Register to reply
Current vs voltage
by neeraj kaira
Tags: current, voltage
Share this thread:
neeraj kaira
#1
Mar13-14, 07:54 AM
neeraj kaira's Avatar
P: 30
Is it possible to decrease the voltage without decreasing the current????
Phys.Org News Partner Engineering news on Phys.org
Researchers find security flaws in backscatter X-ray scanners
Virtual reality guides those whose memory is failing
Intelligent navigation system to personalise shopping trips
phinds
#2
Mar13-14, 08:12 AM
PF Gold
phinds's Avatar
P: 6,275
Quote Quote by neeraj kaira View Post
yes, by decreasing the load.
Your question out of context really doesn't make any sense.
neeraj kaira
#3
Mar13-14, 08:19 AM
P: 30
Quote Quote by phinds View Post
I know this any other formula for it
psparky
#4
Mar13-14, 08:33 AM
PF Gold
psparky's Avatar
P: 752
Current vs voltage
Yes.
V=IR.
Voltage=current X resistance
phinds
#5
Mar13-14, 08:36 AM
PF Gold
phinds's Avatar
P: 6,275
Your question out of context continues to not make any sense.
neeraj kaira
#6
Mar13-14, 08:48 AM
P: 30
Haha again ohm's law
berkeman
#7
Mar13-14, 11:01 AM
Mentor
berkeman's Avatar
P: 40,932
Look, you are wasting people's time. Please stop doing that.
State your full question and application clearly, or this thread will be deleted.
neeraj kaira
#8
Mar13-14, 11:04 AM
P: 30
And you are wasting mine...stop commenting
berkeman
#9
Mar13-14, 11:05 AM
Mentor
berkeman's Avatar
P: 40,932
Thread closed. Check your PMs.
berkeman
#10
Mar13-14, 12:20 PM
Mentor
berkeman's Avatar
P: 40,932
Turns out his question was about DC-DC converters. From a PM exchange:
Ok let me tell you...i m thinking to make a charger which output should be 5v 1.5 - 2 A
And i'm getting 18 v after stepping down the voltage so i want ti decrease the voltage to 5volts keeping current high.
Hope you will get this .
Quote Quote by berkeman
You use a "Buck" DC-DC converter to lower the voltage with high efficiency:
http://www.maximintegrated.com/app-n...ex.mvp/id/2031
They are available off-the-shelf, or you can build your own with a Buck DC-DC converter IC, an inductor, a diode, and a capacitor.
Regards,
berkeman
PF Mentor
Register to reply
Related Discussions
Amplifiers - Voltage gain of a current controlled voltage source and current source. Engineering, Comp Sci, & Technology Homework 10
Finding resistor's voltage with current and voltage sources present Introductory Physics Homework 5
Figuring out voltage across resistor and current in loop given initial voltage input Engineering, Comp Sci, & Technology Homework 2
How to get Voltage vs. Time graph from having Current and Voltage values. Introductory Physics Homework 1
Current to voltage conterter and voltage to current converter Engineering, Comp Sci, & Technology Homework 3
