8) - 160(8 + 4)= - 7520 lbX(bar) =ΣM/R.
-7520 lb/-960lb= 7.83 lb
  • #54
Dellis said:
Ok so here the finish line...
[tex]\Sigma[/tex] F= -100 lb - 700 lb - 160 lb= -960 lb
X(bar) =ΣM/R.
Check your units...
CS
  • #55
stewartcs said:
Check your units...
CS
Woah I almost forgot about that lil detail, so this is it right.ΣF= -100 lb - 700 lb - 160 lb= -960 lb
ΣM = -100 lb(0) - 700 lb(8) - 160lb/ft(12)= -7520 lb/ftX(bar) =ΣM/R
-7520 lb/ft (divided by) -960lb= 7.83 ft
  • #56
Dellis said:
Woah I had forgot about that lil detail, so it is like this
X(bar) =ΣM/R.
Correct.
CS
  • #57
stewartcs said:
Correct.
CS
Yes!:), thank you all for the guidance in regards to this problem, see now I can do these type of exercises since I understand the process, that is my problem I need to get familiar with the processes.Like I said before I do have two other problems I tried doing by myself and I need them checked/corrected, I will make a new thread since this one is too much already, hopefully you can provide further guidance for those two :).
