New Reply
Calculating the force required to displace a tensioned cable
Share Thread Thread Tools
Feb11-13, 07:02 PM   #1
Hi,
I'm trying to figure out a method for calculating the force required to displace (axially by 5mm) an elastic material that is tensioned longitudinally at 105 N.
Material properties:
Cross-sectional area: 100mm^2
Stiffness, K = 1652 N/mm
Modulus, E = 0.68 GPa
Length of material, L = 41.9 mm
I need help finding a relationship between required force as a function of displacement, tension and other involved variables.
Thank you! Please let me know if you need any more information.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Feb12-13, 02:32 PM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
hi abhiramv! welcome to pf!
show us what you've tried, and where you're stuck, and then we'll know how to help!
Feb21-13, 10:27 AM   #3
Hi tiny-tim, Thanks!
Sorry for the super delayed response.
I'm honestly not sure where to start. I've taken mechanics courses, so I was going to use a beam-bending model, but I wasn't sure how that would apply to an elastic material that is already tensioned.
Any advice would be greatly appreciated!
Feb22-13, 02:40 PM   #4
If you mean longitudinal displacement, then the answer is staring you in the face in your question. If you mean lateral displacement, that is a bit more complicated. So...badly worded question?
Feb22-13, 02:53 PM   #5
Hi Pongo38. Yes, I mean lateral displacement (In my original post I wrote axial displacement of a longitudinally tensioned elastic material).
Feb22-13, 04:00 PM   #6
Your value for k is meaningless unless it is better defined. I assume you mean central lateral force and corresponding 5mm deflection. Consider the triangle of forces at the central node representing equilibrium, and then draw a geometrically similar triangle for the geometry of the situation. Answer is then obvious. (at least it's a good first approximation and you can refine it from there)
Feb23-13, 11:27 AM   #7
nvn
Recognitions:
abhiramv: Is this a schoolwork question? I am currently assuming you want the cable axial force required to elongate your cable axially (longitudinally). If your material remains in a range that is approximately linear, then the tensile force is approximately T2 = k*x, where k = cable axial stiffness, and x = cable axial elongation. E.g., if x = 5 mm, then T2 = k*x = (1652 N/mm)(5 mm) = 8260 N. If the cable was pretensioned to T1 = 105 N, then the new cable tension is T3 = T1 + T2 = 105 + 8260 = 8365 N. Let us know if this is not what you want.
New Reply
Tags
displace, displacement, tension
Thread Tools
Similar Threads for: Calculating the force required to displace a tensioned cable
Thread Forum Replies
calculating force required for lifting Advanced Physics Homework 3
mass on a tensioned cable with axial/transverse oscillations Engineering, Comp Sci, & Technology Homework 5
Calculating force to displace water General Physics 3
Calculating force required for specific strain Materials & Chemical Engineering 2
Calculating force required for specific strain Materials & Chemical Engineering 9
